| Register | Pictureposter | Classifieds | FAQ | Members List | Search | Today's Posts | Mark Forums Read | Garage | My Recent Topics | Dealer Listings |
| Notices |
Thread Tools | Search this Thread | Display Modes |
#1 |
AudiWorld Expert
![]() Join Date: Feb 2004
To celebrate my 8,000th post, here is my write-up for the Tiptronic paddle-shift steering wheel. This was NOT a cheap mod at all, although I got some good bargains on eBay Germany and eBay UK.
Big kudos to Herve for blazing the trail with his button shift steering wheel tech article, ming.moro for showing me his RS6 paddle shift steering wheel, TeddyBGame for helping out with numerous questions that came up during my preparation for this project and SilverBullet LT, who found an error in my wiring connections in my writeup. DISCLAIMER: If you do this project, you are about to do major electrical work on your car. Exercise care, and make sure you disconnect the battery. You are also going to be removing the airbag, and if you are skiddish about that, don't do this project. However, working properly, it should not pose any problems. Lastly, you MUST have access to a VAG COM cable as one component requires you to not only login to the ESP to recode, but to recalibrate the steering angle sensor for ESP. NOTE: The paddles ONLY work when the shifter is moved into the Tiptronic mode. When the car is in D, the paddles do nothing. Also, this will NOT work on 2002 and later A6, as the tiptronic wiring changed. I believe in 2002, this mod can be done with simply changing the steering wheel control unit, and wiring to the tip harness, but I have not interpreted those wiring diagrams. I have included everything I followed to do this project. Please feel free to contact me at bostondriver@gmail.com if you have any questions. The preview... ![]() Tools needed - VAG COM cable - radio removal keys - 8mm socket (for various plastic trims) - 10mm wrench (for battery) - 13mm socket (for M12 triple-square tool) - T-30 Torx key (for airbag) - T-30 Torx driver - T-25 Torx driver (for plastic trims) - M12 triple-square bit (for steering wheel bolt) - Phillips and flat screwdriver (for trims) - Wire cutter/stripper - Plastic putty knife (not pictured) ![]() Audi Parts needed - Steering wheel [8D0 419 091] - Airbag [8N0 880 201] - Self-canceling ring [1J0 959 654 M] - Wire connector [4B0 973 605] ![]() ![]() ![]() Other materials needed - 24-gauge wire (different colors if possible) - 24-gauge button-style wire taps - Zip ties ![]() Installation Steps 1. Preparation 2. Remove airbag and old steering wheel 3. Remove self-canceling ring 4. Remove lower dash, shift trim, and center console electronics 5. Run wires from steering wheel to Tiptronic selector 6. Connect wires 7. Fit new self-canceling ring and steering wheel 8. Replace trim and other components 9. Connect the battery 1. Preparation First, login to VAG COM and record the codes for ESP (If you have ESP). Also, make sure you have your radio security codes handy, since you will be disconnecting the battery. You will need most likely need the radio security code when you power up the car again. Once you have stored the codes, park the car with the front wheels straight and the steering wheel centered. This will make for easier installation of the new steering wheel later. Disconnect the battery using the 10mm socket. I typically only disconnect the negative side of the battery, which kills power to the car. 2. Remove airbag and old steering wheel From behind the wheel, remove the two T-30 torx bolts that fasten the airbag to the steering wheel. I am sorry that I do not have a picture of the bolts on the old 4-spoke wheel, but here is a good picture of the bolt from the back of the new steering wheel. ![]() These bolts are VERY tight, and there is not much room back there to get good leverage with a Torx driver. I ended up buying a T-30 torx key, which gave me MUCH more leverage to loosen the bolt. Once the airbag is removed, release the wiring harness for the airbag by using a very small flat head screwdriver and flipping up the yellow clip pictured below. If you have the multifunction steering wheel with radio controls, there will also be a black connector on the right side of the airbag that also has to be removed. ![]() Remove the airbag and carefully set it aside. Using the M12 tool, remove the bolt that secures the steering wheel to the steering column. ![]() Remove the wire connector that goes from the steering wheel to the self-canceling ring, remove the wheel, and store in