Old 11-29-2005, 12:32 PM   #1
3Scanner
Member
Account #: 43051
Default Need advice for good location to install Lidatek LE-30 transponder with RS4 bumper...
I've STFA, seen sample photos and read write-ups for placing the unit behind the grille area. I'd like to attach it in a different location since (a) I'm worried that the jarring caused by opening an closing of the hood might affect the transponder's position if it is placed in behind the main grille and (b) my license plate sits very low on my RS4 bumper, so I'd like to get the transponder as close to the plate and main bumper cover facia as possible.
Here's a picture of where I'm thinking of installing the single transponder (I need to save up more $$$ before I can get a second transponder). I will likely pick the area highlighted in red on the driver's side as my first option.
I noticed that there aren't too many places behind the lower grille area where I can attach the transponder's brackets, since the RS4 bumper mounting areas behind the lower grill section are different from the stock bumper. If any of you have the RS4 bumper and have done a similar type of install please offer advice.
TIA.
3Scanner is offline   Reply With Quote
Old 11-29-2005, 12:36 PM   #2
DanosS4
Member
Account #: 33628
Default cut out one of the bars and mount it inside one of the audi rings, if it will fit.
mine is mounted to one of the flat bars on the stock grill.
DanosS4 is offline   Reply With Quote
Old 11-29-2005, 12:42 PM   #3
3Scanner
Member
Account #: 43051
Default Yes, but won't it sit too high from where my license plate is currently located? How about ...
movement after you slam the hood close? Have you had to adjust the transponder at all over time because of the jarring?
Old 11-29-2005, 12:46 PM   #4
DanosS4
Member
Account #: 33628
Default it's never moved
Old 11-29-2005, 01:03 PM   #5
Audeye A6
Member
Account #: 67177
Default I think it would better and more concealed there.
2001 2.7T / 6spd / Cold Weather Pkg. / Premium Pkg.
EPL Custom Tuned Stage III / 93 Oct
710N's
Bilstein-HD / B&G Sport Coils / H-Sports
KO4/997 Hybrids
Autospeed MAF
60 lb injectors
RS4 Accordion tube
Kevlar Clutch,PP & Throwout bearing
Autospeed Trans. stabilizer bar
AWE/McNeil Downpipes/graphite rapped
AWE/McNeil Intercoolers
APR exhaust/snub mount
Port/Polished/Ceramic coat exh. mani's
JHM short shifter
Hardwired/stealth V1
Digital Boost gauge
Debadged
Audeye A6 is offline   Reply With Quote
Old 11-29-2005, 01:10 PM   #6
TwinTurboTerror
Member
Account #: 3779
Default Did you fill in the euro plate indent on your bumper? Otherwise I'd suggest mounting your plate the
way I have on my car (with moulding tape).
TwinTurboTerror is offline   Reply With Quote
Old 11-29-2005, 01:28 PM   #7
EdyJun
Member
Account #: 48484
Default What state are you in, are radar (laser) jammers legal in your state?
I am in CA and if a cop here suspects that I have one he has the right to search my car. So I am still trying to find a way to install it that the cop can not find it.
Edy
2000 Audi S4 STG 3
FATS = 3.66 w/ 91 oct
AIM: EdyJun
11 September 2001
In their honor. In their memory.
<font color="red">----------------------------------------------------------
<u><big>
<a href="http://homepage.mac.com/edyjun1/S4/index.htm">EdyJun's S4 Directory (FAQ, DIY, Info, Tips and Help)
</a>
</big> </u>----------------------------------------------------------
</font>
EdyJun is offline   Reply With Quote
Old 11-29-2005, 01:39 PM   #8
Beeman'S4
Junior Member
Account #: 40407
Default Federal level, radar detectors legal, radar jammers illegal (under FCC jurisdiction), laser jammers
legal (under FDA jurisdiction).
I know some states (VA, and another one out West?and all of Canada IIRC) laser detectors also illegal.
00 S4 Silver/Black
darintake (my way), RS4 airbox top, RS4 MAF housing
allroad p/p intake mani (F hose delete!) with ASP phenolic intake spacers
AWE IC's (IPP's up for sale)
allroad TB, fuel rail, VAST tweaker chip, 37# delphis, MBC and TCD
K04/RS6 'brids, p/p, clearanced hot side, z/c coldside with Induktion oil lines
Piggie pipes, Twin 2
Achtuning OCK
VAST kevlar clutch w/ re-surfaced and balanced flywheel
APR bi-pipe, snub mount
RS4 motor mounts, AWE DTS
19mm rear sway bar - awaiting install
spare ECU with GIAC IBE2 w/ X, XR, etc.
(shouldn't have started the mod thing)
EPqC - Events and More...
Beeman'S4 is offline   Reply With Quote
Old 11-29-2005, 01:58 PM   #9
O.W. Kenobi
R.I.P.
Account #: 20137
Default Mine hasn't fallen out of adjustment since I mounted it.
I replaced the foam tape once, but that was it. Otherwise, it's been trouble-free and it's worked very well. You get an 18 inch radius, so you should be fine there.
O.W. Kenobi is offline   Reply With Quote
Old 11-29-2005, 02:58 PM   #10
3Scanner
Member
Account #: 43051
Default No, bumper indent still there. Where is your transponder located?
