Go Back   AudiWorld Forums » Audi Models » Audi A6 / S6 / RS 6 » A6 / S6 (C5 Platform) Discussion
Old 02-28-2008, 06:12 AM   #1
5speed6 v.2
Member
Account #: 44347
Default Part VIII - Disappearing amp rack install
I wanted to do something different with the amp rack I was going to install.
My goal was:
- not to lose as much space as possible.
- being able to access the amps for tuning or servicing purposes.
-stealth, non-exposed installation.
After much thought and looking at different materials, I decided on using sliding trays sold for computer server racks.
I mounted two of the sliding trays together, side by side and added heavy duty "L" brackets at the corners and in the middle:
Side view of the trays:
View of the trays operating independently:
I test fit the amps for best position with regards to cable, fuse access & front panel access..
2 Alpine amps test fitted:
a/d/s 8 channel amp test fitted:
I had to cut off a 1/4" lip on one side of both trays for the amps to sit properly.
Action shot, using air powered "whizz wheel":
One Alpine amp is mounted and protected in the foreground.
I then mounted the trays under the rear deck, secured with #10 machine screws, lock washers and nuts.
Trays installed under rear deck:
Drivers side tray slid outward:
Passenger side tray slid outward:
Both trays slid outward:
After this, LOTS of wiring followed, for the power, speakers and signal. After all the wiring was loomed up and secured, all the trunk panels were replaced.
I then made a carboard template of the area in front of the amp trays. It is actaully quite curved at the top. Once I had a nice fit, I traced it onto 1/4" medium-density fiberboard (mdf). After cutting out the wood, belt sanding, and test fitting, I applied spray glue and covered it with a pretty close matching carpet.
Here is the panel installed.
It is tightly press-fit at the sides and held in by a single securing fastener in the middle.
Close up of the fastener(attached to the center bracket):
I believe I have succeeded in meeting the criteria of my goal for this project.
Thanks for reading
5speed6  v.2 is offline   Reply With Quote
Old 02-28-2008, 06:18 AM   #2
Kris Hansen
Chief of Goat control
Account #: 20
Kris Hansen's Avatar
Send a message via MSN to Kris Hansen
Default Nice!!!!!!! How are they locked in place, so when you launch hard, they don't slide back?
Kris Hansen is offline   Reply With Quote
Old 02-28-2008, 06:19 AM   #3
EuroVWGTi
Junior Member
Account #: 66320
EuroVWGTi's Avatar
Send a message via AIM to EuroVWGTi Send a message via MSN to EuroVWGTi Send a message via Yahoo to EuroVWGTi
Default WOW thats hot bro......
when can you do mine :P
2002 C5 A6 2.7T Ming Blue Exterior/Cream leather interior Audi Navigation RNS-E, Bose Premium Sound (10 speaker plus sub system), Cold weather Package, 82,500 Miles
Performance Mods:Forge 007P Diverter valves, Hotchkis HSport swaybar kit, Audi RS6 18s, RS6 Grills, Milltek Exhaust system, Kenwood eXcelon DNX8120 Radio/Nav, Tints (35% rear window & back doors, 25% front 2 doors
Adaptions"01032" transmission code - "15981" door lock code
What the warranty covered at 80,200 when I bought it:
New turbo setup, new cam seals, valve cover seal, front tranny seal, Secondary air pump, new tcm and harness, new electric secondary fan, transmission redone, new climate control fan. 2 visits, 3 weeks, cost me 2 deductables totaling $100. gotta love the CPO
What I have done so far:
Just did my Timing Belt service at exactly 84600 miles.
To Do List:APR chip, PSS9s, RS6 brushed aluminum mirror housings, RS6 spoiler, Tinted Tails
EuroVWGTi is offline   Reply With Quote
Old 02-28-2008, 06:23 AM   #5
2000 A6 2.7t 6m
New Member
Account #: 110523
Default Looks Good!! Same place I mounted my amps, but mine don't slide out :(
2000 A6 2.7T 6M
Click for photo album
Completed Upgrades:
APR 93 ECU -=- H&R Coilovers -=- H-Sport Swaybars -=- VMR B7 RS4 Reps in Onyx Black -=- Hella Smoked Tail Lights -=- Smoked Sidemarkers -=- Clear Corners -=- 4.2 Door Blades -=- Hidden Compass OEM B6 mirror -=- Upgraded Sound System -=- Phatbox -=- Short Shifter -=- Low Temp Afterrun Switch -=- VASTperformance Solid F-Hose -=- 710Ns -=- Samco TBB -=- Independent Fog Light Mod -=- Central Locks Recode -=- ABS Rebuild -=- Motul Fluids
Saving money for:
Allroad Headlights -=- Window Tint -=- Spoiler
2000 A6 2.7t 6m is offline   Reply With Quote
Old 02-28-2008, 06:27 AM   #6
Audeye A6
Member
Account #: 67177
Default Wow..very clean !!!
2001 2.7T / 6spd / Cold Weather Pkg. / Premium Pkg.
EPL Custom Tuned Stage III / 93 Oct
710N's
Bilstein-HD / B&G Sport Coils / H-Sports
KO4/997 Hybrids
Autospeed MAF
60 lb injectors
RS4 Accordion tube
Kevlar Clutch,PP & Throwout bearing
Autospeed Trans. stabilizer bar
AWE/McNeil Downpipes/graphite rapped
AWE/McNeil Intercoolers
APR exhaust/snub mount
Port/Polished/Ceramic coat exh. mani's
JHM short shifter
Hardwired/stealth V1
Digital Boost gauge
Debadged
Audeye A6 is offline   Reply With Quote
Old 02-28-2008, 06:29 AM   #7
Kris Hansen
Account #: 20
Default Nice!!! Can't wait to see, and hear this in person!
Old 02-28-2008, 06:30 AM   #8
Press
Yeah, I have a Porsche
Account #: 78455
Press's Avatar
Default looks great
PSA - Don't post angry
"Just living the dream"
Autobahn Country Club (North-South-Full),
Blackhawk Farms, Daytona International Speedway,
GingerMan, Grattan, Mid-Ohio, Nurburgring, Road America,
VIRginia International Raceway, Watkins Glen International
"The most fun you can have in a car with your pants on"™
RIP Zipper 08/03/1999 - 05/09/2009
TeamJanicaRacing.com
2004 A4 3.0 USP Avant
1989 Porsche 951
2001 A6 4.2
Press is offline   Reply With Quote
Old 02-28-2008, 06:35 AM   #10
4Driver4
Tech Guru
Account #: 43812
4Driver4's Avatar
Default Curses! Pics blocked at work. Now I'll have to run home at lunch.
4Driver4
"Never give up the throttle until the bitter end." -RC
1990 Coupe Q
1999 A6 Sedan Q 2.8
2000 A4 Avant Q 2.8
1995 Mazda Miata: the anti-Audi
1999 Mazda Miata: Track beotch
1999 Chevy Suburban: the anti-earth :-(
1990 Nissan Pickup: Snow plow/garbage hauler
1981 VW Scirocco: the car I shouldn't own
4Driver4 is offline   Reply With Quote
