Go Back   AudiWorld Forums » Audi Models » Audi TT / TT-S / TT-RS » TT (Mk1) Discussion
Old 05-24-2005, 10:53 PM   #1
shifTT
Junior Member
Account #: 75098
Default Wheel spacer size? Offset? Confused? Use my offset / spacer calculator!
I've created a wheel spacer / offset calculator to help you figure out what size spacers to use with a given wheel. You can find it here.
meem I hope you don't mind me linking to your pic. Any comments, suggestions, error corrections welcome. Hope you find it useful.
shifTT is offline   Reply With Quote
Old 05-24-2005, 11:13 PM   #2
TTear
Member
Account #: 54811
Default Correction : FWD's have an 8mm wider rear track, thus wheels are exposed 4mm more each.
Great job nevertheless! I'm sure everyone will find it very helpful.
TTear is offline   Reply With Quote
Old 05-24-2005, 11:21 PM   #3
shifTT
Junior Member
Account #: 75098
Default corrected... thought it was 6mm...
Old 05-24-2005, 11:35 PM   #4
mny
Junior Member
Account #: 2068
Default Very useful! Thanks! :-)
mny is offline   Reply With Quote
Old 05-24-2005, 11:48 PM   #5
meem
Elder Member
Account #: 1898
Default excellent! :-) in the year or so since that post i've ...
adjusted my personal preferences a bit such that i now like 8.5ET22 front, 8.5ET16 rear -- and ET20 front is probably actually flush though it will rub a bit if lowered aggressively (whereas ET25 is more safe). so maybe we can revise things just a bit? i'm happy to revise my original post a bit to avoid confusion.
let me know how you want to proceed.
meem || amulet red 2001 tt quattro coupe :: imola red 2003.5 m3 coupe
meem is offline   Reply With Quote
Old 05-25-2005, 02:00 AM   #6
jtntsfr
Junior Member
Account #: 57617
Default Wow, this is awesome. Thank you!!!
jtntsfr is offline   Reply With Quote
Old 05-25-2005, 03:52 AM   #7
SpoiledHeeb
Member
Account #: 52707
Default That is really helpful... isn't the stock wheel 7.5 ?
SpoiledHeeb is offline   Reply With Quote
Old 05-25-2005, 05:41 AM   #8
kodeTT
Elder Member
Account #: 23258
Default that's excellent work! should solve a lot of issues here!
Bill
'01 Atlas Gray Tip allroad : winter package : Dahlback chip : H-Sport sway bars
'01 225 TTQC : Brilliant Black TT : Ebony : Premium : Heated Seats : Bose
—| Engine |—
:: Dahlback chip
:: Dahlback intake manifold
:: 42 Draft Designs 3" downpipe with test pipe
:: EVOshield intake gasket
:: Bosch Super Copper spark plugs
:: N75 K valve
:: Modshack VTDA
:: Modshack MoFo v.2 with Tyrol adjustable FPR
:: Forge SPLTR DV :: relocated
:: O.CT FMIC
:: Samco hoses [intake, upper and lower]
:: VF Engineering side motor and pendulum mounts
:: Custom 3" Sheep/Mufflex exhaust
:: Optima YellowTop battery
—| Suspension/Drivetrain |—
:: KW variant 3 coilovers : 8012 spring mod
:: DieselGeek Sigma 6 short shifter upgrade
:: DEFCON3 with H2S rear spherical bearings
:: CPT control arms (lower) | Forge tiebars (upper)
:: Haldex race controller
:: H-Sport front and rear adjustable sway bars
—| Exterior |—
:: Blindspot "Euro" mirrors
:: Bosch Aerotwin wipers
:: OEM roof rack [Thule bike rack]
:: Audi OEM 3.2 bumper
:: Audi OEM Quattro Sport Phantom Black grilles
:: RISO smoke clear corners : o-gas : zero v.3
:: RISO CF arc
:: Smoked Euro tail lights <Jon's Tinted Tails>
:: Black sidemarkers <Jon's Tinted Tails>
:: Wilwood 4-piston, 13" rotor BBK
:: Summer Sandals [Toyo T-1Rs on 19" BBS LMs ET25]
:: Winter Boots [Nokian WR on 19" LMs]
:: ECS 12.1" rear cross drilled slotted rotors
:: Hawk HPS brake pads
:: StopTech SS brake lines
—| Interior |—
:: ModShack gadgeTT v.2
:: AWE Tuning boost gauge
:: Hardwired Garmin nuvi 360 with gadgeTT2
:: Hardwired V1
:: PIAA H3 Super Plasma foglight and switch mod
:: ice>Link v.1.1 : iPod interface
:: Audi RS4 perforated steering wheel
:: Audi OEM TT winter mats
:: Audi OEM S-Line all aluminum shift knob
:: RISO O-gas
:: Britax Starriser seat in rear
—| yard sale |—
:: KMD lightweight crank pulley
—| Future Mods |—
:: Euro dash
kodeTT is offline   Reply With Quote
Old 05-25-2005, 05:42 AM   #9
shifTT
Junior Member
Account #: 75098
Default I had linked to your old post since you had the photo of your offset
I thought it would be helpful to have a photo to go with the numbers. I can link the page to your post above with your new preference. Do you have a photo that shows these new offsets?
Old 05-25-2005, 05:48 AM   #10
shifTT
Junior Member
Account #: 75098
Default oops... you're right... page updated
Tags
35, audi, calculator, changing, determining, forum, offset, offsets, size, sizes, spacer, spacers, tt, wheel, wheels
