Go Back   AudiWorld Forums » Audi Models » Audi A6 / S6 / RS 6 » A6 / S6 (C5 Platform) Discussion
Old 04-04-2005, 12:17 PM   #1
TeddyBGame
Member
Account #: 32631
Default euro blindspot mirrors: Installation, Fitment, thoughts, experience (you know the drill)
Well, I've seen these advertised on several group buys etc...so I thought, "what the heck, I'll give them a shot”. I apologize in advance for the dirty picture of my mirror.
The highlights:
- Very easy DIY installation. You can handle each side in 45 minutes (tops)
- Fairly inexpensive...unless you have auto-dimming mirrors (see below)
- I only installed the drivers' side mirror. After a month of use, I plan on buying the passenger side.
Bottom-line: Has made a noticeable difference when navigating in traffic (most of my driving is on the highway). These will probably make a bigger difference if you drive a lot in the city.
Description (I pulled this from another website): Why these mirrors aren't available outside of Europe, we may never know. The Blindspot Mirror Glass adds safety and security to your vehicle, allowing you to see objects both near, far, and in areas that are normally easy to miss. While basically normal by all appearances, these European Blindspot Mirrors are curved (aspherical) at the outermost edges, allowing for greater range of view.
Fitment for Models/Years: C5 A6/S6/RS6/allroad MY1998-2004
(FYI - the mirror glass from a B5 A4 (MY1999.5-2001) and B5 S4 (MY2000-2002) is the same glass/part used in the C5 A6.)
- C5 A6 MY1998-1999 (those with the smaller passenger/right side mirror. For this car, I am not sure if someone offers a blind spot mirror for the smaller exterior mirror. You might need to install an exterior mirror housing from a newer C5 A6. Sorry, other than that…I can‼sup>TM</sup>t help you there (hint: search the forum for any details from those that have done it in the past).
- C5 A6 / S6 / RS6 MY1999.5-2004 (V6 and V8 models all have the same exterior mirrors)
- C5 allroad MY2001-2005 (V6 and V8 models all have the same exterior mirrors. I believe that only www.Vagparts.com offer the allroad versions)
Part numbers (via vagparts.com) for C5 A6/S6/RS6 (1998-2004) FYI - I used the part#'s that they gave me for the B5 A4 1999-2001 as they share the common part; also a part# starting in 4B0-XXX-XXX might work).
Auto-dimming, heated version
- Left/drivers' side: part#8D0-857-535H
- Right/passenger side: part#8D0-857-536H
NONE auto-dimming, heated version
- Left/drivers' side: part# 8D0-857-535E
- Right/passenger side: part# 8D0-857-536E
Part numbers for C5 allroad MY2001-2005 (via vagparts.com)
- Left/drivers' side: part# 4Z7-857-535A
- Right/passenger side: part# 4Z7-857-536J
- Left/drivers' side: part# 4Z7-857-535B
- Right/passenger side: part# 4Z7-857-536D
C6 A6 from 2005 - ?:
C6 A6 MY2005+ ? I believe the B6 A4/S4 (and possibly the D3 A8) share the same size/shape exterior mirrors...but I'm not positive (I posted the question on the C6 A6 forum a month ago…and I didn't get a response). In this scenario, you could add the euro blind spot mirrors as they are listed on www.Vagparts.com (both auto-dim and non auto-dim) under the parts section for the B6 A4/S4 (MY2002-2004).
Part numbers (via vagparts.com) for C6 A6 (and possibly S6/RS6…when available):
- Left/drivers' side: part# 8E0-857-535H
- Right/passenger side: part# 8E0-857-536H
- Left/drivers' side: part# 8E0-857-535E
- Right/passenger side: part# 8E0-857-536E
What if I have exterior auto-dimming mirrors?:
Chances are, most of the C5 A6 owners have the convenience package with interior/exterior auto-dimming mirrors. I've noticed that the auto-dim blind spot mirrors are ridiculously expensive (Ouch! $500+ for a pair). Incidentally, the dealer charges $200/each for a replacement auto-dimming mirror (non euro blind spot).
Based on my research via the Bentley schematics, the three (two exterior and one interior) auto-dimming mirrors all work in concert together to adjust the dimming of all three. You might ask, "how do you know this?"...well my 2001 A6 didn't have the convenience package...and I REALLY wanted the interior auto-dimming mirror. Well, back in June 2002, Achtuning was running a Group Buy for the interior auto-dimming compass mirror for $200. What a bargain! (If you search on achtuning.com you will see the compass mirror listed for $250..but it is backordered). I then consulted the schematics in my Bentley manual and spent some time on the phone with the Audi parts department to figure out what parts I needed and how to hook it up. If anyone would like to add an interior auto-dimming mirror (and/or compass version) to their A6...just drop me an email (teddybgame@hotmail.com). I can send you the parts info for the wires/connectors etc. See also this great article by Joshua (Compass Mirror Tech Article)
Behind the exterior mirrors you will find a separate wiring harness (two wires - see link/pix)
that connect to the perimeter black membrane of the mirror. FYI - this black membrane is auto-dimming sensor.
