Go Back   AudiWorld Forums » Audi Models » Audi A8 / S8 » A8 / S8 (D2 Platform) Discussion
Old 05-30-2003, 01:28 AM   #1
Matthew Baldry
New Member
Account #: 49583
Default Immobilizzer Fault
Had a problem with my A8 yesterday, the car would start then cut out and the immobilizer symbol was flahing on the dashboard. The fault sorted itself out so I got home and plugged vag-com in. I got the following fault code:
Address 01
Controller 4D0 907 557 J
Component 4,2L V8/4V MOTR AT D01
Coding 04263
Shop# WSC 00000
1 Fault found
17978 Engine start blocked by immobilizer
P1570-35-10 Intermittent
Readiness N/A
Can anyone help, I have now cleared the code but how do I go about fixing the problem?
Cheers
Matthew
Matthew Baldry is offline   Reply With Quote
Old 11-08-2003, 07:44 AM   #2
MackTDI
New Member
Account #: 65025
Default Re: Immobilizzer Fault - Did you find an answer?
I've also hit the same problem. Please contact me if you've had any further troubles after clearing the code.
Many thanks,
Mack
MackTDI is offline   Reply With Quote
