Old 10-30-2006, 12:10 PM   #1
Mark P
AudiWorld Expert
Account #: 139
Default Implemented some changes in the newest ECUx Templates (v11beta)
If you want to try them out, feel free to grab the latest from here:
http://ctny.audiworld.com/mark/s4/ecux/template11/
And if you do give them a try, please let me know any issues you encountered, etc.
Here are examples of some of the output of each:
Single-gear template example
Multi-gear template example
The one for multigear runs is basically complete (pending user comments). The single-gear pull version just has the additions to the 1st tab - I'm waiting until it's been refined enough before porting the changes to the other tabs.
The biggest change is that this version doesn't require one to use a specific group file to match the template. You can use your own group file, with variables in any order. You merely paste the corresponding column headers so the file knows what the data is.
Helpful Hint: When you first open up the csv file from your log, the cursor will already be in cell A1. Click ctrl-shift-<right_arrow> and it will highlight the header row. Then just do a ctrl-c and ctrl-v to copy/paste it into the templates.
In addition to that, I've also changed some of the Auto-Calculators to be more flexible...
In the single-gear-pull template:
- In the FATS calculator, I added the calculated/corresponding MPH for 4200/6500, so it is immediately obvious if the results are from a car with different gearing. Also it can be used to remind us what the startMPH and endMPH are for our normal FATS pulls - this info can then be used in the Any-Speed-Range calculator below for other cars to compare to ours.
- Previously there was a FATS+ 4000-7000 auto-calculator and corresponding graph. I've now changed this to an Any-RPM-Range Auto-Calculator, so the user can choose which range they want to measure time for. I left the startRPM and endRPM and 4000 and 7000, so it defaults to a FATS+ calculator, but a B5 A4 owner (for instance) could change that to the range for their CAPS time (3800-6500).
- I've also added a similar Any-Speed-Range Auto-Calculator. It could be used to check you car's performance compared to other cars results in magazines, etc (ie 50-70mph). Another reason for adding it was to allow better comparison of "FATS" to other cars. That is, cars that have different gearing would give non-comparable FATS results if you only were looking at the 4200-6500 RPM range. Now, those other cars can use this to enter ~57mph and ~91mph to see what their apples-to-apples FATS times are.
In the multi-gear template:
- I replaced the 0-100mph calculator with a similar Any-Speed-Range Auto-Calculator.
Mark P
Dyno: 469wHP / 451wTQ
93 oct - best 60':1.734 | best 1/4ET:12.239 | best 1/4mph:116.58
100+oct - best 60':1.698 | best 1/4ET:11.762 | best 1/4mph:121.72
Current:
'04 Porsche 911 Turbo, Speed Yellow - 21k miles
'02 Audi S4 Avant, Imola Yellow, APR Stg3 - imolavant website - 189k miles
'01.5 VW Golf 4dr 1.8T, Satin Silver, GT28R - Golf website - 200k miles
Previous:
'00 Audi A4 1.8T, Silver - Quattrobonium website
Mark P is offline   Reply With Quote
Old 10-30-2006, 12:22 PM   #2
PSmalls::AnalRetentiveNumbNut
Member
Account #: 112331
Default Very cool, Mark. I downloaded both templates, will give 'em a try.
Your templates are going to get me thrown in jail.
PSmalls::AnalRetentiveNumbNut is offline   Reply With Quote
Old 10-30-2006, 12:25 PM   #3
Mihnea
Junior Member
Account #: 25793
Default 2nd, gonna do a few runs tomorrow :D
RIP O.W. Kenobi
1998 Audi S4 2.7T, Stage 3+
-FMIC, ported/polished/clearanced K04s
-custom intake pipes, tubular manifolds
-custom dual 2.75" turbo back exhaust
-lowered compression
-RS4 transmission
511.5 crank HP/505 crank ft/lbs on DynoDynamics (391wHP)
2.8 FATS average on 92.5 octane
Status: awaiting patiently stage 4 a.k.a. RS6 turbos and mo' boost.
Mihnea is offline   Reply With Quote
Old 10-30-2006, 12:30 PM   #4
My2ndS4
Member
Account #: 46878
Default jeebus. I really need to get ecu-x
My2ndS4 is offline   Reply With Quote
Old 10-30-2006, 12:32 PM   #5
Ah10@WMS
Account #: 9327
Default I downloaded the new version and when i copy and paste previous log, the graphs are not showing up?
WMS: 818-997-6500 ASP:856-772-9500
|| ASP Custom Tuned Stage 3 || 710P || Piggie DP || ASP 89mm Truedual || ASP TSB || APR Boost Gauge || RS4 Grille ||
|| AWE Intercooler || C M Stage 4, 6 puck &amp; LWFW || ASP Motor Mount || RS4 Tranny Mount|| StaSIS Motorsport Ohlins ||
|| 18" Work W-ITS 901 || 245/35/18 ContiSport3 || Ecode || Modded RS4 Bumper || StaSIS Motorsport Alcon 6pot 355 ||
WMS Stage III: 3.54 fats on Pump 3.25 fats on Race gas both runs were on pump file
3.06 on East Coast Pump Gas/Race File
2.93 on East Coast Pump Gas/Race File in 40f weather
Ah10@WMS is offline   Reply With Quote
Old 10-30-2006, 12:32 PM   #6
jprice@CPS
Member
Account #: 8422
Default nice.. How about an ANY RPM time calc? Then us A4 folks can easily get CAPS times.
Or am I the only A4 folk that uses these? :-p
Minnesota Audi Club
2001.5 Audi A4 1.8TQMS
APR Stage 3+, APR Exhaust, Eibach Pro Street Coilovers, Neuspeed 19mm rear sway.
jprice@CPS is offline   Reply With Quote
Old 10-30-2006, 12:32 PM   #7
wagongotya
Elder Member
Account #: 90994
Default *sigh* 2nd
|sig|
EPL Custom Tune w/ OEM RS6 Turbos.
"I wish I could have a stage 3 car to be disapointed in. :-)" - IBG 2007-01-16 16:15:26
RIP O.W. Kenobi
|/sig|
wagongotya is offline   Reply With Quote
Old 10-30-2006, 12:33 PM   #8
Mark P
AudiWorld Expert
Account #: 139
Default you need to copy the corresponding header colum labels...
read my post above where it says "the biggest change is"
Mark P
Current:
Previous:
Old 10-30-2006, 12:34 PM   #9
Mark P
AudiWorld Expert
Account #: 139
Default how about you read my post before asking questions ;-)
look at the second really big green square in my post above ;-)
Mark P
Current:
Previous:
Old 10-30-2006, 12:34 PM   #10
Member
Account #: 112331
Default Works so awesome, Mark. I'm glad I can finally plug in old logs that don't use all the same variable
Tags
4200, 6500, apr, audi, ecu, ecux, fats, files, gauge, marks, mk2, s4, speed, template, test, vw
