Go Back   AudiWorld Forums » Audi Models » Audi TT / TT-S / TT-RS » TT (Mk1) Discussion
Old 07-02-2005, 04:30 PM   #1
GorTT
Account #: 53277
Default Alright, DONE! (Seats out) >
Naturally of course, no instructions, but really easy - about an hour, maybe one and a half from start to finish, IF you have all the tools...
Rear seats out - I can post on this if need be, but not too much of a problem at all.
Evetything came really well packed - great!
Stuff all laid out:
This sending box needs to be relocated to one of the braces; only thing I actually needed to re-use any parts for, just the original mounting nuts.
Support braces in.
This piece needed cutting and a support brace (or through - bolts would work) for my FWD - no problem on quattro.
Net and bridge trim in place.
Almost done! Had to run out for supplies...
Actually, I needed to run out for an extra-deep 17mm socket to pull the seat latch pins.
The bar drops on - this connection is extremely nicely detailed - adjustable pin-bolt with slotted head mates to groove in bar end, then through bolted with concealed torx, all hidden by the escutcheon. The aluminum escutcheons slide on TIGHT - they use an o-ring for fit.
ATTENTION - this shot was taken with the screw in from the rear - actually it should be placed into the connection from the passenger's compartment side.
This is the way the car should have come, base, AND THEN maybe a $1500 add for a back seat option...
NOT the other way around. Good Miesians, those Audiots, "Less is more, and more ($) for Less..."!
Another detail:
Ha Ha! "leftover parts?" (actually, I was sent stuff that also came with other parts, so there was some duplication - the only expensive ones were the escutcheons).
That be it!
2001 FWD
BMC CDA/MOFO/Samco TIP/Boost Machine/K04 Turbo/APR K04 software/P&P exhaust mani/Tectonics DP & High-Flow Cat/Milltek Cat-Back/Forge FMIC/Forge RS/SFS DV relo/EVOheatshield/Dahlback intake mani with a little custom plumbing ;-)/Adjustable FPR/Denso IK 22's/KMD pulley/Quaife LSD/Sachs Power Clutch/Autotech LW Flywheel///H&R 20f 25r/KW V1's/VF engine mounts/Cool-looking Powder-coated Valve Cover/Braille Lightweight Battery/MassDamper elective surgery ;-)/Neuspeed 28mm Rear/BBS RE 18x8/Mich 245/35 PS2's/Defcon's/H2S Sphericals ;-)/Wilwood Superlite 13" BBK F with some decent low-temp track pads - stops on a dime (no change, but a dollar isn't what it used to be, is it?)/Precision 12" R///De-spoiled and de-antenna'd/Charactere Grille/Euro headlights/Smoked corners/Smoked side markers/Q-S Rear seat delete/Raffi Race 3/Dieselgeek Race/Vent mount Defi D Boost & Oil Temp.
GorTT is offline   Reply With Quote
Old 07-02-2005, 04:38 PM   #2
TTGram
Member
Account #: 62318
Default Your right, I like that look a lot better.
2001 225 Quattro Coupe, Aviator, Ebony, premium, Bose
Giac-X Chip, TurboX/S H25 Bov, Mofo, 4 Bar Fpr, Boost Machine, Samco intake hose, Neuspeed p-flow, Neuspeed short shift, Neuspeed dogbone bushings, VF Engineering motormount, Evoheatshield, FMIC Intercooler, FK spacers 25MM R 18MM F, Mille Miglia Uno 18x8, Dunlop SP Sport Maxx 225/40/18
Eibach Springs, Bilstein Shocks, K-Mac Rear Camber kit, Neuspeed 19mm rear swaybar
2006 A4 Quattro 2.0T, 6 speed, Dolphin Gray, Gray, Premium, Revo, sport bar
1996 A4 Quattro H&R springs, Bilstein shocks, Sport bar, 4 studded snows
TTGram is offline   Reply With Quote
Old 07-02-2005, 04:39 PM   #3
tylor
Member
Account #: 71285
Default not bad for $1500, hehe...
how much was shipping and customs? also, what are you doing with the left over collar? 0:-)
looks soooo good, man!
tylor is offline   Reply With Quote
Old 07-02-2005, 04:42 PM   #4
GorTT
Account #: 53277
Default total, including priority shipping >
$1500. And remember, to my door, complete. No aggravation, no farting around. Done.
2001 FWD
Old 07-02-2005, 04:45 PM   #5
TTschwing
AudiWorld Uber User
Account #: 13940
Default Nice Will....Looks great!
no sig
TTschwing is offline   Reply With Quote
Old 07-02-2005, 04:47 PM   #6
GorTT
Account #: 53277
Default Thx! A 2-beer mod!
2001 FWD
Old 07-02-2005, 04:53 PM   #7
ZGTT
Elder Member
Account #: 30768
Default that I like, alot! Very nice.
ZGTT is offline   Reply With Quote
Old 07-02-2005, 04:55 PM   #8
JohnLZ7W
Account #: 5201
JohnLZ7W's Avatar
Default That looks fantastic! How's the material match between the seat delete and trunk floor?
John
225QC
Aviator Grey/Ebony Cloth
Road Trip 2007 blog and gallery.
http://forums.audiworld.com/image.php?type=sigpic&userid=5201&dateline=1237605  682
"I just want to drive. I don't want to stop doing this, at all, ever" - Richard Hammond
"This is me breathing" - Martin Blank
JohnLZ7W is offline   Reply With Quote
Old 07-02-2005, 05:04 PM   #9
GorTT
Account #: 53277
Default excellent - I've kept mine in good shape - the newer is only half a shade darker >
really imperceptible.
2001 FWD
Old 07-02-2005, 05:06 PM   #10
GorTT
Account #: 53277
Default Thx - looks really 'right' in person, too; also, more functional for me.
2001 FWD
