Old 02-07-2005, 03:03 PM   #1
EdyJun
Member
Account #: 48484
Default Audi Certified Pre-Owned Coverage List
I thought this may be useful
These are the parts covered under CPO.
Part ID Description
1009 ENGINE BLOCK
1010 ENGINE CRANKCASE
1011 FREEZE PLUG
1013 PISTON COOLING OIL JET
1031 ENGINE MOUNT/CARRIER
1035 RUBBER MOUNT
1050 CRANKCASE BREATHER
1053 CRANKCASE BREATHER PIPE
1058 HEATING PIPE HARNESS
1062 INTERMEDIATE PLATE
1082 SOUND ABSORBER PAN
1310 PISTON
1319 PISTON RING SET
1326 PISTON PIN
1330 CONNECTING ROD BEARINGS
1340 CONNECTING ROD
1348 CRANKSHAFT
1350 CRANKSHAFT BEARINGS
1359 CRANKSHAFT OIL SEAL - FLYWHEEL SIDE
1360 FLYWHEEL
1362 DUAL MASS FLYWHEEL
1363 TORQUE CONVERTER DRIVING PLATE
1366 ENGINE SPEED SENDER WHEEL
1367 CRANKSHAFT NEEDLE BEARINGS
1370 SPUR BELT DRIVE SPROCKET
1373 BELT TENSIONER DAMPER
1374 CRANKSHAFT OIL SEAL
1375 VIBRATION DAMPER
1376 CRANKSHAFT PULLEY
1377 IDLER PULLEY ASSEMBLY
1391 CHAIN TENSIONER
1392 SPROCKET
1505 CAMSHAFT
1507 CAMSHAFT SPROCKET
1510 CAMSHAFT BEARINGS
1512 HUB FOR SENDER WHEEL
1514 CAMSHAFT OIL SEAL - TOOTHED BELT SIDE
1516 CAMSHAFT SEAL
1517 INJECTION PUMP SPUR BELT COVER
1519 TOOTHED BELT RELAY ROLLER
1520 INTERMEDIATE SHAFT
1523 INTERMEDIATE SHAFT OIL SEAL
1524 TOOTHED / TIMING BELT - CHECK MAINT. RECORD
FIRST
1525 DAMPER
1526 TOOTHED BELT TENSIONER
1527 TOOTHED / TIMING BELT TENSIONER PULLEY
1533 TIMING CHAIN HOUSING COVER
1535 TIMING CHAIN
1536 TIMING CHAIN TENSIONER
1550 HYDRAULIC LIFTER
1553 MIXTURE PIPE
1559 CAM FOLLOWER
1560 INTAKE VALVE
1562 EXHAUST VALVE
1563 VALVE STEM SEAL
1565 VALVE SPRING
1569 PRESSURE LIMITING VALVE
1570 CYLINDER HEAD
1571 CYLINDER HEAD GASKET
1572 CYLINDER HEAD BOLT
1573 EXH. MANIFOLD STUD
1575 INTAKE VALVE GUIDE
1576 EXHAUST VALVE GUIDE
1580 CYLINDER HEAD COVER GASKET
1582 CYLINDER HEAD COVER
1584 CAMSHAFT ADJUSTER
1585 CONTROL HOUSING
1587 TOOTHED BELT COVER
1700 OIL PUMP/GASKET
1704 OIL PRESSURE SENDER
1705 OIL PRESSURE SWITCH
1707 OIL TEMPERATURE SENSOR
1708 OIL PRESSURE WARNING CONTROL UNIT
1711 OIL SENSOR
1714 OIL FILLER CAP / GASKET
1715 OIL FILLER NECK / GASKET
1716 OIL DIPSTICK
1720 OIL PUMP / GASKET
1721 MOUNTING BRACKET
1722 OIL PUMP DRIVE
1724 OIL PRESSURE RELIEF VALVE/SPRING
1726 PCV VALVE
1733 OIL FILTER FLANGE
1735 OIL COOLER THERMOSTAT
1740 OIL COOLER
1745 UPPER OIL PAN
1750 OIL PAN - NO OUTSIDE INFLUENCE
1751 OIL PAN GASKET
1752 OIL HOLDER
1772 OIL COOLER LINES
1799 LOW OIL/PRESSURE WARNING SWITCH
1905 FAN
1908 FAN MOTOR
1909 RADIATOR FAN MOTOR SERIES RESISTOR
1910 COOLANT FAN CONTROL RELAY
1911 ENGINE COOLANT LEVEL SENSOR
1913 COOLANT FAN THERMOSWITCH
1918 COOLANT LEVEL RELAY
1920 COOLANT FAN HOUSING
1924 RADIATOR COWL
1940 EXPANSION TANK
1945 AUXILIARY COOLANT PUMP
1946 AUXILIARY COOLANT PUMP CONTROL UNIT
1949 VISCOUS COUPLING
1950 COOLANT PUMP
1951 COOLANT PUMP GASKETS
1952 COOLANT PUMP GASKETS
1953 COOLANT PUMP PULLEY
1955 THERMOSTAT HOUSING
1957 HOUSING WITH IMPELLER
1958 COOLANT THERMOSTAT
1960 COOLANT HOSE FLANGE
1961 COOLANT LINE
1970 RADIATOR
1975 CAP
1977 AFTER RUN THERMOSWITCH
1978 TEMPERATURE SENDING UNIT
1979 RADIATOR FAN RUN-ON CONTROL RELAY
1983 HYDRAULIC MOTOR
1990 ENGINE PREHEATER
2005 FUEL FILLER CAP / GASKET
2007 FILLER NECK
2010 FUEL TANK
2015 FUEL GAUGE SENDER UNIT
2017 VENT SYSTEM HOSE
