Old 12-11-2008, 07:46 AM   #1
Roque
Junior Member
Account #: 124609
Default LOGS. APR Stage 3. 91 octane. Leak at compressor inlet. Bit lean?
Finally logged my car with ecux. I haven't found any APR stage 3, 91 octane logs so this is a good one for the archives.
I have a known leak at the driver's side compressor inlet, so some unmetered air is getting in. Am I running a bit lean?
I'll log again when I get around to removing the inlet pipe (pain in the ass) and see what's going on with the o-ring.
Does 4.4s FATS sound about right for 91 octane APR in an avant?
Stats:
Avant. ~4000 lbs during log.
Ambient = 65 F.
Altitude = 10 ft.
Relative Humidity = ~60%.
91 Octane.
APR Stage 3. Ver 2, 91 Octane code.
AWE Intercoolers.
APR Bipipe.
APR Stealth exhaust.
Piggie pipes.
BTW, Nye's ECUx Plot is the shiznit.
This plot has been adjusted to SAE conditions:
Roque is offline   Reply With Quote
Old 12-11-2008, 07:56 AM   #2
DocSlowMiniPerson
Junior Member
Account #: 142564
Default Not bad for a fairly conservative tune. You could try adding ~5% primary fuel to test a richer AFR.
Gone But Not Forgotten --> Midgyet Tuned Stg 3 2001.5 Nogaro S4
DocSlowMiniPerson is offline   Reply With Quote
Old 12-11-2008, 07:59 AM   #3
Roque
Junior Member
Account #: 124609
Default Do you think I'll be a bit richer when I fix my leak at the compressor inlet?
Old 12-11-2008, 09:48 AM   #4
TwentyValveB5+S4
AudiWorld Expert
Account #: 87200
Default That's what I was going to say too :)
I know I'm learning when I'm thinking like you and Nye...
His injectors are already close to maxed out, but I guess it doesn't hurt to try
2008 RS4, 2001.5 AWE Stage 3 S4
TwentyValveB5+S4 is offline   Reply With Quote
Old 12-11-2008, 09:50 AM   #5
nyet
Member
Account #: 13093
Default you might even go a bit more lean when you fix it. metered air is escaping right now.
add some pri if your trims aren't too bad.
"It's easier to practice medicine without a license in this country than it is to get info on tuning Motronic." -JasonS9
ECUxPlot - my java based ECUx/VAGCOM/VCDS plotter
My hacked version of Flyboy's ECUx template.
S4Wiki - CONTRIBUTE TODAY!
Web based FATS calculator for ECUx and VAGCOM logfiles
Sync your iPod under Linux!
Definitive S4 DIY Thread of Doom
AWOT Brain Trust #101
AWOT Axis of Evil Member #6
Member, Aw0t Fish Taco Dinner Club
I say to you that the VCR is to the American film producer and the American public as the Boston strangler is to the woman home alone." - Jack Valenti, President and CEO of the MPAA
this site is NOT for information sharing
it's strictly for multiple monologues
that result in none of the participants
changing their point of view
- frank
nyet is offline   Reply With Quote
Old 12-11-2008, 09:52 AM   #6
Roque
Junior Member
Account #: 124609
Default I think you read it incorrectly. The leak is on the INLET. So unmetered air is going in, not out.
All the metered air is going into the compressor and then some more is going in.
Old 12-11-2008, 10:17 AM   #7
nyet
Member
Account #: 13093
Default errr sorry. yea. my bad.
brainfart.
- frank
Old 12-11-2008, 10:53 AM   #8
Roque
Junior Member
Account #: 124609
Default No prob. I hope fixing the leak helps me a bit.
Old 12-11-2008, 11:33 AM   #9
OSin456
Junior Member
Account #: 42092
Default Or just add a meth kit to richen it up a tad.
For straight 91 that tune is just damn solid on 91. Not the fastest, but not pushing the turbos, no frills, just solid.
ASP Stage 3 Avant
<a href="http://www.wunderground.com/US/CA/Hermosa_Beach.html?bannertypeclick=big2">
</a>
OSin456 is offline   Reply With Quote
Old 12-11-2008, 12:30 PM   #10
DocSlowMiniPerson
Junior Member
Account #: 142564
Default It's almost in his favor that they're maxxed up top. Added primary will help mid-range only.
Gone But Not Forgotten --&gt; Midgyet Tuned Stg 3 2001.5 Nogaro S4
