Old 12-12-2005, 12:46 PM   #1
archimense
Account #: 86435
Default How do you mount a front license plate?
My used S4 came with no front license plate mount.
Are there clips hidden somewhere or do you have to drill into the bumper?
I'm going to try to get away without having a front plate, but I would like to know how I would mount it if I needed to.
Thanks.
2001.5 Audi S4 Stage 3
Stasis Tracksports 700/800 and 4:1 centre diff
CPP front upper arms, tie rod ends, rear end links, rear toe links
Neuspeed 22mm Rear Sway
ASP Tru Dual downpipes and exhaust
Custom chip with 60lb injectors and 85mm MAF
55w Xtec HIDs
etc etc etc
archimense is offline   Reply With Quote
Old 12-12-2005, 12:49 PM   #2
S4Poor@Curbside
Member
Account #: 98473
Default Start drilling. If you need (sounds like you do) a bracket, you can have my old one...
S4Poor@Curbside is offline   Reply With Quote
Old 12-12-2005, 12:56 PM   #3
archimense
Account #: 86435
Default Well if I need to drill I think I will wait until I am forced to.
55w Xtec HIDs
etc etc etc
Old 12-12-2005, 01:04 PM   #4
3Scanner
Member
Account #: 43051
Default <waiting for WindyCityS4 to come to the rescue - best solution, btw>
3Scanner is offline   Reply With Quote
Old 12-12-2005, 01:11 PM   #5
addìct
Member
Account #: 43942
Default Remove the center piece
in the bumper by pulling down. See if you have holes drilled already. If not, well your going to have to drill if you want a front plate on there.
2008 Quartz a4 2.0tqm - Current
2000 Imola s4 - Sold
2000 Nogaro s4 - RIP
addìct is offline   Reply With Quote
Old 12-12-2005, 01:16 PM   #6
archimense
Account #: 86435
Default Ah, that makes sense. Thanks for the info. I will check.
55w Xtec HIDs
etc etc etc
Old 12-12-2005, 01:54 PM   #7
gandolf the white
Junior Member
Account #: 78036
Default you don't they're ugly and you get worse MPG :-)... just use double sided tape, sign off, and remove
"It is so choice. If you have the means, I highly recommend picking one up."
gandolf the white is offline   Reply With Quote
Old 12-12-2005, 03:08 PM   #8
WindyCityS4
Account #: 52314
WindyCityS4's Avatar
Default Are you sure it was me? I don't run a front plate.
I bounced around a few ideas, but since I don't go into the city anymore (the hot zone for tickets) I never executed any.
In a world of constant change, it is the learners that shall inherit the future. For the learned soon find themselves capable of living in a world that no longer exists.
Autobahn Country Club (North, South, combined), Blackhawk Farms, Gingerman, Grattan, Mid-Ohio, Putnam Park, Road America, Thunderhill
WindyCityS4 is offline   Reply With Quote
Old 12-12-2005, 03:43 PM   #9
TwinTurboTerror
Member
Account #: 3779
Default No need to drill. Here's what I did for my RS4 bumper:
Use only the top piece:
Bolt the plate onto the plastic bracket:
Then apply lotsa moulding tape and stick it on the bumper.
It's held up for me for about 1/2 a year now.
TwinTurboTerror is offline   Reply With Quote
Old 12-12-2005, 03:50 PM   #10
3Scanner
Member
Account #: 43051
Default hmmm....I thought it was you, Darryl...I know it was another silver S4 with RS4 bumper...Hmmm.
Tags
a4, audi, front, license, mount, plate