I don't see why you wouldn't be able to just disconnect those wires and install none auto-dimming [euro blind spot mirrors]. Of course, all C5 A6's have heated mirrors, so these are all heated as well.
Thoughts after 1 month of use (based only on drivers' side):
This mirror has already saved my a$$ twice while driving on the Mass Pike (Boston area). If you drive with these mirrors....then drive another car (i.e. your spouse's car), it will be a bit disorienting. I've grown accustomed to that added visibility...but when I go to drive my wife's 2005 Pacifica....I need to take some time to adjust. Of course, you could always just buy euro blind spot mirrors for both cars. Problem: solved! On the flipside, if someone (i.e. your spouse) else drives your car, then he/she will need to adjust to this convex lens as well...because it takes a little while to adjust to them.
Related posts (for those savvy enough to use the "search" function):
related post
related post
related post
related post
Installation fitment post
Source:
(Dear Forum Moderators: Before you decide to delete this post...please keep in mind that I only listed sources that are advertisers on Audiworld)
- Achtuning (AW advertiser): Not sure...as I could only find the version for the TT on their website.
- Stratmosphere (AW advertiser):
Stratmosphere
- EP Importers: http://www.epimporters.com/products/...tion.php?II=93
- VAG parts - they offer the allroad and the C5 A6 version (located under the 1999-2001 B5 A4 grouping) - (www.vagparts.com) Enter Online Shop/Product Overview/Audi etc. www.vagparts.com
https://sslrelay.com/s74326199.onean...dex.shopscript
- ECS Tuning:
http://www.ecstuning.com/stage/edpd/...egory=Exterior
- Pure Motorsport
http://www.pure-motorsport.com/produ...hp/CA=562/PA=1
Links to helpful installation information (very easy job):
Installation post
Installation post
I hope this was useful for you. I tried to cover every possible question that the forum (nooB's and veterans) could ask of me.
Standard Disclaimer: I am not associated with any of the companies that sell/import these mirrors. You assume all responsibility for any damage or unsatisfactory result obtained by following this modification. Please read it all beforehand, just to make sure you understand the implications of this modification and how it will impact your driving ability.
- Ted (Go Celtics!!)
TeddyBGame
- C5 Avant - "the Beast" (Ha!!)
- 2005 Chrysler Pacifica Touring (Nav, Sirius, Bluetooth, Xenon, TPMS, ParkSense, DVD Changer - basically loaded)
- 2003 Vespa ET2 (modified exhaust and carb -- so I can max out at 45MPH)
- John Deere Gator (4x2) for the boy
As of November 2006:
Accessory Add-ons:
(Definition: An item that provides a specific function - in a cyclical nature - and can be removed very..very easily.)
1) OEM winter floor mats
2) OEM rubber trunk mat and cargo net
3) VW Touareg cigarette lighter flashlight
4) Thule roof bars with Evolution 1200 roof box
Upgrades:
(Definition: A [bolt-on/bolt-off] item that enhances the appearance, performance or misc function of your car.)
1) OEM front/rear Euro black Recaro Seats (from a Euro 2003 S6 Avant)
http://forums.audiworld.com/a6/msgs/618112.phtml
2) OEM HID/Xenon (complete) housings (car never came with the Xenon option from the factory)
3) OEM Euro front/rear (avant) beam-style wiper blades/arms (available via www.vagparts.com)
4) OEM B6 S4 Interior auto-dimming black mirror with compass and on/off button
5) OEM Euro blindspot exterior mirrors
6) OEM S6/4.2 exterior lower door trim
7) OEM S4/S6/S8 aluminum mirror housings
8) OEM Euro rear license plate panel from 2002+ facelift avant (slight MODification to US plate required)
9) ?
10) OEM Euro RNS-E DVD Navigation system with MP3, SAT control and TV input
11) Dietz 1417 A/V input to RNS-E
12) Blaupunkt ME3 DVD/CD/MP3/TV Tuner with aftermarket amplified TV antenna in windshield
13) OEM Sirius tuner (special version to work with RNS-E)
14) OEM Phatnoise Phatbox MP3 player (trunk mounted) with custom interface cable to allow Sirius tuner and Phatbox to work together -- cool!!
15) ?
16) BBS RC 17x8 ET35 with Michelin Pilot Sports (summer tires)
17) 2002+ Rear bumper with valance openings for Magnaflow 3" exhaust tips
18) OEM submarine fin roof antenna for SAT / GPS / Cellphone (GSM)
19) OEM Euro gunmetal black avant roof rails
20) 2002+ Climate control faceplate to match faceplate color of RNS-E
21) Walnut wood trim near hazard button (above RNS-E) to match rest of interior wood scheme
22) OEM Euro Avant door panels with integrated sunshades (imported from Germany to match the black leather in my Euro Recaro interior)
23) OEM Euro blacked out front grille (no chrome perimeter)
24) OEM gunmetal black lower rear hatch strip (specific part# for avant vs. sedan)
25) OEM RS6 gunmetal black interior door latches; no need to add any RS6 badges in my car (Thanks Nelson!!!)
