Old 12-28-2005, 10:14 AM   #1
üBER.QIK
Junior Member
Account #: 41342
Default Gas smell resolved!
I've had a persistent gas smell whenever I fill the tank past half full. I found fuel residue under the passenger side of the gas tank (follow link below for some history).
I finally got around to fixing it. Here's how:
1. Remove the fuel pump fuse (fuse location 28 - bank of fuses nearest the front of the car, 3rd from the bottom).
2. Start the car and let it run out of gas (take a few seconds).
3. Disconnect the battery
4. Locate the 3-screw fuel tank access panel directly behind the rear passenger side seat under the trunk matting.
5. Remove the 3 philips screws to expose the Fuel pump cover. It will look like this:
6. Remove the electrical connector by firmly lifting it straight up (it should pop off easily).
7. Clean the area up with a soft brush and vacuum cleaner.
8. Losen the factory hose clamps by working them open with a screw driver (or some such tool). These are a pita to pull off - do not use excessive force and be patient! Place a rag under the hose as there may be a small amount of fuel leakage.
9. Work both hoses off by pushing on the hose from the connector side - while pulling from the other side.
10. Once both hoses are off, use a hammer and screw driver to gently drive the black plastic ring counter-clockwise (put screw driver on an angle on the 'nubs') until you can losen it by hand. Remove the black plastic ring completely.
11. Pull up the fueld pump cover plate and locate the large rubber gasket seal. Remove the rubber gasket by working it free from the fuel pump cover (note the gasket orientation).
Here's what mine looked like:
12. Intall the new gasket making sure its in the correct orientation (the gasket is only about $20 and is usually stocked by Audi).
13. Carefully replace the fuel cover. MAKE SURE THE SEAL BETWEEN THE GASKET AND THE FUEL TANK FITS PERFECTLY by working the gasket in place in a circular manner. Make sure there is no binding or pinching of the rubber material.
14. Replace the black ring by hand while you're pushing down on the fuel pump cover until it bites cleanly. Tighten it up by hand - then give it a few taps with a hammer/screw driver to make sure its snug.
15. Replace the hose clamps with new 1/2 inch galvanized clamps and secure firmly.
16. Replace the electrical connector.
17. Reconnect the battery and reinsert the fuel pump fuse.
18. Start the car and look for leaks before replacing the fuel pump service cover.
19 Once you've verified there are no leaks, replace the cover.
Gasket part number:
Recent upgrades: K04s, RS4 Clutch, RS4 Engine Mounts, GIAC 3- ECU, Hitachi MAF, Vast Snub
üBER.QIK Launch>
üBER.QIK is offline   Reply With Quote
Old 12-28-2005, 10:17 AM   #2
lemieux@curbside
Account #: 47312
Default good job man !!!
"it's a B5 S4 ,it may break down, but its far enough ahead, by the time its fixed, you still haven't caught up." -best line i've heard ;)
AUDI B5 S4 detail info (pdf file) that everyone should read and have saved on his computer
AUDI B5 RS4 study guide detail info (pdf file)
FATS database
VAG-COM LOCATOR
ASP Hands down the "BESTEST" tuner out there.
lemieux@curbside is offline   Reply With Quote
Old 12-28-2005, 10:45 AM   #3
Kris Hansen
Chief of Goat control
Account #: 20
Kris Hansen's Avatar
Send a message via MSN to Kris Hansen
Default Mind if I grab this for the tech section?
Kris Hansen is offline   Reply With Quote
Old 12-28-2005, 11:11 AM   #4
UberVier
Account #: 17771
Default well done , sir, and good write-up.
UberVier is offline   Reply With Quote
Old 12-28-2005, 12:19 PM   #5
üBER.QIK
Junior Member
Account #: 41342
Default go for it
üBER.QIK Launch>
Old 12-28-2005, 12:43 PM   #6
Kris Hansen
Account #: 20
Default Thanks!
Old 12-28-2005, 01:40 PM   #7
Milpitas2.7T
Elder Member
Account #: 6383
Default kudo's... you list the part number somewhere?
Milpitas2.7T is offline   Reply With Quote
Old 12-28-2005, 02:24 PM   #8
OCA::DIY Motorsports
Member
Account #: 60276
Default Can I submit an article to you?
SUPPORT STEM CELL RESEARCH!
"There are (shop)whores that do provide a valuable service. However, you appear as a whore with no orifices, therefore all you accomplish is space occupation." --Kartman
"Those who would give up ESSENTIAL Liberty to purchase a little temporary safety, deserve NEITHER liberty nor safety"
Benjamin Franklin
OCA::DIY Motorsports is offline   Reply With Quote
Old 12-29-2005, 11:17 AM   #9
üBER.QIK
Junior Member
Account #: 41342
Default Here's a shot of the packaging.....
üBER.QIK Launch>
Old 01-06-2006, 10:25 AM   #10
Kris Hansen
Account #: 20
Default Please do!!! Encourage EVERYONE to submit articles to the Tech section
