| Register | Pictureposter | Classifieds | FAQ | Members List | Search | Today's Posts | Mark Forums Read | Garage | My Recent Topics | Dealer Listings |
| Notices |
Thread Tools | Search this Thread | Display Modes |
#1 |
Member
Account #: 43051
The kit with O.W. Kenobi's writeup
I couldn't find the firewall-run similar to where O.W. Kenobi suggested in his write-up; it's pretty sparce in there and I didn't want to ruin the hood release firewall grommet... ![]() ...so I decided to go through the ECU cover ![]() Ran the transponder cable to the controller cable like I was supposed to ![]() Sealed up the ECU cover and made all the electical connections near the fuse box (speaker, LED, switch, T1, power, ground) ![]() Shot of transponder routed under the hood with sound deadening cover off for easier access ![]() Tapped the 6mm hole for the LED near the top of my steering wheel moulding and made small slit to acordian-like cover for better fitment ![]() First test fire...everything worked...nothing started smoking or blew up (yes, that's 12:05 a.m. EST this morning...ugh!) ![]() Reinstalled lower dash cover and discretely placed the toggle switch for easy access ![]() Taped down cable before leveling transponder ![]() Dremmelled grill ring area ![]() Closeup shot ![]() View from behind ![]() Closeup of LE-30 installed in grill location ![]() Transponder leveling check and taped down ![]() Pics this morning of front facia ![]() Closeup shot of grille ![]() Front of car without flash to show normal lighting ![]() Front of car with flash to higlight reflective areas on car (notice how the license plate and headlights glow - lasers are aimed at these locations for a reason) ![]() So far, all of the visual and audible cues are working properly on the LE-30 (I get the appropriate beeps and light flashes to indicate that the sytem is on). However, I haven't been able to test the unit with a simulated laser yet. I tried using a t.v. remote, but the signal was too week and only slightly set off my V1 and not my LE-30. Does anyone have suggestions on what I should use to do a full functional test besides buddying up with my local law enforcement pals? Oh, one more item...the LED comes wired to light up in green and turns red only when it is triggered. I switched the connection points around (red to black and vice versa) so that it stays on in red (to match the cabin lighting) and turns green when activated. Hope everyone finds these pictures helpful and it will compel you to go and install your system this weekend instead of letting it collect dust in the closet...yes, Oo.et.oO, I'm talking to you! (j/k - I'll give you a hand if you need) Thank god for O.W. Kenobi's tech writeup; it was invaluable in helping me get through this mod. In terms of difficulty, I give it a "Two Band-Aid" rating out of five. For more information and the non attention-deficit-disorder version, please STFA or check out O.W Kenobi's writeup below.
#2 |
Member
Account #: 98473
#3 |
Elder Member
Account #: 65572
id be willing to help you out and sacrifice my stock one for you.
i wont even charge you. you send me yours and ill send you mine.
![]() ![]() MY BABIES a.k.a. CARS you want the best for your car? tell him i sent you. FATS database ![]() ![]() NOT stock ;^P nogaro 6mt my00, casa 6mt my01.5
#4 |
Member
Account #: 43051
#5 |
Audiworld Sponsor
Account #: 6924
Very different products.
-Dave Pramanik |
#6 |
Member
Account #: 43051
#7 |
Member
Account #: 98473
#9 |
Elder Member
Account #: 65572
#10 |
Member
Account #: 43051
Previous Thread
Next Thread
| Display Modes | |
Linear Mode
