| Register | Pictureposter | Classifieds | FAQ | Members List | Search | Today's Posts | Mark Forums Read | Garage | My Recent Topics | Dealer Listings |
| Notices |
Thread Tools | Search this Thread | Display Modes |
#1 |
Junior Member
Account #: 106707
Most likely it is the valve cover gaskets and cam chain tensioner seals as most of my search came up with. Figured I would post some pics anyways and get some feedback.
POSTS I FOUND: Post 1 Post 2 Post 3 Post 4 ***NOTE*** If after viewing the pictures below and you feel it could be something else that I haven't mentioned feel free to mention it! TIA!!! FYI: I found two Write-Ups about DIY...if anyone else has one as well, that would be much appreciated. TIA. Also if anyone knows where I can get the parts needed to DIY please let me know. TIA again! Write-up ONE - absolutcq20v's Fix Your Leaky Valve Covers/Cam Tensioners Write-up TWO - http://www.robsaudiworld.com/2.8camseal.htm First thing is first, remove the belly pan Oooooo looky what I found never good to find fluids on the belly pan...![]() A closer look... ![]() Quickly jumped to the ground and took a couple shots for your viewing pleasure ![]() First noticed a couple drips... ![]() Followed the steel lines back closer to the engine... ![]() Followed them even further up... ![]() Another shot from where I could see with the camera... ![]() Removed the air system and the plastic covering to uncover the below pics... ![]() ![]() ![]() ![]() ![]() ![]()
#2 |
Member
Account #: 8108
...swap out that suction pump. You want to be sure that the pressure inside the head is regulated properly.
See my sig for a step-by-step
![]() ![]() AudiWorld || 1999 A6 2.8q | 1992 100CS | AudiWorld Photo Gallery Links || Stoney's FAQ | CycleForums European Sportbikes Forum Tech Articles || Instrument Cluster Replacement | Suction Pump Replacement Other || boompa.com/audiSean FOR SALE: MOVEN SP-10 18X8.5 FORGED WHEELS, $500 for 5 |
#3 |
Junior Member
Account #: 106707
#4 |
Junior Member
Account #: 106707
#5 |
Member
Account #: 20251
it won't "heal" itself. You will still have to get the seals replaced, but it should reduce the amount of oil dripping immediately.
There were some defects in the heads themselves that might be causing this behavior, but if you have not yet had the cam adjuster and valve cover seals replaced that is likely your issue. My 2.8L 30V had those seals replaced twice before the realized it was a defect in the head itself - had the heads replaced under warranty and that finally stopped the leak and the awful smell that came with such. (This was on a B5 Passat - same as a C5 A6 w/ FWD; except that VW gave a 10 yr/100k mile powertrain warranty, thank god! The head R&R cost like $5k+)
2002 S4 Laser/Silver 6-speed Cold, Premium, Bose, Changer <Brian May guitar riff>..."I'm in love with my car, got a feel for my automobile"...I OWN an S4, I DROVE many a service loaner from Enterprise! $19k+ worth of warranty repairs. Tally ended on 8-23-05! She's now free of the man; DIY all the way! Now spending AoA retroactive cash back bonus for crappy dealer service! Thanks for the check, AoA! Please help to fight window-licking! (I hear they have a cure over on Audizine...)
#6 |
Junior Member
Account #: 106707
Looks like I will have a weekend of DIY!
![]() Pretty Decent Prices from World Impex: SUCTION PUMP $23.45 TENSION GASKET KIT $17.20 VALVE COVER GASKET SET $52.18 |
#7 |
Member
Account #: 8108
Whether or not is stops leaking depends on the amount of damage to the seals themselves. You won't know until after you remove the blockage in the breather system.
#8 |
Junior Member
Account #: 106707
I am going to replace the suction pump and go from there.
Previous Thread
Next Thread
| Display Modes | |
Linear Mode