26) OEM Euro four spoke walnut wood and black leather (special order via Audi GmbH) multi-function wheel with tip buttons and OEM phone (BT) control
27) Upgraded "618" MF/Tip control module
Coming soon:
- rear mounted removable 7" LCD panel
MODifications:
(Definition: Any permenant change to a part or component of your car that you cannot reverse)
1) Tray under armrest to add aux. cigarette lighter
2) OEM avant CD changer bracket MODified (to fit two large CD changers etc) - now I just use it for Phatbox, OEM SAT tuner and OEM BT module.
3) Exhaust tips MODified to add Magna Flow (#35163) 3" dual walled tip
4) Factory wiring behind Sym I to simplify installation/removal of RNS-E
5) MODified glovebox to support fitment of Blaupunkt ME3 (a biatch to install!!)
6) MODified headlight switch bezel for fitment of GALA switch for "video-in-motion" for playing Blaupunkt ME3 through RNSE
7) MODified stock exhaust and had magnaflow 3" tips welded on (see above)
8) MODified rear Euro license plate surround to house 2nd rear foglight (2001 model only came with one from the factory); US license plate needed to be MODified a bit to fit inside the narrow Euro opening.
RNS-E for C5 A6/S6/allroad/RS6 - your quest starts here - (regularly updated)
<a href="http://forums.audiworld.com/a6/msgs/607331.phtml">OEM submarine fin installed on
TeddyBGame is offline   Reply With Quote
Old 04-04-2005, 12:24 PM   #2
Boston Driver
AudiWorld Expert
Account #: 69482
Boston Driver's Avatar
Default I just picked up a set from ebay Germany (heated and autodimming)
because I kept seeing your references to the blindspot. I'll let you know when they come in so you can check them out. Price too low to advertise here!
2002 A6 4.2 Sport...with a few things added
Boston Driver is offline   Reply With Quote
Old 04-04-2005, 12:27 PM   #3
MCH 2.7t
Member
Account #: 68483
Default Great (and extensive) write-up!
MCH 2.7t is offline   Reply With Quote
Old 04-04-2005, 12:29 PM   #4
Grapeking
Account #: 18685
Default of course you did.... one more mod, coming up!
Grapeking is offline   Reply With Quote
Old 04-04-2005, 12:37 PM   #5
Boston Driver
AudiWorld Expert
Account #: 69482
Default Of course..for safety :)))
Old 04-04-2005, 12:46 PM   #6
kpereyra
New Member
Account #: 87016
Default Apparently you're fluent in German and Ebay-sien. What might the less fluent of us look for?
2001 A6 2.8 Quattro Racing Green Pearl / Melange Interior
Rondell #22 18"x8" Nitto 555 235/40/18
Koni Sports/ Eibachs/ H-Sports
RS6 "style" spoiler / S6 Door Blades / Clear Corners
Magnaflow 4" Exposed Exhaust Tips
Aux Power Mod / Hardwired Passport 8500/ XM
00032 Tip Recode / Window Recode
kpereyra is offline   Reply With Quote
Old 04-04-2005, 01:15 PM   #7
TeddyBGame
Member
Account #: 32631
Default I had to follow-up with your dynamat install. Nice work...BTW.
TeddyBGame
Accessory Add-ons:
Upgrades:
9) ?
15) ?
Coming soon:
MODifications:
Old 04-04-2005, 01:44 PM   #8
ECMEsq.
New Member
Account #: 75449
Default Good write-up. The new Saab 9-3s have this feature.
we owned one right after they came out (fall '02?) and it took some getting used to, particularly when you are in the passenger seat and try to look out the passenger side mirror. In general, however, it is a useful option. I don't know why other marques don't offer them in the U.S.
ECM
2004 A6 2.7T, 6spd, Prem., Lux., Cold Wthr., Sport Seats.
2004 Volvo V70 2.5T
2000 BMW 323ci (sold)
ECMEsq. is offline   Reply With Quote
Old 04-04-2005, 01:51 PM   #9
Kimchee
Member
Account #: 15573
Default another EXCELLENT write up!
Kimchee is offline   Reply With Quote
Old 04-04-2005, 02:55 PM   #10
Boston Driver
AudiWorld Expert
Account #: 69482
Default "audi spiegel original" = Audi mirror OEM
which will give you results for internal and external mirrors, external mirror glass, as well as mirror housings.
Then, you have to find a seller willing to ship "weltweit" = worldwide, or contact the seller, use an on-line translation (like Google language tools), and of course, apologize for the poor grammar.
Happy hunting!!!
Tags
a4, aftermarket, blindspot, bmw, climate, control, euro, faceplate, glass, heated, mirror, mirrors, parts, passenger, side
