Go Back   AudiWorld Forums » Audi Models » Audi A6 / S6 / RS 6 » A6 / S6 (C5 Platform) Discussion
Old 03-20-2004, 02:54 PM   #1
demon_s8
New Member
Account #: 62705
Default ac fan and compressor stay on??? on 2000 a6
does any one know why my ac compressor and fan wont turn off, even if my temperature is set to HI? this happens when i turn on my climate control ofcoarse when i run the vag com on it ti shows no errors.
demon_s8 is offline   Reply With Quote
Old 03-20-2004, 02:57 PM   #2
2.7T_RT(toofast)
Account #: 60878
Default The compressor always runs ulnless ECON is pushed AFAIK
go to dubya dubya dubya dot quattro world dot c o m
2.7T_RT(toofast) is offline   Reply With Quote
Old 03-20-2004, 03:44 PM   #3
demon_s8
New Member
Account #: 62705
Default Re: The compressor always runs ulnless ECON is pushed AFAIK
hmmm, you might be right. on a 99 that i had i never had that problem, the ac compressor& fan only came on when i had the temp set at low degrees?now even at HI which is supposed to be full heat , why would the compressor be on?
Old 03-20-2004, 06:29 PM   #4
paulroad
Account #: 63674
Default The compressor will act as a dehumidifier and stop the windows from fogging...
• 2003 audi allroad 2.7t 6 Speed
• 177,000 miles; bought new in May 2003
Mods
• APR 5.0, Stratmosphere Hyperboost Diverter Valves, AWE DTS, Toy Guy SS, RS6 Exhaust with Borla Tips
• HP2 reverse mod, ECS Slotted Rotors, Metal Master Pads, SS lines
• 402 down 20MM, RS6 Reps,
• Arnott Replacment Air Springs-Front
• OEM Trailer Hitch.
• New OEM Shocks at 140K.
• New OEM Clutch, Flywheel, Pressure Plate, Slave Cyl at 175K
• New Upper Control Arms, Tie Rod Ends and other suspension parts at 140k-175k
• check www.allroadfaq.com for some allroad information.
paulroad is online now   Reply With Quote
Old 03-20-2004, 07:13 PM   #5
demon_s8
New Member
Account #: 62705
Default this is not my front defrost that i am refering to. just period
i dont know, this is new to me. this is my forth audi. you might tbe right i probably never realized it? maybe that model year? i have a s8 also and it doesnt behave like that. and i also had a 99 2.8, and 00 4.2 and ditto. this one that i have now must of been built on a day that those people didnt want to work lol.
Old 03-21-2004, 12:45 AM   #6
Capt William
New Member
Account #: 58372
Default Unless you push the econ button the A/C is always on.
My wife's Lexus, my last BMW 740 and my daughter's new A4 all work the same way. They all have some way to turn off the A/C but it is normally always on.
Capt William is offline   Reply With Quote
Old 03-21-2004, 06:58 AM   #7
2.7T_RT(toofast)
Account #: 60878
Default Hijack, how do you like the APR? Do you have EMCS or a replacement ECU?
