Old 05-25-2007, 02:55 PM   #1
Cooper993
Member
Account #: 69944
Default Hockey Puck Mod. So I had enough with all the driveline movement I experience on a daily basis. I
already have the RS4 motor mounts, the snub mount, a DTS and a newly replaced rear differential mount. I noticed that when I had just replaced the rear mount, the car felt very "solid" for about 1.5 months, then after that it was back to the old way it used to feel.
I've seen the posts where some people had filled the bushing with caulk or rubber sealant, but I didn't want something that permanent in case I didn't like it. So after looking at the mount for a few minutes (I still had the old one sitting on my workbench), I decided to try something a little more "reversible".
So I went to the sports shop and bought a hockey puck ($1) and measured how thick it would need to be to minimize the play of the mount while still allowing for some flexibility. I came up with a measurement of 11 mm. So using a "jig" (made from 2 2x4's and a couple of clamps) I sliced the puck down to size on my table saw. I then measured how big the opening would need to be to slip around the bushing and cut a slot in the puck accordingly.
I then slid the puck into the mount and used a screw driver to push down the little "tabs" on the bushing so that I could really shove the puck in there
Once it was in place
I remounted the part. I only drove it around my neighborhood, but I noticed a real improvement. There still is some play (because I didn't make it as thick as I could), but so far so good.
If I decide I don't like it, it's fairly easy to slide the puck out and go back to stock.
B5 S4 Hockey Puck Mod
Cooper993 is offline   Reply With Quote
Old 05-25-2007, 03:21 PM   #2
sj6sp
Member
Account #: 31992
Default Nice! Mine really needs to be replaced. Waiting for the one PureMS has coming out...
Maybe I should give this a try.
<A HREF="http://www.marsavius.net/qclub" target="_blank">
</a>
sj6sp is offline   Reply With Quote
Old 05-25-2007, 03:21 PM   #3
~DonQPremiumTequila~
Account #: 68023
Default nice!
01 S4 6-speed stage 3.5
95 S6 avant very stock.. sold
95 90 quattro 5 speed winter car
MK3 (L322) Range Rover HSE full size with mods
Leader of the Anti Windows mobile militia Blackberry pimp..... NOW WITH the 3G IPHONE :-)
~DonQPremiumTequila~ is offline   Reply With Quote
Old 05-25-2007, 03:31 PM   #4
Cooper993
Member
Account #: 69944
Default Unless the bushing is torn, I don't think a new one will do anything. Mine had a lot of play in it
compared to the new one, but then the new one had the same amount of play in it in less than 2 months.
This took me less than an hour to do and cost me $1.00.
Let's see how long it lasts.
Old 05-25-2007, 03:54 PM   #5
Dr. Jekyll
Account #: 76012
Default PureMS told me that if the diff mount is shot to replace it. The one pureMS is coming out with is
just an insert, it's not a completely new diff mount.
Dr. Jekyll is offline   Reply With Quote
Old 05-25-2007, 04:23 PM   #6
EdyJun
Member
Account #: 48484
Default can you extend on "all the driveline movement" plz?
2000 Audi S4 STG 3
FATS = 3.66 w/ 91 oct
AIM: EdyJun
11 September 2001
In their honor. In their memory.
<font color="red">----------------------------------------------------------
<u><big>
<a href="http://homepage.mac.com/edyjun1/S4/index.htm">EdyJun's S4 Directory (FAQ, DIY, Info, Tips and Help)
</a>
</big> </u>----------------------------------------------------------
</font>
EdyJun is offline   Reply With Quote
Old 05-25-2007, 04:28 PM   #7
sj6sp
Member
Account #: 31992
Default Not sure what that means. Everything is intact, just lots of movement on/off throttle.
I thought the PureMS mount replaces the stock bushing.
</a>
Old 05-25-2007, 04:44 PM   #8
Aman_UnatrlyAspiratd
Member
Account #: 46274
Default good job man
Aman_UnatrlyAspiratd is offline   Reply With Quote
Old 05-25-2007, 05:43 PM   #9
visintainer [vis]
Member
Account #: 90752
Default i'm not installing my new mount till mike's insert comes out
MIKE SPOKANE, WA - PIGGIE POWERED
MY S4 WEBSITE/CLASSIFIEDS - E-MAil ME - TORQUE SPECS - PART #s - NOOBs CLICK HERE
Q U A T T R O W O R L D F T W
visintainer  [vis] is offline   Reply With Quote
Old 05-25-2007, 06:27 PM   #10
4Train
Junior Member
Account #: 115929
Default Nice Job...
2001.5 S4 Tip Stage 2+/EPL Custom Tune/ASP DP's/Tru Dual/RS4 Grill/Dahlback Diverters/KW V3 Coil Overs/AMS Custom Kevlar TBB/IPOD Integration/Hartmann RS4 reps/T1-R's/Stoptech 332/AWE Vent Boost Gauge/RNS-E Nav+...
<a href="http://www.wunderground.com/US/CT/Plymouth.html?bannertypeclick=big2">
</a>
<a href="http://www.nerdtests.com/nq_ref.html">
</a>
4Train is offline   Reply With Quote