a safe place. You may want to fasten the airbag back to the steering wheel at this point for storage (or sale). ![]() 3. Remove self-canceling ring First, you need to remove the plastic shell of the steering column. You need to remove 2 Phillips-head screws in the front and two from the underside, as well as a T-25 Torx bolt that is located on the bottom under the tilt steering lever (see pictures below, the two screws are in the upper corners of the image, the Torx bolt in the lower part of the image). Lift the upper-half section of the steering column cover by lifting up the end of the trim closest to you and pull outward. Carefully, remove the lower half, being mindful of the opening and gasket for the ignition. This lower trim piece may just dangle, since it does not have to be completely removed. ![]() You may now remove the self-canceling ring by releasing the 4 tabs that hold it into place and disconnecting the various wire connectors. 4. Removing lower dash, shifter trim, and center console electronics Removing the lower dash: I do not have good pictures of the lower dash panel removal for this post, but there are a few good posts already on this panel removal. However, I will describe it for you. There are five (5) 8mm bolts that secure the lower dash panel. Two bolts are located behind the plastic trim piece just above the steering column (just pull rearward to remove this trim). Two bolts are recessed in the lowest and outermost corners of the panel. One bolt is located on the left side of the dashboard by the fuse box. Unplug the ODBC connector (the purple plug) and the foot-well light. Unclip this trim panel from its two catches near the floor just above the pedals. You can now free the trim, and it will be much easier to run wires with it out of the way. I left mine dangling because of the cell phone hands-free kit control module that is fastened to the dash panel. I did not feel like disconnecting all of those things. Removing shift trim: Lift the shift trim from the rearward edge. Shift the gear selector to 4th (I know, in this picture, mine is in N...regardless, make sure your emergency brake is on!) and lift up and out and towards the rear of the car. ![]() Next, with the gear selector in 4th, pull the button on the left side of the handle out with one hand while pulling the gear knob hard upward with the other hand. If you have never removed this knob, you really feel like you are going to break something. IMPORTANT NOTE: Once the knob is removed, make sure you wedge something in the gap on the lower side of the button before it snaps back in. This button is a PITA to pull back out if it recesses into the knob itself. I used a small scrap of cardboard that I had on hand as a wedge in the gap on the bottom side of the button. ![]() Next, as you can barely see in the picture above, you need to remove the aluminum bezel, which is secured by four tabs, two each on the left and right side. Using the putty knife, GENTLY pry the black tabs to release the bezel. Those black plastic tabs are brittle. Now you can see the shifter circuit board. ![]() Just lift up the circuit board to gain access to the wire connector underneath. ![]() To remove the wire connector, simply depress the spring clip in the center of the red circle pictured below, and pull the connector plug out of the back of the circuit board. ![]() Removing center console electronics: I had a REALLY hard time fishing the wires from the Tiptronic shifter to the under-dash area, so I removed the radio, climate control unit, and the ashtray to get a good look at the pathway for the wires. First, remove the radio head unit using proper radio removal keys and unplugging the wiring harnesses. ![]() Before you set aside the radio head unit, remove the radio keys by pressing down the spring tabs and pulling out the key. I have heard so many stories of stuck radio keys, and they are stuck because the unit has to be out of the dash to be removed properly. ![]() Remove the two bolts in the upper corner of the climate control unit (red circles below). Then, reach in from the top of the unit and push the unit out from behind. ![]() Unplug the multiple wire connectors, and set the unit aside. ![]() There are two tabs on the top hold of the ashtray the secure the assembly. Simply push down on these tabs (red circles below) push unit out from the rear. The ashtray is a very tight fit. Just keep pushing from the rear, and it will eventually free itself. ![]() Disconnect the wiring harness from the underside of the ashtray. ![]() YOU ARE NOW READY FOR INSTALLATION!!! 