Old 10-13-2005, 04:34 PM   #1
EdyJun
Member
Account #: 48484
Default EdyJun's HP and Torque Estimation.
This is done using the torque values that the ECU uses to manage the car. (These numbers are what the ECU uses/sees from the engine)
Using this together with FATS would give you a great way to gauge your car's performance, and also will let your see how and where different aftermarket part will help @ different RPM.
For example:
I did 2 runs, first in 57 deg weather and the second in 80 deg. You can see how the out side temperature will effect the HP and Tq. Between 3K - 4.5K RPM is where the biggest differences are.
By adding better IC you can see if the HP and Tq have changed, better IC will cool better so you gain a bit more between 3K-4.5K RPM (just an example) in hotter weather (90+ deg) and you can see the effects of heat soak @ different RPM.
You can measure the difference in HP and Tq for any part that changes how your car runs and performs and the best part is that its is visual and you can see where it plays the biggest roll.
This type of HP and Tq estimation is not accurate but it is very precious. Since it depends on the data from the ECU, much like FATS.
Keep in mind: the condition of your engine/car , gas, weight, road conditions, altitude have not been taking into effect. But since you will not be changing altitude or car weight as often I would expect it to be very accurate for caparison runs ON YOUR OWN CAR.
For example, my Estimated HP and Tq is 286 and 272 for Run 1 respectively. That those not mean that my car is actually producing that at the crank but what the ECU sees.
If I add an aftermarket ECU the HP and Tq may change to 346 and 380. The Delta will be what the gain or loss is. This type of estimate is very accurate at showing the Delta of such change. But the base line would be off a bit.
If you send me a log of (VAG-Com) bock 120 ONLY as if you were doing FATS in 3rd gear I can generate this HP and Tq estimate for you. Make sure you also provide your car's spec i.e. stage, also make sure that you can get a valid FATS for your log.
Edy
[list][*]Click here to see the Excel file with detail information of the Runs > Stock - 57 deg vs. 80 deg HP
2000 Audi S4 STG 3
FATS = 3.66 w/ 91 oct
AIM: EdyJun
11 September 2001
In their honor. In their memory.
<font color="red">----------------------------------------------------------
<u><big>
<a href="http://homepage.mac.com/edyjun1/S4/index.htm">EdyJun's S4 Directory (FAQ, DIY, Info, Tips and Help)
</a>
</big> </u>----------------------------------------------------------
</font>
EdyJun is offline   Reply With Quote
Old 10-13-2005, 04:56 PM   #2
Flyboy
Member
Account #: 4736
Default I thought the consensus was that Blk 120 was not valid for a chipped ECU.
<url="http://www.myaudis4.com/index.htm"> <img]http://www.myaudis4.com/sig.gif</img></url>
<url="http://www.motorists.org/">National Motorists Association</url>
Flyboy is offline   Reply With Quote
Old 10-13-2005, 05:17 PM   #3
nobodeuno
Account #: 25538
Default Dude you have the longest sig I've every seen...
I guess its at least helpful
-Justin-
01.5 S4, Santorin, 6 speed
::APR V5::
::Eibach Pro Street S Coilovers::
::AWE Twin2::
::ASP TSB w/ Vast Snub::
::Adjustible ToyGuy SS::
::AMS TBB w/ 710N's::
::20gb Phatbox::
::HCB-700 BT Kit::
::Painted RS4 Grill::
nobodeuno is offline   Reply With Quote
Old 10-13-2005, 07:09 PM   #4
EdyJun
Member
Account #: 48484
Default At least 1 Chipped ECU was used to check the cal. and it was fine.
But if some one can send me more Logs of block 120 i can check.
Edy
2000 Audi S4 STG 3
AIM: EdyJun
11 September 2001
<u><big>
</a>
</font>
Old 10-13-2005, 10:13 PM   #5
Sl!p
New Member
Account #: 91862
Default Would this work for Tip owners?
2001.5 Tip Laser Red S4, GIAC Flashed, 710N's, Samco TBB, VDO Boost Gauge, Borla Exhaust.
Sl!p is offline   Reply With Quote
Old 10-14-2005, 10:36 AM   #6
EdyJun
Member
Account #: 48484
Default If you can do FATS, i can make your a HP + Tq estimation.
2000 Audi S4 STG 3
AIM: EdyJun
11 September 2001
<u><big>
</a>
</font>
Old 10-14-2005, 10:36 AM   #7
EdyJun
Member
Account #: 48484
Default Re: If you can do FATS, i can make you a HP + Tq estimation.
2000 Audi S4 STG 3
AIM: EdyJun
11 September 2001
<u><big>
</a>
</font>
