| Register | Pictureposter | Classifieds | FAQ | Members List | Search | Today's Posts | Mark Forums Read | Garage | My Recent Topics | Dealer Listings |
| Notices |
Thread Tools | Search this Thread | Display Modes |
#1 |
Member
Account #: 51051
![]() I've been reading various posts about folks modifying their fog lights to allow operation w/o the head lights, and have been wanting to try that out myself. I liked the fuse taps/blocks that Richard Solomon used is his "tidy" version, but couldn't figure out where he got them. I was not that excited about having a separate fuse holder dangling around the fuse box and decided to try the following. Instead of piggybacking off fuse 27 and adding a fuse holder, I drew my power from fuse slot 41 (identified as vacant for my vehicle). The contacts for this slot are different that described by Richard - the right contact (when looking at the fuse box) is hot and there is no contact on the left. By inserting a 15A fuse and attaching the tap to the left side, I now have a fused lead to power the fog lights. I added a fuse tap to the right side of fuse 36 and used a small length of wire to connect the two taps. The fog lights can now be turned on whenever the parking lights are on. The parts were ~$5 at Radio Shack and the mod took about 10 minutes to complete (which included voltmeter time). Just thought I would share another option on how to mod your fog lights... Mod at your own risk.
2005 Boxster, Seal Grey Boxster S Wheels | Clear Side Marker Previous Audi's: 2002 TT Quattro Coupe, Lake Silver Metallic (traded in 3/7/09) 1998 A6 Quattro 2.8, Andorra Red (traded in 4/29/04) |
#2 |
Account #: 22012
It appears that your jumper is pushed onto one of the installed fuses (as if it had a spade sticking out of it, I know it doesn't). How did you get the spade into the fuse?
Is it attached to the blue fuses in the picture or is it below them? Thanks. pw
_________________________________ Paul Waterloo 01 S8 Black on Black Lots of Electronic Mods D2 A8/A8L/S8 FAQ Digest ![]() |
#3 |
Member
Account #: 28004
Is there a metal contact in the fuse holder on the non-hot side of fuse 41? If there is, do you know what you are now sending power to?
It definitely is much cleaner. Looks good!
#4 |
Member
Account #: 48069
Rules of turbo ownership! 1. Let them warm up until the oil temp gets to 175 degrees (at least). 2. Likewise, after a "spirited" run, let them cool off for a couple of minutes before you shut off the engine. 3. Use full synthetic engine oil - 0-40 is best! These rules apply regardless of the ambient temperature. A little caution should mean longer turbo life. To clarify, this doesn't mean you have to sit in your driveway for 5 minutes and let it warm up or cool down, it means you should use common sense and take it easy when you start/finish your trip. ![]() Stoney's FAQ <a href="http://forums.audiworld.com/s4/msgs/2008685.phtml"> a must read</a> Golf community and handicap tracking @ golfinity <a href="http://oldoakland.golfinity.com"> Old Oakland Golf Club</a> |
#5 |
Member
Account #: 51051
I used the fuse taps that are described in the Tech article. You can get a 4-pack from Radio Shack for a couple of $. The tap clips over the fuse blade and provide a spade terminal above the fuse. As for the connect, that is just a fully-insulated female quick disconnect connector (also from Radio Shack) that gets crimped onto the wire.
#6 |
Member
Account #: 51051
There was no metal contact on the other side of the fuse 41 slot. No power should be going anywhere other than to the other side of fuse 36.
#7 |
Account #: 22012
#8 |
Junior Member
Account #: 49437
RadioShack doesn't have em, but I found them at several Autozones I visited.
I have an extra set of them for anyone in the NYC area who wants to do the foglamp mod. I hooked up Brooklyn2.7t also.
Previous Thread
Next Thread
| Display Modes | |
Linear Mode