5. Run wires from steering wheel to Tiptronic selector You can see in the picture below the path I ran for the wire, but this picture shows the wrong wire (red, green, and black). I used the wrong gauge wire for my initial install, so I simply used the wrong wire to fish the new wire into the dash later. ![]() Next, you will need to feed the wire up the steering column. To make sure the new wires don't interfere with anything else, there are a couple of clips under the steering column (red arrows below) that release and then clip back to fasten the wires down. ![]() 6. Connect wires Strip wire ends and hook into wire connector (4B0 973 605), making sure you note which wire is in which numbered position. I used the following wire connections here based on the order they are laid out in the ribbon wire: Green wire to position 1 on connector Red wire to position 2 on connector Black wire to position 3 on connector White wire (not needed) to nothing ![]() Secure the wiring connector to the other wire connectors for the steering wheel with a zip tie. ![]() Pull the wire for the Tiptronic shifter out as far as you can. Peel back as much of the cloth tape to expose the plastic tube. This tube has a slit for access to the wires that are contained within the tube. Locate the purple/red, purple/blue, and the purple/yellow wires and pull them out ![]() I used the button-style wiretaps from Radio Shack, which are small, and self-sealing, and perfect for this size wire used in this mod. The existing wire slides into a slot on the side of the button, while the new wire is inserted into a hole on the other side of the connector. The new wire does not need the end stripped for this tap. I made the following connections using the phone wire taps: Wire 1 (Green) to the purple/red wire in the Tiptronic harness. Wire 2 (Red) to purple/yellow in the Tiptronic harness Wire 3 (Black) to the purple/blue wire in the Tiptronic harness Wire 4 (White) to nothing ![]() Here is the wiring diagram from the Bentley Manual so you can see what the heck you are tapping into: ![]() Tuck it all into the console and reconnect the wire for the circuit board. ![]() Replace the aluminum shift bezel. ![]() 7. Fit new self-canceling ring and steering wheel Plug I the wiring connectors in the back of the self-canceling ring. The yellow one is the airbag, the middle one is the connector you just made, and the large black one is for ESP. Remove the safety tab. ![]() Snap the self-canceling ring onto the steering column. ![]() Reinstall the steering column trim. You must install the lower half first, again, being mindful of the rubber gasket for the ignition switch. Replace the two screws in front and the T-25 Torx bolt from underneath the tilt steering lever. ![]() Replace the upper half of the trim which kind of "hinges" from the portion closest to the instrument panel. Then secure with the two long screws from underneath. ![]() Install the new steering wheel and fasten using the steering wheel bolt. ![]() Connect the airbag. ![]() Fasten the airbag to the steering wheel using the two T-30 torx bolts from behind the steering wheel. ![]() 8. Replace trim and other components Reinstall the dash panel, shift trim, shift knob, ashtray, climate control, and radio. ![]() 9. Connect the battery. Turn the car to the "on" position, without starting your car. Let the car rest for at least 3 minutes. Check VAG COM for any codes, start the car, and enjoy!!! IMPORTANT NOTE ABOUT ESP!!! Make sure you run a VAG COM check and write down your original ESP code. I had issues with my ESP and ABS because I had my battery plugged back in while several components (including the self-canceling ring) were out of the car. I was working at night for some of this install so I had to have the lights on inside the car. I forgot to record my original ESP soft code, but thanks to my VAG-COM cable, the Bentley Manual, and Andy from Ross-Tech, I was able to re-code the ABS Brakes module (03) and clear the codes. Although not in the VAG COM instructions, we discovered that the ABS module could ONLY be re-coded after you log in with a shop code other than 00000. If you try to login with the default "ghost" shop code of 00000, then the module cannot take the re-code. Once that was done, I could recalibrate the zero position for the steering angle sensor. Happy shifting!!!
2002 A6 4.2 Sport...with a few things added |
#2 |
Member
Account #: 1018
Instant FAQ inclusion nominee right here.
Great post.
