Go Back   AudiWorld Forums » Audi Models » Audi TT / TT-S / TT-RS » TT (Mk1) Discussion
Old 06-10-2002, 08:25 AM   #1
TTschwing
AudiWorld Uber User
Account #: 13940
Default MOD SHACK MOD: Boost improvements for $.16 cents (DV Tuning!).........>>
One of the things you discover as you add more mods and instrumentation to this car is sometimes things don't work the way you assume they should. Take Boost for instance. Adding the boost gauge gave me a window into how, when and how much boost was developing over a variety of condidtions. I was surprised how much throttle was required to put the car "on boost" and how soon boost dropped out with slight relaxation of the pedal. Hmmm....Maybe time to grease the DV (Forge 006, Green spring, aluminum, piston). Upon dissassembly everything looked fine. Began to think how and why the piston operates. Boost pressure bleed, spring tension and vacume affect whether the piston remains seated (and holds boost) or not (and bleeds boost). I figured increasing the spring tension would keep the valve seated longer. Off to Lowes for some washers (shims). I placed 2 washers (35mmx2.5mm) into the piston for a total of a 5mm shim, inserted the spring and bolted it back together. Guess what?
Boost now comes on with slight throttle tip in, holds longer, and is more linear in it's delivery. Not a bad improvement for 16 cents! One you can feel and see on the Gauge.
Here's the DV with shims (er....washers). Just slip them into the piston, insert spring, and bolt back together.
The washers fit the older Blue plastic piston as well:
Current set-up with APR Chip and FMIC is showing a peak of 18PSI (1.24 BAR) on the gauge. It pulls strongly into redline in every gear with no power drop-offs. All in all, a pretty good boost for the buck...
Steve
no sig
TTschwing is offline   Reply With Quote
Old 06-10-2002, 08:47 AM   #2
joe@vwvortex
Member
Account #: 4599
joe@vwvortex's Avatar
Default Run a Vag-Com log of Block 115 - it's your boost in mBar - its also a good way to test
for those without a boost gauge.
joe@vwvortex is offline   Reply With Quote
Old 06-10-2002, 08:51 AM   #3
GoKart3
Member
Account #: 25185
Default Hmmmm..... very interesting.
AW.... DIAF.
GoKart3 is offline   Reply With Quote
Old 06-10-2002, 08:52 AM   #4
hoTTub
Member
Account #: 11019
Default Steve, isn't the green spring a higher tension? Maybe you should
try that as well.
Do you have the 006 (big)or the 007p(small) ?
hoTTub is offline   Reply With Quote
Old 06-10-2002, 08:53 AM   #5
Rennen
Elder Member
Account #: 8364
Default Where, exactly, do you place the shims? At the "back" of the spring or on the piston end?
Rennen is offline   Reply With Quote
Old 06-10-2002, 08:59 AM   #6
Lightweight-USPowah
Account #: 25882
Default Awesome steve.. Could you do some vag testing for the lazy people?`
Id love to see some data backing up your findings.. Should have never told people about this, you could have took another companys design, changed a thing or 2, add the spacers, call it a day and then market it as your own DV.. When you say power drop offs, are you talking about the boost drop at 6200ish rpms?? Im still running the stock chip and Ive noticed the boost drops off at 6200rpms (about).. It actually starts to increase at about 5800 then peaks, then at 61 or 6200rpms it drops big time..
5.7 Liters of Forced American Muscle - 2 + 8 = 715
6.0 Liters of American AWDrivin Muscle
599ccs of Japanese Track Samurai (ninja style)
http://public.fotki.com/johnjacobjingleheimer/
http://images12.fotki.com/v213/photos/3/30429/123720/TimesSquareLegendLives-vi.jpg
Lightweight-USPowah is offline   Reply With Quote
Old 06-10-2002, 09:02 AM   #7
JustJeff
Elder Member
Account #: 2847
Default Wow, after MichaelTT's post ealier regarding his DV, and thoughts that mine might be sticking...
I'm off to get these washers, and dis-assemble my Forge.
I'll report back later.
JustJeff is offline   Reply With Quote
Old 06-10-2002, 09:02 AM   #8
Jason Chen
Elder Member
Account #: 4297
Default The drops I get is.......
Boost spike 1.2-1.3bar
Settles 1 bar
5500-6k+ drops down to almost .6 bar depending on weather.
Sigless
Jason Chen is offline   Reply With Quote
Old 06-10-2002, 09:04 AM   #9
Lightweight-USPowah
Account #: 25882
Default wow.. Mine doesn't drop until Im above 6200 rpms .. you have a stock 225?
Old 06-10-2002, 09:05 AM   #10
CJ S4 (aka CJ TT)
New Member
Account #: 36009
Default Do washers void the warranty? lol
CJ S4 (aka CJ TT) is offline   Reply With Quote
