Go Back   AudiWorld Forums » Audi Models » Audi A4 » A4 (B5 Platform) Discussion
Old 04-07-2003, 08:14 PM   #11
Pizzicato
Member
Account #: 27798
Default just to the inside of it
Nie Folgen<a href="http://www.wunderground.com/global/stations/71627.html?bannertypeclick=gizmotimetemp24">
</a>
pizzicato1@gmaildotcom
Pizzicato is offline   Reply With Quote
Old 04-07-2003, 08:21 PM   #12
CMC - in Buffalo!!!
Member
Account #: 2963
Default What's that undercoating made of? I got a chunk taken out earlier this week driving into a parking
lot made for 4x4's out by the Ozarks. =(
Any idea where I can get it "recoated"? Thanks...
1999.5 Volcano Black A4 1.8TQ Tip (SOLD)
2002 Sapphire Blue Mercedes SLK230 6-spd
2006 Porsche Cayenne
CMC - in Buffalo!!! is offline   Reply With Quote
Old 04-07-2003, 08:31 PM   #13
Andy_FL
Account #: 12690
Default Rubber?
A rubbery/sticky goo? Just grab a spray can of rubberized undercoating (or truck bed liner) at AutoZone....it's nasty stuff, but it does the trick. Good luck
Andy
Andy_FL is offline   Reply With Quote
Old 04-07-2003, 08:39 PM   #14
CMC - in Buffalo!!!
Member
Account #: 2963
Default Cool... thanks Andy!!! =)
I'll get working on it sometime this summer and place my jack stands in the spots you stated above, hehehe.
Old 04-07-2003, 08:40 PM   #15
MikekiM@PureMS
Audiworld Sponsor
Account #: 13830
Default Excellent pointer
For lifting, I use the flat spot (that's sorta deformed in your pic), BUT I place a small piece of plywood on top of my lift pad. It helps to prevent that are from getting deformed.
I use various places for the stands, where you indicate is an excellent choice, as is where MB suggests on the factory DTS mounting locations.
Your source for all Audi parts! Euro, OEM, Aftermarket, we can get it!
www.purems.com | 866-397-5487 | Temecula, CA
mike@purems.com
MikekiM@PureMS is offline   Reply With Quote
Old 04-07-2003, 09:02 PM   #16
Greyhound Guy
Member
Account #: 7687
Default sometimes also known as undercoating.
2001 A4QM Avant 1.8T Stage III and More
1996 A6Q Avant 2.8 Straight Up
Capital Area Volkswagen Audi
Greyhound Guy is offline   Reply With Quote
Old 04-08-2003, 03:08 AM   #17
Digit@lex
Elder Member
Account #: 1308
Default Mark, can you point out where this PAD area is?
Is it where those little rubber circular pads cover up the holes or somewhere else? Thanks.
Digit@lex is offline   Reply With Quote
Old 04-08-2003, 04:11 AM   #18
scott12v@pghaudi
Member
Account #: 7844
Default You should submit this as a FAQ.
scott12v@pghaudi is offline   Reply With Quote
Old 04-08-2003, 04:41 AM   #19
markbradford
Member
Account #: 129
Default Low, square, flat area that does have a hole in it yes.
I use a flattop floor jack to lift there and then put the jack stands where the DTS go. The dealer uses these pads with a lift too, because the surface area is greater to distribute the weight better.
markbradford is offline   Reply With Quote
Old 04-08-2003, 04:45 AM   #20
Digit@lex
Elder Member
Account #: 1308
Default Cool thanks. I think in the pic, that's where Andy had his rear jack stands placed (last pic).
Ok, I know there is a similar one up front. However, when I jack the front I won't be able to use the DTS area since I will be installing the DTS. ;-)
Tags
a6, audi, b5, jack, jacking, mk2, pinch, points, quatro, s4, spots, stand, stands, tdi, volkswagen, weld
