Old 03-17-2008, 07:28 AM   #1
Mark@AutoSpeed
Banned
Account #: 93546
Default AutoSpeed is pleased to announce RS6 Turbo Kit Performance Numbers...
Hey Guys,
We worked out the issues we had with the RS6 wastegates on the turbos and now have performance data to back our kit.
The subject vehicle is a 2001 AllRoad (aka RMcQ) with forged rods and all other intake components stock spec, no RS4 power adders. ASP manifolds, DP's and FMIC.
The following dyno plots represent 93 Octane and VP109 Unleaded Racegas Profiles.
Note a healthy K04 car running 23psi on our dyno makes apporx. 350-360whp on 93 octane.
Here is what's included in our kit...
[2] Factory KKK RS6 TurboChargers
[1] Set K04 Inlet Tubes
[1] MAF Housing/Hose/Clamps
[6] 630cc Fuel Injectors/Hardware
[6] Bosch Spark Plugs
[1] ECT, Clip & Oring
[1] N75 Valve
[1] Bosch MotorSport 044 Fuel Pump, Backet & Strainer
[1] Turbo Hardware Kit
[1] ASP Software 93/109/valet/kill
List Price $6995
We believe we have the most comprehensive kit on the market. Also these are the only true
"bolt-on" solution requiring absolutely no modifications to any components. The other kits require you to have your existing downpipes cut apart and have flanges re-welded on.
Our software is the most advanced as we have reprogrammed the factory routines to allow for multiple programs switchable by the end user as well as have datalogging functionality with no need for 3rd party programs.
What this means is you and your dealer have the ability to datalog the car at lightning speeds, over 45 variables @ 30times a second! You send us the logs and we can then tweak your file for perfection. The dealer can then reflash your vehicle from our webserver within minutes.
Give us a call, let's make some power!
Mark@AutoSpeed is offline   Reply With Quote
Old 03-17-2008, 07:34 AM   #2
DocSlowMiniPerson
Junior Member
Account #: 142564
Default Very nice on all counts. Keep up the good work!
Gone But Not Forgotten --> Midgyet Tuned Stg 3 2001.5 Nogaro S4
DocSlowMiniPerson is offline   Reply With Quote
Old 03-17-2008, 07:37 AM   #3
visintainer [vis]
Member
Account #: 90752
Default nice work :)
MIKE SPOKANE, WA - PIGGIE POWERED
MY S4 WEBSITE/CLASSIFIEDS - E-MAil ME - TORQUE SPECS - PART #s - NOOBs CLICK HERE
Q U A T T R O W O R L D F T W
visintainer  [vis] is offline   Reply With Quote
Old 03-17-2008, 07:37 AM   #4
fussball.biturbo
Account #: 17850
Default the first graph is 93 octane
That's pump where I am, at least.
Sorry. Can't handle vB. I am now at:
http://www.quattroworld.com
fussball.biturbo is offline   Reply With Quote
Old 03-17-2008, 07:37 AM   #5
DocSlowMiniPerson
Junior Member
Account #: 142564
Default Heh, sorry. I missed that. I just edited before reading your response, actually. ;-)
Old 03-17-2008, 07:38 AM   #6
djillusion
Elder Member
Account #: 7258
Default is there a better upgrade path (ie cost) for those who are running ASP's K04 Stage 3 kit?
GO FAST / STOP FAST: KO4s | ASP Fueling Kit | AWE DPs + TPs | AWE Intercoolers | Miltek Super Dual Exhaust w/ Custom Tips | 710N BPVs | Stasis Motorsports | APR Snub Mount | UUC SS | ECS Stage 4 Brakes | ECS Rear Stage 1 Brakes | V1 Hardwired | Achtuning Oil Cooler | RS4 Clutch | Re-Surfaced Stock FW | Samco TBB | ASP TSB |
LIL SOMETHIN' ELSE: Euro Lights | Fog Light Mod | Custom A-Pillar w/ Prosport Boost Gauge | "S4" Shift Knob / RS4 Alcantara Shift Knob | Oettinger Front Grill / RS4 Grill | OEM RS4 Front | OEM RS4 CF Engine Covers | Rear M3 Lip Spoiler | 19x8.5" DCR Catalunyas | 235.35.19 Bridgestone KDWs | AL Sideview Mirrors | 20G Phatbox | Greddy TT | RNS-E NAV | Infinity Basslink | 35% Tint | Winter Setup: B6 S4 Avus 18" Wheels w/ 235.40.18 Hancook IceBear Winter Tires | 255 lph fuel pump | Zoldman O2 sensors | OEM RS4 Alcantara Steering Wheel
djillusion is offline   Reply With Quote
Old 03-17-2008, 07:40 AM   #7
Jeff 'S iv
Junior Member
Account #: 127620
Jeff 'S iv's Avatar
Default i cant see the graph on my phone what does it say!!
also do we have to do rods? I guess the hp will tell me.
Early 2000 6spd
Labree splits/
Twin 2,
Revo stage2/w sps3,
Avalon monstrous oil cooler,
phelonic spacers,
asp light weight crank pulley,
vast hi flo efk,low temp after fun, hyperboost dv's,evo intake
(ER's and k04 hybrids waiting for install)
Stasis rebuild / 4:1 center diff,
Vast ceramic clutch/lwfw,
JHM SS, ASP dts,Vast snub mount, RS4 tranny mounts,
Vogtland GT's, Kumho spt
rs4 bumper mod
piano black trim
Avic D3 with Bluetooth,Sirius,Ipod,cd changer
clear corners, independent fogs, dual rear fogs, m3 lip spoiler, chrome mirror caps,rims,tint,
Need a passenger rear door (silver)
Jeff 'S iv is offline   Reply With Quote
Old 03-17-2008, 07:41 AM   #8
Arcteryx::Stock Rods
Senior Member
Account #: 70072
Default my setup is perfect for that! way to go mark! except my CR and boost gauge ;)
Bored 2.8/9.1CR
JE Pistons/034 Rods/RS4 Heads
KO4's Port Polished/VAST Meth Injection
RS4 Intake Manifold/Throttle Body
X-1 Intake/ER IC's
ASP Exhaust Heads to Tips
Clutchmaster Stage IV with LWFW
STaSIS Ohlins 700/800 AWE DTS
Alcons 355 6 Piston BBK
Arcteryx::Stock Rods is offline   Reply With Quote
Old 03-17-2008, 07:45 AM   #9
My2ndS4
Member
Account #: 46878
Default Good job Mark, I love seeing new options (even if it's too late for me). :)
My2ndS4 is offline   Reply With Quote
Old 03-17-2008, 07:45 AM   #10
B5QShip
Account #: 78120
Default Looks great! I assume the 93 file was run on pump gas?
Runs were 4 min apart, I guess that's enough time to swap fuels?
B5QShip is offline   Reply With Quote
Tags
27t, audi, autospeed, catch, diagram, file, intake, k04, kit, oil, rs6, s4, sale, turbo, turbos, twin, upgrade
