Go Back   AudiWorld Forums » Audi Models » Audi TT / TT-S / TT-RS » TT (Mk1) Discussion
Old 11-06-2001, 08:21 AM   #11
smallTTs
Member
Account #: 4314
Default Yes. First used on small MK-82 (500 lb) bombs to cause the detonation at ground level.(revised)
The BLU-82 (BLU = "Bomb, Live Unit") or Commando Vault is the 15000 lb monster which is extracted from the back door of a C-130 (called Combat Talon in the Gulf War) perhaps aided by a drouge parachute...it comes out tailend first...then falls to the ground exploding at ground level when the instantaneous (no delay)fuse on a 38 inch extension first touches.
The effect is blast (1000psi!) and shock. It pulverizes anything in about a 600 ft radius, (it looked like a plowed and disked field in the jungle, and was used to make big LZ's or Landing Zones for choppers) and produces a mushroom cloud reminicent of a tiny nuke(there is "only" about 6 tons of explosive, while a small nuke is equivalent 10,000 and up tons).
It's NOT like napalm which "sucks" up the oxygen but doesn't produce much blast. The BLU-82 will ring your bell from a couple of miles away. Within the central blast area virtually nothing survives. Probably a underground concrete bunker would, but that's not the target.
I was airborne a few miles from a detonation in Southeast Asia long ago, and could feel the shock wave. As a matter of fact, in the humid jungle, you could see the shock wave travel out from the blast as the moisture condensed.
That is one awe-inspiring weapon.
My $.02.
_______________________________________
With Age comes Wisdom...
but sometimes Age shows up alone.
Jon
smallTTs
180TTQ BB
C5 (UNRED)
Impala SS (KLR WHL)
smallTTs is offline   Reply With Quote
Old 11-06-2001, 09:24 AM   #12
smallTTs
Member
Account #: 4314
Default Nope. Fuel Air Explosives (FAE) generally don't create the huge
blast (overpressure) that the BLU-82 does.
There was a 2000 lb FAE (BLU-96) however.
The link is for the BLU-82, as posted above.
This one is for the FEA bombs.
http://www.fas.org/man/dod-101/sys/dumb/cbu-72.htm
No offense intended.
Jon
smallTTs
180TTQ BB
C5 (UNRED)
Impala SS (KLR WHL)
Old 11-06-2001, 10:56 AM   #13
0TT0 BURNER
Junior Member
Account #: 20566
Default So, what's the target? Defoliant for LZ's, minefield detonation, or Taliban garrisons?Just curious.
Tradition & Technology
0TT0 BURNER is offline   Reply With Quote
Old 11-06-2001, 11:53 AM   #14
smallTTs
Member
Account #: 4314
Default Taliban garrisons would be my guess. Anything above ground would be vulnerable IMO.
If nothing else, plunking down a few "Bluey" 82's should have a pretty good demoralizing effect on the nearby survivors. Bet they duck the next time they see a C-130 fly over!
As I recall, the C-130 zooms up a couple hundred feet as the bomb leaves...sorta like having 65-70 paratroopers leave in 1/10 of a second!
My $.02
Jon
smallTTs
180TTQ BB
C5 (UNRED)
Impala SS (KLR WHL)
Old 11-06-2001, 12:54 PM   #15
0TT0 BURNER
Junior Member
Account #: 20566
Default If that's the case, they will be moving in small groups now. Divide and conquer. ;-)
