Go Back   AudiWorld Forums » Audi Models » Audi TT / TT-S / TT-RS » TT (Mk1) Discussion
Old 05-25-2005, 06:06 AM   #11
YosemyTT
Senior Member
Account #: 3125
Default Nice job!
Mark B.
Click for my radio show and blog ->
YosemyTT is offline   Reply With Quote
Old 05-25-2005, 06:35 AM   #12
BluHeaven
Member
Account #: 56172
BluHeaven's Avatar
Default yay!!!!!!!! now I know how much tuck I'll have
this helps me a bunch!!!
http://forums.audiworld.com/image.php?type=sigpic&userid=56172&dateline=123760  4879
2003 Ocean/Vanilla 225QC
Milltek - Revo - Hyperboost - K&N - Samco - Mobil 1 - SSR - Bridgestone - OSIR - Dieselgeek SS - AWE - Omori - Modshack Stage II - Zaino - AutoAesthetics - 3.2 - Seat LCR - Inpro - H&R - Kmac - Defcon1 - ECS - Forge - Powerflex
My BluHeaven: The Photos | The Blog
Screensavers: 2006 | 2004 | 2003
BluHeaven is offline   Reply With Quote
Old 05-25-2005, 06:56 AM   #13
emule
New Member
Account #: 67082
Default Re: Wheel spacer size? Offset? Confused? Use my offset / spacer calculator!
Suggest you allow decimals in input box for offset
e.g. ECS offers 17.5 mm thick spacers
Thanks,
emule is offline   Reply With Quote
Old 05-25-2005, 07:12 AM   #14
meem
Elder Member
Account #: 1898
Default posted this one yesterday: 8.5ET20 front ...
looks perfect from this angle, but from the back it looks a touch too aggressive:
i should have a pic of 8.5ET16 rear next week when my hre's arrive -- but that's only a millimeter so that's probably not too big a deal.
i'd update the offset calculator to consider 8.5ET22 and 8.5ET16 to be "flush", and once you do that i'll update my original post to be consistent, and i'll also toss in the second pic i posted here.
meem || amulet red 2001 tt quattro coupe :: imola red 2003.5 m3 coupe
meem is offline   Reply With Quote
Old 05-25-2005, 07:37 AM   #15
ePuFFy
Member
Account #: 78971
Default Good job man! I didn't know I was poking that much! haha
01 225 TTR | 04 E55 AMG | 02 G500
ePuFFy is offline   Reply With Quote
Old 05-25-2005, 07:44 AM   #16
shifTT
Junior Member
Account #: 75098
Default ok page updated
shifTT is offline   Reply With Quote
Old 05-25-2005, 07:55 AM   #17
ePuFFy
Member
Account #: 78971
Default Hijack: Hey Meem... according to the calculator...
I need 13MM in front, whereas I am currently running 15MM. Do you think that 2MM would cause my rubbing problems to go away (pull the wheel inside the wheel well enough)?
Also, do you remember back when I have the Projectzwo P2 wheels, you had calculated that my wheel might be rubbing on the inside on the coilover adjustment shaft thing, and indeed I was. Will I have the same problem as that if I change to the 13MM spacers?
Old 05-25-2005, 08:29 AM   #18
meem
Elder Member
Account #: 1898
Default your wheels are 8.5" wide, right?
if so, backing off to a 13mm spacer should be fine (if you can find one -- common sizes are 8, 10, 12, and 15).
backing it off 2mm may not fix your rubbing problems but that's where i'd start.
Old 05-25-2005, 08:33 AM   #19
meem
Elder Member
Account #: 1898
Default calculator looks good but pic is a lie now ...
how about including both pics and saying something like:
The photos on the right show his 8.5" wide BBS LMs with ET20 in front and ET17 in the rear. Since then, additional data collecting has shown ET22 front, ET16 rear to be a "safe" FLUSH setup, with few rubbing problems even on aggressively lowered cars.
<p>
This setup will be considered FLUSH to fenders and will be used as a baseline for all calculations below. The stock 7.5" wheel with ET32 is also given as a comparision.
Old 05-25-2005, 09:02 AM   #20
dirrTTy
Junior Member
Account #: 53167
Default That's Dope!>>>
But isn't Meem using spacers?
dirrTTy is offline   Reply With Quote
Tags
35, audi, calculator, changing, determining, forum, offset, offsets, size, sizes, spacer, spacers, tt, wheel, wheels