JimR '07 A3 3.2q Lava Gray '99 A8 4.2q Pearl White '99 A6 Avant 2.8q Silver (My old car, son now drives) '06 Boxster S Guards Red (wife's wheels) ![]() Support the troops "Over the years, I have come to understand a critical difference between the world of fear and the world of freedom. In the former, the primary challenge is finding the inner strength to confront evil. In the latter, the primary challenge is finding the moral clarity to see evil." |
#3 |
New Member
Account #: 90401
![]() ![]() 01 AUDI A6 2.7T SLUSH BOX EDITION GIVING AWAY STOCK EXHAUST FOR 2.7T LOOK AT PIC POSTER FOR A PIC |
#4 |
Member
Account #: 32631
...plus I have a complete inventory of tiptronic wheels and airbags left to clear out of my garage (hint, hint). The hardest part was sourcing the airbag and the self-cancelling ring.
You folks should see my pix in another month. Also worth noting: If you don't have ESP, then a VAG-COM is not needed. -ted
TeddyBGame - C5 Avant - "the Beast" (Ha!!) - 2005 Chrysler Pacifica Touring (Nav, Sirius, Bluetooth, Xenon, TPMS, ParkSense, DVD Changer - basically loaded) - 2003 Vespa ET2 (modified exhaust and carb -- so I can max out at 45MPH) - John Deere Gator (4x2) for the boy As of November 2006: Accessory Add-ons: (Definition: An item that provides a specific function - in a cyclical nature - and can be removed very..very easily.) 1) OEM winter floor mats 2) OEM rubber trunk mat and cargo net 3) VW Touareg cigarette lighter flashlight 4) Thule roof bars with Evolution 1200 roof box Upgrades: (Definition: A [bolt-on/bolt-off] item that enhances the appearance, performance or misc function of your car.) 1) OEM front/rear Euro black Recaro Seats (from a Euro 2003 S6 Avant) http://forums.audiworld.com/a6/msgs/618112.phtml 2) OEM HID/Xenon (complete) housings (car never came with the Xenon option from the factory) 3) OEM Euro front/rear (avant) beam-style wiper blades/arms (available via www.vagparts.com) 4) OEM B6 S4 Interior auto-dimming black mirror with compass and on/off button 5) OEM Euro blindspot exterior mirrors 6) OEM S6/4.2 exterior lower door trim 7) OEM S4/S6/S8 aluminum mirror housings 8) OEM Euro rear license plate panel from 2002+ facelift avant (slight MODification to US plate required) 9) ? 10) OEM Euro RNS-E DVD Navigation system with MP3, SAT control and TV input 11) Dietz 1417 A/V input to RNS-E 12) Blaupunkt ME3 DVD/CD/MP3/TV Tuner with aftermarket amplified TV antenna in windshield 13) OEM Sirius tuner (special version to work with RNS-E) 14) OEM Phatnoise Phatbox MP3 player (trunk mounted) with custom interface cable to allow Sirius tuner and Phatbox to work together -- cool!! 15) ? 16) BBS RC 17x8 ET35 with Michelin Pilot Sports (summer tires) 17) 2002+ Rear bumper with valance openings for Magnaflow 3" exhaust tips 18) OEM submarine fin roof antenna for SAT / GPS / Cellphone (GSM) 19) OEM Euro gunmetal black avant roof rails 20) 2002+ Climate control faceplate to match faceplate color of RNS-E 21) Walnut wood trim near hazard button (above RNS-E) to match rest of interior wood scheme 22) OEM Euro Avant door panels with integrated sunshades (imported from Germany to match the black leather in my Euro Recaro interior) 23) OEM Euro blacked out front grille (no chrome perimeter) 24) OEM gunmetal black lower rear hatch strip (specific part# for avant vs. sedan) 25) OEM RS6 gunmetal black interior door latches; no need to add any RS6 badges in my car (Thanks Nelson!!!) 