Go Back   AudiWorld Forums » Audi Models » Audi A4 » A4 (B5 Platform) Discussion
Old 07-07-2003, 08:46 AM   #1
TimO'Brien
Account #: 21070
Default DIY Timing Belt Change Success!!
A big thanks to Andy_TN and Ben Hardt for their cook book style write-ups! Review:
I didn't have any plans this past weekend so it was about time that I got to my timing belt (62k miles). I was pretty nervous doing this myself but all in all, it was extremely (and surprisingly) easy. It just took a long time ~ 8hrs total for my father, a friend, and I to do it. (None of us had ever done it before either) I used the Bentley manual as reference as well as extremely well-done audiworld write-ups. The thing I was really nervous about was the actual timing belt exchange -- not messing up the timing but all I needed to do was hand crank the car to TDC and then mark the crank pulley. Neither of them moved so I had no problem. The whole thing went off without a snag except for one slight error but I found was very fixable. I ended up pulling the pin on the tensioner too soon because I realized that I needed to remove another pulley (that the timing belt went around) to get to my water pump/thermostat. So I experimented on recompressing the old tensioner and re-installing the pin in a vice. Well, it worked so we took the new tensioner back out, compressed it, and then proceeded to the water pump/thermostat. So it IS possible to recompress the tensioner. I took a lot of digital pix just for my sake of putting things back together correctly. Everything went as expected. I did need to run out and get a universal joint for my socket wrench but that's the only extra tool I needed. Total: ~$400. Saved ~$700. The list of what I replaced:
- Timing belt, tensioner, roller, tensioner pulley
- Water pump impeller
- Thermostat
- All "exterior" belts -- A/C belt, Serpentine belt, and water pump/power steering belt.
- Spark plugs
- G012 coolant
- K&N recharge
- pollen filter change
- APR Snub Mount
A few scarry Pics:
99.5 A4 1.8t QM
A few mods...
TimO'Brien is offline   Reply With Quote
Old 07-07-2003, 08:49 AM   #2
paul_858
Member
Account #: 18752
Default nice work man! :)
paul_858 is offline   Reply With Quote
Old 07-07-2003, 08:51 AM   #3
Andy_FL
Account #: 12690
Default Cool
Glad it went off without a hitch. First time I've heard my write-up likened to a cook book recipe ;-)
Andy
Andy_FL is offline   Reply With Quote
Old 07-07-2003, 08:53 AM   #4
paul_858
Member
Account #: 18752
Default personally i hate cook books, i always fail to follow the directions properly... now... color by #,
that's the stuff.
Old 07-07-2003, 08:57 AM   #5
TimO'Brien
Account #: 21070
Default following directions is over-rated...
I ended up pulling the pin on the "granade" too early just to stir things up. -- it was going too well.. hehe
99.5 A4 1.8t QM
A few mods...
Old 07-07-2003, 09:16 AM   #6
BSCA4
Senior Member
Account #: 34916
Default I though you would tempted on the KO-4. It is there.
Cheer,
Ryan
1.8TM traded!!! Future 1.8TAQMS (I WILL BE BACK)
BSCA4 is offline   Reply With Quote
Old 07-07-2003, 09:55 AM   #7
TimO'Brien
Account #: 21070
Default it'd be nice to go stage III but it's too much $$$ right now.
99.5 A4 1.8t QM
A few mods...
Old 07-07-2003, 10:00 AM   #8
2tuŽbos1mission
Elder Member
Account #: 40304
Default nice work!!
2002 Subaru WRX
2002 A4 3.0 6spd
2004 Allroad Tip
2tuŽbos1mission is offline   Reply With Quote
Old 07-07-2003, 10:26 AM   #9
CC Rider
Account #: 2093
CC Rider's Avatar
Default You'd better stick to connect the dots.
2009 VW CC
CC Rider is offline   Reply With Quote
Old 07-07-2003, 12:27 PM   #10
LaserRed_OC
Account #: 38587
Default I must say, that is one spotless.......garage?
Gonna be doing my T-belt sometime this week too. Taking it to a shop cause I suck. Unless someone wants to help in OC? Free beer and $$$.
LaserRed_OC is offline   Reply With Quote
Tags
a4, audi, belt, diy, timing
