| Register | Pictureposter | Classifieds | FAQ | Members List | Search | Today's Posts | Mark Forums Read | Garage | My Recent Topics | Dealer Listings |
| Notices |
Thread Tools | Search this Thread | Display Modes |
#1 |
New Member
Account #: 89885
Hello,
I have searched this forum but didn't find an answer to my question. I have a 2002 A6 4.2. The econ light on the climate control will come on and stay on about 5 minutes into driving, meaning I have no A/C. I had the car VAG'd today and here is the fault: 00819 - High Pressure Sensor (G65) 29-00 - Short to Ground I found the following article on Ross-Tech: http://wiki.ross-tech.com/index.php/00819 The recommended solutions are: 00819 - High Pressure Sensor (G65): Signal too Low Possible Symptoms * Climate Control stuck in ECON Mode Possible Causes * Insufficient Refrigerant Pressure * Wiring/Connectors from/to High Pressure Sensor (G65) faulty * High Pressure Sensor (G65) faulty Possible Solutions * Check Refrigerant Pressure o Check Measuring Value Blocks (MVB) * Check Wiring/Connectors from/to High Pressure Sensor (G65) * Check High Pressure Sensor (G65) My question is: Should I have the system checked for low refrigerant before replacing the sensor? The 29-00 Short to ground from the fault code makes me think the actual sensor may be bad. Has anyone had this same code before? Any suggestions? Thanks in advance. |
#2 |
Tech Guru
![]() Join Date: Oct 2002
4Driver4 "Never give up the throttle until the bitter end." -RC 1990 Coupe Q 1999 A6 Sedan Q 2.8 2000 A4 Avant Q 2.8 1995 Mazda Miata: the anti-Audi 1999 Mazda Miata: Track beotch 1999 Chevy Suburban: the anti-earth :-( 1990 Nissan Pickup: Snow plow/garbage hauler 1981 VW Scirocco: the car I shouldn't own |
| Tags |
| 00819, 2002, 2004, a4, ac, audi, code, econ, g65, high, light, low, pressure, sensor, signal, stays |
Previous Thread
Next Thread
| Display Modes | |
Linear Mode