26) OEM Euro four spoke walnut wood and black leather (special order via Audi GmbH) multi-function wheel with tip buttons and OEM phone (BT) control 27) Upgraded "618" MF/Tip control module Coming soon: - rear mounted removable 7" LCD panel MODifications: (Definition: Any permenant change to a part or component of your car that you cannot reverse) 1) Tray under armrest to add aux. cigarette lighter 2) OEM avant CD changer bracket MODified (to fit two large CD changers etc) - now I just use it for Phatbox, OEM SAT tuner and OEM BT module. 3) Exhaust tips MODified to add Magna Flow (#35163) 3" dual walled tip 4) Factory wiring behind Sym I to simplify installation/removal of RNS-E 5) MODified glovebox to support fitment of Blaupunkt ME3 (a biatch to install!!) 6) MODified headlight switch bezel for fitment of GALA switch for "video-in-motion" for playing Blaupunkt ME3 through RNSE 7) MODified stock exhaust and had magnaflow 3" tips welded on (see above) 8) MODified rear Euro license plate surround to house 2nd rear foglight (2001 model only came with one from the factory); US license plate needed to be MODified a bit to fit inside the narrow Euro opening. RNS-E for C5 A6/S6/allroad/RS6 - your quest starts here - (regularly updated) <a href="http://forums.audiworld.com/a6/msgs/607331.phtml">OEM submarine fin installed on |
#5 |
Junior Member
Account #: 66048
![]() 2000 A6 4.2 NS stock except 00032 tip recode, auto-lock/windows mod, 392 Servo pulled, 20GB Phatbox, 2002 bumper and exposed tips, 3M tint - 20% all around. |
#6 |
Member
Account #: 76151
However, Tips and paddle shifters are for geeks anyway ;-). Thanks...great writeup!
6-speeds rule!
![]() '01 A6 2.7T 6-spd (Ming Blue, Cold, Sport, Premium), 2 x K04, APR Downpipe & Cat-back (where did I leave the Cats anyway?), Bi-pipe, Forge Diverter Valves, Snub Mount, AWE Fueling Kit, RS4 Intercoolers, Stoptech 332 BBK, RS4 Clutch Kit, AWE DTS, Bilstein PSS9 coilovers, H-sport swaybars, Setrab 12x9 Oil cooler with Mocal 180deg adapter plate, 18x8 RS4 DTM Wheels Falken FK-452 (235/40/18), Track: 17" Flik Lex Wheels with Falken rt-615 245/45/17, B&M Short Shift Kit, Samco hose kit, Forge DV's, RS6 Fender Liners, hella smoked tails. Dyno results 371whp/411wtq!!! Other Rides '03 Mini Cooper--Mama's Ride '87 4000 CSQ--Under construction Past Rides '86 Coupe GT--Tornado Red! '98 Jetta TDI, aka "Chitty-chitty, Bang-bang" (Gone but not forgotten) '86 CSQ--gave it's life so other could live (chop, chop) Kansas City Chapter Website Kansas City Audi Yahoo Group--Local News and Info |
#7 |
Junior Member
Account #: 75436
#8 |
Account #: 65805
paddles a lot more than I use mine!
![]() badges Our new baby: ![]() 2003 RS6 Mugello w/STaSIS Motorsport Suspension, RNS-E 1979 Porsche 911SC Targa past: 2001 A6 4.2 1998 A6 2.8 Q 1996 A4 2.8 Q 1984 Ferrari Mondial 1983 Rabbit GTI - (Stage II turbo - what a pisser of a car!) 1979 Mazda RX-7 1977 Ford Capri II |
#9 |
Account #: 75826
2002 3.0 Quattro | Dolphin Grey | Platinum | Premium | Xenon | Heated Seats | Owner since June 29, 2002 What I've done to it: Limited Edition 25th Anniversary S4 18" Wheels | Milltek Exhaust | H-Sport S4 Sway Bars | Bilstein Sport Shocks | Eibach Pro Kit Springs | S4 Front Bumper | S4 Upper and Lower Grilles | S4 Polished Aluminum Mirrors | S4 Door Blades | S4 Replica Spoiler | Zimmerman Rotors | Hawk HPS Pads | 3M Carbon Black 50% Tint | Hoen H-11 Xeonmatch Fog Bulbs | Tinted Side Markers Miles: 98,500 B6 A4 3.0 AudiWorld Member Database |
| Tags |
| 2001, 2002, 2007, a4, a6, audi, cl600, install, installing, paddle, shift, shifter, steering, tiptronic, wheel |
Previous Thread
Next Thread
| Display Modes | |
Linear Mode
