| Register | Pictureposter | Classifieds | FAQ | Members List | Search | Today's Posts | Mark Forums Read | Garage | My Recent Topics | Dealer Listings |
| Notices |
Thread Tools | Search this Thread | Display Modes |
#1 |
New Member
Account #: 42710
I am posting this since I have not seen this solution posted here or elsewhere. Anyone know how I can submit this for the TT FAQ or tech resource?
My rear shelf was driving me nuts, not because it rattled, but because it squeaked every time I hit a bump. Following the suggestions in the FAQ and in older posts, I cracked open the shelf. Here is what I did once it was open that resolved the squeaking: 1. There are two pieces, a solid thick frame that contains the connections to the car, and a flimsy shell, to which the fabric is attached. 2. Following previous recommendations, I removed the two metal rods on opposing sides of the solid portion of the shelf, since these would squeak when I twisted the shelf. I applied clear caulk inside the slots, then re-inserted the rods. For good measure, I also popped out the side mounts, filled their slots with caulk, and put the side mounts back into place. 3. Then I discovered the true cause of the squeak. It appears that the manufacturing process involves stretching the fabric over posts mounted in the shell. There are cavities in the solid frame that correspond to these posts. Hot wax or plastic is poured over the posts. While the plastic is still hot, the shelf is assembled, so that the hot plastic also fills in the cavities and acts as additional "glue" for the frame. Over time, if the seal between the plastic and the cavity breaks, then plastic rubs against the cavity, which is the true source of the squeaking! Now imagine 10-20 of these little squeak sources, and you've got a major source of irritation. BTW, when these plastic portions break completely free from the cavities and posts, they are what cause the previously reported rattle. 4. To resolve the squeak, I removed and discarded all plastic pieces that had broken free from the mounts on the shell. I then placed the fabric over the posts and used modeling glue to secure the fabric in place. Note that I did not do all the posts at once, as the fabric would pop loose under tension and the whole thing would become maddeningly frustrating. Instead I just did a few at a time and let them dry before moving on. When the fabric was completely attached dry, I applied an extra dollop of glue at each point. 5. Before final assembly, I whipped out my caulk gun and placed a dollop of caulk on every cavity and vertical protrusion on the solid frame. Anything that could rub against the top shell when the shelf vibrated received a touch of caulk. 6. As has been mentioned elsewhere, prior to assembling the halves, I applied clear caulk around the entire edge of the solid frame, just beneath the lip snaps together against the upper shell. 7. Before anything had a chance to dry, I snapped the two halves together, and then I let it dry overnight. Viola'! No more squeaking! |
#2 |
Member
Account #: 5297
all with white lithium grease as someone else here had suggested.
Granted I got some grease on the outside of the plastic that I couldn't clean off, but no more squeaks or major rattles. Sometimes I hear a "tuhh tuhh tuhh" when I got over large bumps... I think that's due to not having the metal rods in there anymore: the plastic shakes too much. In any case, it's always quiet except for large bumps where I'd expect any car to make some noises.
![]() Milltek Non-Res - DieselGeek Race SS - V1 - XM SkyFi - AA Sphere-R-2 Euro Mirrors - Smoked/LED Sides - Becart Rear Frame - Blue Door LEDs Winter Mode: 16" Dunlop WinterSport M2 / Sport Edition Fox 2 Newest mod: Custom screwdriver-drilled-out door locks from the Jersey Gardens Mall |
#3 |
New Member
Account #: 42710
But I'm an engineer, so I like to make things complicated.
#4 |
New Member
Account #: 40151
What's the deal? I had a unique third gear grind and the unique dealer put a brand new transmission in.
#5 |
New Member
Account #: 40151
doesn't squeek. Problem solved.
#6 |
Member
Account #: 5297
#7 |
New Member
Account #: 42710
But it makes me a little different from most people here, without spending lots of money on mods!
In my case, the dealer replaced the 1-2 and 2-3 gear synchros. Problem solved. |
| Tags |
| 90, a6, audi, bumps, c5, coupe, door, fabric, glue, hit, panel, q5, rear, shelf, squeak, squeaks, squeaky, squeek, tt |
Previous Thread
Next Thread
| Display Modes | |
Linear Mode
