Go Back   AudiWorld Forums » Audi Models » Audi TT / TT-S / TT-RS » TT (Mk1) Discussion
Old 06-30-2005, 09:27 PM   #1
RafaTT
Member
Account #: 62820
Default Thermostat replacement procedure..>>
Well, here it is: I'm not going to say it is simple, but it actualy is. All the procedure should take 15 to 30 minutes,
Here are the tools you will need to do this: 3/8" ratchet, as many extensions as you can get (about 24"), a 10mm short socket, 10mm box end (or long socket), flex joint , 5mm allen wrench or socket, a magnetic pickup (or needle nose pliers) and a channelock.
We will asume the engine covers are removed, NEGATIVE post of the battery removed (check radio code first!) and of course, car IS cool, no radiator pressure. Also, a clean engine bay will help a lot.
Start removing the following screws:
pull the tray up to release the hook for the oil dipstick and then separate from the manifold about 2 inches. Remove the connector on your left
put the whole assembly to the right and hold it is place (I use a ty-rap for this)
Here is the first "catch", the oil dipstick tube gets very (I mean very) brittle after a couple of years, so as it has to be removed for clearance, it may break so will need to be replaced. Be careful that when it breakes it leaves a little piece or plastic (orange)tube inside the metal part that goes to the oil pan. This has to be removed too, use an old flat screw driver with a bent tip to pull this piece. This looks like this:
Pull the orange tube up, it will do a little snap and release like this:
Now we can see where are we going: here!
With the Channel lock, remove the clamp that holds the radiator hose (center of picture above, push it towards the engine block) and separate the hose from the thermostat housing. Now, assemble the tools like this, the bottle is just a dimensional reference...
Put a rag on top of the open dipstick tube to avoid getting any coolant or debree into the oil. With the tools assembled as above, loose the top bolt that holds the t'stat housing to the block, like this:
There is enough space to work the bolt by hand:
Now let's work with the lower bolt, like this:
when it's loose you'll be able to remove the housing from the block, it will look like this:
Remove the old o-ring and pull the old t'stat from the block, if you do a quick change (quick as in normal, not lightning fast) you should loose only very little coolant. Remember that the o-ring goes on the outside, over the t'stat! Now it should look like this:
Time to reasemble. put the housing back in place, caution to not move the o-ring, the housing should be flush with the engine block. Hold everything with the top bolt, which can be worked by hand, like this:
Now, with the magnetic pickup, hold the lower bolt like this and insert it into the lower hole on the housing:
Bolt towards the housing:
Bolt onthe housing:
Now, use the short 10mm socket and the long extensions again to secure the lower bolt in place, then do the top bolt. Reattach the coolant hose. Now, insert the oil dipstick tube back into the metal base, remember that the square part on the side is to be reinserted on the manifold base later. Release the ty-rap (if used) that holds the tray that we moved to the right and put it back into it's position, on the manifold. Remeber to secure the oil dipstick tube into it's slot and reattach the connector we removed from the left side of the tray.. Reattach the 2 10mm nuts and the 2 5mm allen screws.
Open the coolant reservoir and top it off with coolant or water, depending on how much you did loose. Remember, that the OEM coolant, PENTOSIN G12 (Pink color), DOES NOT MIX WITH OTHER COOLANTS. If you do, it wil gel and create a mess.
After filling the coolant, reattach the battery and turn on the car, leave it idling for 5 minutes and keep an eye on the coolant level, as it may empty the reservoir filling the bubbles on the block. After the engine has idled for 10 to 15 minutes, check for leaks and go for a test drive.
Hope this helps!
Enjoy!
The Lab.
TT FAQ's
RafaTT is offline   Reply With Quote
Old 06-30-2005, 09:41 PM   #2
andrew.tt
Member
Account #: 50780
Default great write-up >>
did you actually break your dipstick at some point? do you have the part number for the 180 handy? i bought one but it looks like it's for a 225. so if anyone needs one for a 225.. let me know.
Check out the APR stage 3 dyno results
andrew.tt is offline   Reply With Quote
Old 06-30-2005, 09:49 PM   #3
RafaTT
Member
Account #: 62820
Default Thanks. Didn't break this time, but whe did TB it desintegrated..>>
Same as with SunSeTT's car, it shredded to pieces. I think it fits both, looks like it is the same part. The ECS PN is the same for both 180 and 225 (PN#1506).
