| Register | Pictureposter | Classifieds | FAQ | Members List | Search | Today's Posts | Mark Forums Read | Garage | My Recent Topics | Dealer Listings |
| Notices |
Thread Tools | Search this Thread | Display Modes |
#1 |
Junior Member
Account #: 106707
-Engine Must Be OFF but key in ignition turn on one notch to "accessories only".
-Start up Vag-Com. -Click "Select" under "Select Control Module" -Click "01-Engine" -Click "Coding" under "Advanced Functions" -Change the last digit from a 2 to a 1 -Click "Do it" -Close Vag-Com, turn car off and then start fully. -Done! ![]() A4 Engine Soft Coding: Last digit a 1 A6 Engine Soft Coding: Last digit a 2 What this does: This tells the ECU you are an A4, which changes the engine characteristics a bit. Makes the midrange and top end a little more enjoyable for enthusiasts. It changes the manifold changeover point, and I believe ignition timing slightly. Just wanted to bring this back up from the archives. Kris Hansen's Old Post |
#2 |
Member
Account #: 121340
************************************************* ![]() Johnny B. - OFFICIAL 2007 C5 A6 POST WHORE - - OFFICIAL 2008 C5 A6 POST WHORE - R.I.P. Thor- 10/97-8/08.. I miss you buddy :( Racing Green PE 2000 A6 4.2: All options except warm weather & Sport package... MODS: Bilstein shocks, H&R Sport springs, 18x8.5" wheels (et30) with 235/40's, blacked-out RS6 upper grille, debadged, 15mm (F) and 20mm (R) spacers (SOLD,) Darintake mod (w/screen,) 00032 trans recode, high flow race cats (courtesy of 034 Motorsport,) plain black 3-spoke steering wheel, 605 "mod", painted rear valance, drilled rotors F&R, Metal Master front pads, VAST performance fan, clear corners, and various other things. FUTURE PROJECTS: NONE. She will be gone soon. Previous Rides: 1996 A4 2.8Q 1992 Acura Legend LS sedan 1986 Ford F-250 2WD |
#3 |
Senior Member
Account #: 26081
You could experiment:
1. Lemmiwinks 2. Aux. air intake into the air box. The S6 has that if you ever look at one carefully. 3. Investigate the throttle body. I notice the throttle body is smaller than the intake manifold where it bolts up. I wonder if A8 version with the extra 10HP or the S6 version with 40 extra ponies is actually full size. Kind of like a NASCAR restrictor plate concept. Throttle bodies are expensive for these cars because of drive by wire. Do realize all the S6 power is really up above the regular 4.2 redline if you look at the power curve for the motor. But most of the S6 real delta is in the tranny gearing--the 4.2 being ridiculously highly geared to avoid the guzzler tax they decided to let apply to the S6.
.... Current #1: '06 D3 A8L W12 brilliant black w/ amaretto & 4 seat setup, GmbH custom, CPO; modestly VAG COM lowered, H&R 20mm rear DRA's with 275/35 on OEM polished + forged 20's; S8 sway bars (see: rear bar and gen'l D3 bar info and front bar); tweaked 385mm front factory brake mod and matching rear brake mod; matching C6 A6 back headrests (better rear view: headrest tweak); owner installed AMI retrofit with part number details here; other VAG COM tweaking to suit Current #2. C5 '00 A6 4.2 ming blue w/ beige, new off showroom floor; Lemiwinks + VAG COM tweaks; smoked tails; RS 6 OEM 18's; RNS-D (CD) Navi Prior: '96 C4 A6 2.8Q, still w/ family; '85 C3 5000S 5 sp FWD, '73 C1 100LS helpful cross reference to a C6 post with MMI and other TSB's that also cover D3 A8's.
#4 |
Member
Account #: 121340
| Tags |
| a6, coding, soft |
Previous Thread
Next Thread
| Display Modes | |
Linear Mode
