Old 01-10-2006, 10:41 AM   #1
daseighty
Member
Account #: 80761
Default What size drill bit would give me the same diameter that a wheel bolt has? Eh?
Explained it kinda of ****ty in the title. I'm looking for a drill bit that will give me the required width needed to fit a stock wheel bolt into a wheel. Need to enlarge the holes in my new wheels. I thank you guys in advance.
daseighty is offline   Reply With Quote
Old 01-10-2006, 10:45 AM   #2
JasonS4+Festicle
Senior Member
Account #: 36810
Default not sure, but don't you think you might f up your rims doing it yourself? take them to a pro.
JasonS4+Festicle is offline   Reply With Quote
Old 01-10-2006, 10:46 AM   #3
B5QShip
Account #: 78120
Default 2nd, its not like drilling through a block of wood.....
i'd imagine you'd want a good press, a good bit, and some confidence in yourself to do that...
B5QShip is offline   Reply With Quote
Old 01-10-2006, 10:46 AM   #4
daseighty
Member
Account #: 80761
Default Not doing them myself, just want to know the size so I can get a bit for the shop. I'm anal...
I want to make sure the size is exact and I figured I'd ask AW before anyone else.
Old 01-10-2006, 10:50 AM   #5
Andrew C.
Account #: 560
Default can't you just compare to one of the wheels that's on your car?
- Andrew C.
now: 01.5 S4 Avant Pearl/Onyx Widebody
was: 98.5 A4 2.8 QMS Pearl/Ecru
Pearl White S4 Frappr
Andrew C. is offline   Reply With Quote
Old 01-10-2006, 10:54 AM   #6
daseighty
Member
Account #: 80761
Default I don't really feel like bringing an Avus wheel to Home Depot and matching up drill bits. ;)
Old 01-10-2006, 10:57 AM   #7
hadokenny
Junior Member
Account #: 69337
Default If you are taking it to a shop, they should be able to find out for you.
Currently a proud owner of a not-so-stock Casablanca S4 avant.
Stage 3 nogaro S4 (Gone)
hadokenny is offline   Reply With Quote
Old 01-10-2006, 10:59 AM   #8
ModifiedA4
AudiWorld Expert
Account #: 143
Default i think they are M12 or M14...
so if the nominal shank diameter is 14mm, 14/25.4=.551 inches.
so drill the hole out with a 9/16" (best) or 5/8" drill.
if they're M12, just redo the calc. for that
www.modifieda4.com
ModifiedA4 is offline   Reply With Quote
Old 01-10-2006, 11:03 AM   #9
Andrew C.
Account #: 560
Default wouldn't the person doing this for you have some drill bits?!?
- Andrew C.
Old 01-10-2006, 11:06 AM   #10
S4 SOM
Junior Member
Account #: 31255
Default if they don't ... I would run away
S4 SOM is offline   Reply With Quote