TT FAQ's
Old 06-30-2005, 09:51 PM   #4
Blue TTop
Account #: 46497
Default Excellent! This one is worth a bookmark.
My Fotki
Blue TTop is offline   Reply With Quote
Old 06-30-2005, 09:55 PM   #5
TTuned
Member
Account #: 48863
Default Nice writeup..Have any Timing Belt steps w/photos?
Events:
2005 TT-East (TN)
2005 WaterFest (NJ)
2005 TT-Mid West (IN)
2007 TT-East (SC)
2007 WaterFest (NJ)
2008 QDM (NC)
2008 TT-East (WV)
and a few ModShack pilgrimages!
My toyz:
2001 - Audi TT Quattro Roadster
2006 - Lexus IS350
2007 - Hummer H3 (sold)
TTuned is offline   Reply With Quote
Old 06-30-2005, 10:18 PM   #6
RafaTT
Member
Account #: 62820
Default Thanks!. No, I don't have any TB procedure documented ..>>
but there is a fellow TTer that did an awesome write up, I don't remember who, but I'll find it. It was very well documented. I have done it but no pics taken.
TT FAQ's
Old 06-30-2005, 11:50 PM   #7
kgorman
Junior Member
Account #: 86187
Default Ah yes->grolsch!
Kenny Gorman
ACGG
2006 A6 Avant 3.2 Atlas
1989 Porsche 911 #341
2006 Ford Superduty 6.0L Diesel 4x4
2003 Kawasaki KLX300r
'Vorsprung durch Technik'
kgorman is offline   Reply With Quote
Old 07-01-2005, 03:16 AM   #8
CGATT04
New Member
Account #: 74560
Default Looks like I just got a weekend project. . .
thanks!
2001 Audi TT Quattro Coupe - Lake Silver / Ebony
Mods:
- Smoked side markers
- Front euro plate
- TT Valvestems
- Euro mirrors
- Hardwired V1
- Bipes Mp3 adaptor
- Zimmerman X-drilled rotors
- Porterfield Pads
- Stratmosphere armrest
- Pirrelli P-Zero Nero M&S
- K&N Air Filter
- Aero wiper kit
- 1 Happy driver.
CGATT04 is offline   Reply With Quote
Old 07-01-2005, 03:24 AM   #9
hAUDIni
Member
Account #: 35712
Default hmmm, you and me both
hAUDIni is offline   Reply With Quote
Old 07-01-2005, 03:50 AM   #10
ITALSKIER
Member
Account #: 43750
Default raf,you are da man....great piece........
2001 225 TTCQ MODS: /H&R SP.Springs/Bilstein Sp/Bailey DV/RH Cuprad Wheels18x8.5&18x10/25mm H&Rspacers(adapters)F>R/Ziex-Z 912 Falken's on:235/40/18-265/35/18/WINTER WEAR:225.45.17Nokian WR's on Stock 17 5 Spokes
/Schwing's TTDA/GIAC-X Chip/Escort8500/Neuspeed Short Shift kit/Rear Red painted Calipers,Audi Rings/Bird Automotive Armrest/19mmRear Neuspeed Swaybar/Rear Harness Bar/1/2 KMAC for rear/Forge Hi-Flow Exhaust/Raffi Knob(Race -2)/Samco Intake Hose/IK-22 Densos/Descreened,Devaned/Mantis,with 2VDO Gauges Oil Temp and Volt/Dogbones/Defi D Boost Gauge.Pillar Pod/3.2 Rear Valence(modified)/4Bar FPR,MOFO/Telson(FG)3.2 Spoiler/Wilwood 13"BBK,Red 4 Piston Forged Calipers/Dr. SchwingsBoost Machine/Hella Horns/Quattro Sport Gl.Box Emblem/ECS tuning Poly Control Arm Bushings/EVO Phenolic Intake Manifold Gasket/Optima Redtop/Revo 93 on an xtra ECU/passenger side EURO Mirror/Mark 1 Arms/Rear cross drilled Zimmermans/Street Concepts 3 Piece Front Splitter w CF center/Riso Carbon Fiber Door handles/42DD Dwn Pipe/MT-90 TrannyOil/22mm Nuespeed front swaybar/Alcantara E Brake handle/Tyrolsport UG SMIC's(2)/http://us.fotolia.com/p/51995?order=nb_downloads&offset=96
ITALSKIER is offline   Reply With Quote
Tags
2002, 32, 90, a8, audi, audiworld, change, diy, location, repair, replacement, themostat, thermostat, tt, v6
