Old 01-10-2006, 04:27 PM   #1
scalbert
Junior Member
Account #: 83037
Default Dyno Pull Shows Rich
We had an Atlanta area dyno session last Saturday and I still can't determine if these A/F numbers are correct.
mbox did a log and they showed somewhat rich throughout which is somewhat supported here. But the major drop between 3500 and 5000 RPM is what surprises me. It goes very rich but doesn't see to reflect this significantly in the torque. To me the torque curve looks about normal for the modifications and going this rich should have made a noticeable drop in torque.
Anyway, the car as it sits has GIAC X, piggy pipes and Borla exhaust. I was running 100 octane and the dyno seemed to be a bit generous this day. But all in all, there is enough there to get into the 12's...
scalbert is offline   Reply With Quote
Old 01-10-2006, 04:34 PM   #2
S4Fish
Junior Member
Account #: 94628
Default those are some damn good numbers for just GIAC X, piggies, and a borla. were u running XR?
-Sold, but not forgotten-
2001 S4, Brilliant Black
GIAC X
710n's
Evo Intake
Neuspeed G2 Exhaust
Samco TBB
Neuspeed Short Shifter
19" Flik Justice
235/35/19s Bridgestone Potenza RE750's
Intrax Springs/Koni Shocks
E-Codes
AWE Vent Boost Gauge
Vast Snub
H7 Hyper White Fogs
RS4 Grill with painted black trim
"street racing is like jacking off, every guy has done it. the ones who say they havent are lying." -Devious18t
the new s4:
AKA 2001 Corvette z06
S4Fish is offline   Reply With Quote
Old 01-10-2006, 04:38 PM   #3
scalbert
Junior Member
Account #: 83037
Default Nope, just plain old X...
As I said, it was a bit generous this day.
Old 01-10-2006, 04:39 PM   #4
Captain Matt, I be
Elder Member
Account #: 26545
Default its a dynojet.
Captain Matt, I be is offline   Reply With Quote
Old 01-10-2006, 04:41 PM   #5
Ochlockonee
Member
Account #: 72863
Default Did they use a tailpipe sniffer o2 sensor? The cats will skew things to the rich side.
"No, a flux capacitor is not compatible with a ham sandwich."
Ochlockonee is offline   Reply With Quote
Old 01-10-2006, 04:44 PM   #6
scalbert
Junior Member
Account #: 83037
Default Yes, tail pipe sensor but no pump system...
Just a WBO2 sensor in a mock up pipe in the stream. I also thought it would skew readings as well but it should do it somewhat linearly across the RPM band.
This was a change in a cretain RPM range only. The rest looked to be about where it shoudl be. For reference, my O2 voltages were in the 0.910 VDC range...
Old 01-10-2006, 04:49 PM   #7
siffer
Junior Member
Account #: 91036
Default 2nd, always higher.
siffer is offline   Reply With Quote
Old 01-10-2006, 04:51 PM   #8
Ochlockonee
Member
Account #: 72863
Default Yep, you're pretty rich. Check out this lambda/02 sensor voltage post--->
Old 01-10-2006, 05:27 PM   #9
PSmalls::DoggieStyle
Elder Member
Account #: 69223
Default To the rich side?
PSmalls::DoggieStyle is offline   Reply With Quote
Old 01-10-2006, 06:05 PM   #10
Ochlockonee
Member
Account #: 72863
Default Yes. The cats tend to combine any loose o2 molecules with carbon or hydrogen.
