Go Back   AudiWorld Forums » Audi Models » Audi A4 » A4 (B5 Platform) Discussion
Old 09-07-2003, 07:15 AM   #1
Quattromatt
Junior Member
Account #: 61775
Default CHECK ENGINE LIGHT WENT ON...
I have an 99.5'A41.8T. I installed the HKS intake system, APR chip, and TurboXS BPV. After I installed the intake my check engine went on. I got a The vag-com software and ran it and cleared the light. It obviously went on again! Is there a way to keep it off. Is there a way to reprogram the ecu to know that there is more air coming in? Is there a way to adjust the air/fuel ratio?
2000 S4 APR Stage 2+
mods:never enough
Dyno 4/22/06
93oct. 270whp 335wtq
<RIP - 1999.5 A4 1.8T Quattro>
<aim id: gsrmatt13>
http://cgi6.ebay.com/ws/eBayISAPI.dl...3&since=-1
Quattromatt is offline   Reply With Quote
Old 09-07-2003, 07:18 AM   #2
RKA
Member
Account #: 2062
Default If you put black electrical tape over the check engine light, it won't come on again.
What code came up when you scanned the codes? You have a problem, which needs to be addressed...but we have NO idea what the problem is, unless you give us the code (or search the archives to find out for yourself).
2005.5 A4 Avant 2.0T Quattro 6MT
APR 91/93/100 | APR Exhaust | 19" BBS RS-GT's | Carbonio | Hotchkis | Partridge-in-a-pear-tree
Others:
2006 TL on the block
2001 S4 sold
2000 A4 sold
*** September 11th, 2001 - Never Forget ***
RKA is offline   Reply With Quote
Old 09-07-2003, 07:19 AM   #3
AudiAddict B7
Junior Member
Account #: 32794
Default Did you actually read the DTC to see what the problem is?
07 A4 2.0T QM Prem, Conv, Cold, Tech, Xenons, B-Tooth
GONE: 06 A4 2.0T QM
GONE: 99.5 1.8TQ APR SIII, Milltek Exhaust, Spec III clutch, H&R/Bilsteins, Strat Short Shifter, A8 Rotors + Hawk HPS pads XM Radio, Infinity Components, Kenwood Subs, S4 HID's, Cellport hands free, Phatnoise.
AudiAddict B7 is offline   Reply With Quote
Old 09-07-2003, 08:29 AM   #4
Mat Indukts Lambos
Audiworld Sponsor
Account #: 54525
Default Ditto on what RKA said below. Sounds like your HKS intake is causing problems....
From what I've seen & heard, the larger intake can change the flow of air through the MAF enough to upset the reading significantly.
Also, the oil used in aftermarket intake filters(K&N, HKS, etc.) can get pulled in with the air, get onto the heated portion of the MAF sensor, and burn onto it, causing the obvious problems.
There's got to be a solution though, otherwise why would they sell it?
Might be jumping to conclusions, what's the DTC's?
Soon to be "The mechanic formerly known as 'Mat@4induktion'"
Email me at audigeek@hotmail.com
AIM: MatJReid
NOW AVAILABLE on the black market: custom colored braided brake lines for audi A4 quattro & S4, and VW Mk IV golf/jetta/new beetle. Versions for brembo & stoptech kits also available.
In the stable......
'90 CQ 20V, with some nice mods - - SOLD!
'05.5 S4, stock, for now.
'02 S4, wife's ridin' in style.
'03 R1, when nothing else is fast enough - - FOR SALE in March 07!!!
Mat Indukts Lambos is offline   Reply With Quote
Old 09-07-2003, 08:36 AM   #5
Yippers®
Member
Account #: 19399
Yippers®'s Avatar
Default Check your connection on the MAS and that you haven't broken a MAS wire in screwing with it when you
removed it from the airbox and installed it in the HKS assembly. The wires running up to the MAS are very delicate and don't tolerate flexing very well. Make sure they are well supported, have sufficent strain relief and are well tied down.
Yippers® is offline   Reply With Quote
Old 09-07-2003, 09:04 AM   #6
BOOSTD
Elder Member
Account #: 6443
Default THEIF!!!!!
Please read.
BOOSTD is offline   Reply With Quote
Old 09-07-2003, 09:06 AM   #7
RKA
Member
Account #: 2062
Default =)
Others:
2001 S4 sold
2000 A4 sold
Old 09-07-2003, 10:02 AM   #8
Rack 'em Willie
Member
Account #: 34084
Default It might be your BOV. They are known to cause problems.
Rack 'em Willie is offline   Reply With Quote
Old 09-07-2003, 10:40 AM   #9
RedBlackYellow
Senior Member
Account #: 18864
Default blondes should be kept away from electrical tape, just for the record.
RedBlackYellow is offline   Reply With Quote
Old 09-07-2003, 12:10 PM   #10
1.8TQ99.5
Member
Account #: 1768
1.8TQ99.5's Avatar
Default Just reviewed my entire service history, and my by-pass valve was once replaced due to a CEL
This is a stab in the dark, of course, but on my 99.5 1.8T quattro the dealer replaced it after I complained about the CEL coming on and losing a bit of power momentarily. This was at about 50K mi.
A41.8T99.5quattrotipbrilliantblackapr91octaneh&rraces4bilsteinsbaileydv30k&nfilterawecenterventboostgauges4wheellinerRS4grillGentexNVSautodimmingmirror
1.8TQ99.5 is offline   Reply With Quote
