Old 06-25-2005, 04:03 PM   #1
denic992-- JAYHAWK
Junior Member
Account #: 54392
Default Made a few pulls on a dyno, numbers inside...
Made three pulls on a Dynojet, Dont have a working scanner right now, but here are the numbers.
Run1: 292.1 hp/ 369.2 ft-lbs
Run2: 276.3 hp/ 337.2 ft-lbs
Run3: 255.4 hp/ 307.2 ft-lbs
Mods are listed in my sig. I was pretty happy with the results. Wasnt really hoping for anything, I have just always wanted to check out the AWD Dyno at the local Porsche dealership and make a few pulls on it.
It was Hot, mid to upper 90's, and I was running 93 octane, no lemmi tweaks. As you can see heatsoak played a major factor. AWE IC's are next!
2000 S4 6-Spd AUTOSPEED STAGE 3
08/99 Build Date
ASP Software w/ M-box conversion
Plain K04's
MBC in parallel w/ N75 @ 22psi
ASP MAF w/ hitachi sensor
42 lb delphi injectors
Bosch plugs
ASP Phenolic intake spacers
K&N panel filter w/ BIG hole in airbox
Walbro 255lph pump
RS4 intercoolers/shrouds/modded brackets w/ APR hose kit
AMS tbb
710N bpvs
Piggie Pipes + AWE Twin1
Clutchmasters Stage 3 w/ stock flywheel
RS4 tranny mounts
RS4 motor mounts
ASP tranny stabilizer bar
APR snub mount
Redline tranny/diff fluid
Koni shocks
Vogtland springs
Neuspeed 19mm rear sway
Mintex Red Box pads
ECS stainless steel lines
Motul Fluid
OEM RS4 bumper + grille
E-codes
HID Fog Lamps
35% tint
Tires: 235/45/17 Pirelli m+s
Lidatek LE-30 Laser Jammer
AWE vent boost gauge
RS4 shift knob
AWE pedals
12" Infinty sub
Xtant amp
denic992-- JAYHAWK is offline   Reply With Quote
Old 06-25-2005, 04:16 PM   #2
AUDIS4BI:Vintage
Elder Member
Account #: 58652
Default Nice, good numbers.
AUDIS4BI:Vintage is offline   Reply With Quote
Old 06-25-2005, 04:18 PM   #3
wagongotya
Elder Member
Account #: 90994
Default solid #'s, those wheels are ohhhh so hot
|sig|
EPL Custom Tune w/ OEM RS6 Turbos.
"I wish I could have a stage 3 car to be disapointed in. :-)" - IBG 2007-01-16 16:15:26
RIP O.W. Kenobi
|/sig|
wagongotya is offline   Reply With Quote
Old 06-25-2005, 05:22 PM   #4
Fixn2xlr8
Junior Member
Account #: 90271
Fixn2xlr8's Avatar
Default Damn, wheel hp? Not bad. I gotta get mine done sometime. Heat soak does seem to hurt huh.
Audi Haiku:
The Spinning Turbo - Rejoice! The Air Becomes Speed! - My Money Is Gone.
Fixn2xlr8 is offline   Reply With Quote
Old 06-25-2005, 08:38 PM   #5
The R
Senior Member
Account #: 3387
Default You have cats or no? Either way, nice numbers!!!!!!!
Rob aka "The 4DR Assassin"
Captain of the S4 Rowing Team
00 S4 Silver/Silver
93 Corrado SLC
90 Beretta GTZ
Audi S4: It speaks softly, but carries a big stick!
"You must be fast...cuz I was haulin' a$$ when I passed you!"
"BUT do not look down on B5 as they will bite you in the ass with vengeance" by Oggie_s
The R is offline   Reply With Quote
Old 06-26-2005, 01:30 AM   #6
burningcoals
New Member
Account #: 70753
Default Nice! A box is really strong for AMS!
X Sauce
RS4 Grill
RS4 Clutch
RS4 18" Reps
Custom SS
AWE Twin1
AWE A-Pillar BG
APRV1 Downpipes
Test Pipes
StaSIS Streets
Forge BPV
20% Tint
Phatnoise
MBC
Ready to be installed:
K04's and assorted hardware...
burningcoals is offline   Reply With Quote
Old 06-26-2005, 11:25 AM   #7
denic992-- JAYHAWK
Junior Member
Account #: 54392
Default no precats, still running main cats tho
08/99 Build Date
Plain K04's
Bosch plugs
Walbro 255lph pump
AMS tbb
710N bpvs
RS4 tranny mounts
RS4 motor mounts
APR snub mount
Koni shocks
Vogtland springs
Mintex Red Box pads
Motul Fluid
E-codes
HID Fog Lamps
35% tint
RS4 shift knob
AWE pedals
12" Infinty sub
Xtant amp