2019 GRAVITY VALVE
2020 EXTERNAL EXPANSION TANK
2022 EVAPORATIVE EMISSION LINES
2024 EVAPORATIVE EMISSION CANISTER PURGE SOLENOIS
VALVE
2025 EVAPORATIVE EMISSION CANISTER
2026 FUEL GAUGE SENDER UNIT 2
2028 FUEL RESERVOIR
2030 TRANSFER PUMP SCREEN
2033 FUEL PREHEATING VALVE
2035 COOLANT LEVEL SWITCH
2036 TEMPERATURE SENDER
2038 FUEL FEED LINE
2039 FUEL RETURN LINE
2040 NON-RETURN VALVE
2044 FUEL LINE
2048 LEAK DIAGNOSIS PUMP
2049 FUEL TANK SHIELD
2050 INTAKE PUMP
2057 PRESSURE DAMPER
2058 FUEL ACCUMULATOR
2059 FUEL PUMP CONTAINER
2064 TRANSFER PUMP
2065 FUEL PUMP RELAY
2066 FUEL PUMP
2068 FUEL TANK COOLER
2070 FUEL PUMP CONTROL UNIT
2071 SHUT-OFF VALVE
2073 FUEL RETURN LINE
2078 ACCELERATOR PEDAL VALVE SENDER
2082 STANDARD TRANSMISSION ACCELERATOR CABLE
2083 AUTO TRANS/ACCEL.CABLE
2084 AUTOMATIC TRANSMISSION / THROTTLE VALVE
ACCELERATOR CABLE
2085 AUTOMATIC TRANS. LINKAGE SHAFT
2086 RETURN SPRING
2113 AIR INTAKE HOSES
2118 BLOW-OFF VALVE
2129 EXHAUST MANIFOLD
2130 TURBOCHARGER
2132 DELFLECTOR PLATE
2135 COOLANT PIPE
2141 PRESSURE HOSE
2151 INTAKE AIR TEMPERATURE SENSOR
2157 CONNECTING PIPE
2158 WASTEGATE
2163 VACUUM CANISTER
2164 OVER RUN CUT-OFF VALVE
2165 WASTEGATE CONTROL LINE
2167 BYPASS CONTROL UNIT
2168 PRESSURE SENDER
2169 SOLENOID SHUT-OFF VALVE
2170 MICRO SWITCH
2171 OIL INPUT LINE
2178 OIL RETURN LINE
2190 SAFETY PRESSURE SWITCH
2227 PREHEATER HOUSING
2293 CHOKE HEATING HOSES
2328 AIR HOSE
2329 INJECTION PUMP
2330 FUEL INJECTOR LINE
2332 POTENTIOMETER
2335 PART LOAD SWITCH
2340 FUEL INJECTOR
2348 FUEL SHUT - OFF SOLENOID
2358 TEMP SENSOR
2359 AIR MASS METER
2360 EDC CONTROL UNIT
2361 VOLTAGE PROTECTION RELAY
2364 TEMPERATURE SENSOR
2365 IDLE SPEED STABILIZING VACUUM UNIT
2367 SOLENOID VALVE
2380 INTAKE MANIFOLD
2425 AIR CLEANER
2426 TEMPERATURE REGULATOR
2431 HEATER PIPE
2432 HEATER PIPE WIRING HARNESS
2433 TWO-WAY VALVE
2434 THROTTLE VALVE CONTROL PART
2436 AIR INTAKE HOSES
2438 INTAKE AIR DUCT
2439 SERIES RESISTOR
2440 FUEL INJECTOR
2441 FUEL DISTRIBUTION RAIL
2442 THROTTLE VALVE HOUSING
2444 THROTTLE VALVE SWITCH
2445 MASS AIR FLOW SENSOR
2446 AIR INTAKE DISTRIBUTOR
2447 INTAKE MANIFOLD
2453 ALTITUDE UNIT
2458 FUEL PRESSURE REGULATOR
2460 COLD START VALVE
2461 THROTTLE POSITION SENSOR
2462 TEMPERATURE SENSOR
2463 HIGH PRESSURE PUMP
2464 MANIFOLD CHANGE-OVER VALVE
2468 HEATED OXYGEN SENSOR RELAY
2469 FRONT HEATED OXYGEN SENSOR
2470 ELECTRONIC CONTROL MODULE
2472 VOLTAGE SUPPLY RELAY
2473 POST HEATED OXYGEN SENSOR
2477 NOISE DAMPER
2480 IDLE SPEED CONTROL MODULE
2481 IDLE STABILIZER
2483 VACUUM HOSES
2485 INTERMEDIATE FLANGE
2488 INTAKE AIR TEMPERATURE SENSOR
2505 IDLE SPEED CONTROL MODULE
2506 DECELERATION SWITCH RELAY
2507 IDLE STABILIZER THERMOSTAT
2508 BAROMETRIC ABSOLUTE PRESSURE SENSOR
2510 HEATED OXYGEN SENSOR
2511 FUEL SYSTEM MANAGEMENT CONTROL MODULE
2512 FUEL MANG. CONTROL MODULE
2513 DIFFERENTIAL PRESSURE REGULATOR
2514 POTENTIOMETER
2516 FREQUENCY VALVE
2517 PULSE RELAY
2519 COOLANT TEMPERATURE SENSOR
2523 ANTI-BACKFIRE VALVE
2525 AIR CLEANER HOUSING
2527 AIR INTAKE ELBOW
2530 FUEL INJECTOR LINES
2531 INJECTOR COOLING BLOWER MOTOR
2532 BLOWER MOTOR SWITCH
2533 AIR DEFLECTOR PLATE
2534 INJECTOR COOLING RELAY
2536 PRESSURE GRADIENT SWITCH
2540 FUEL INJECTOR
2541 FUEL INJECTOR GASKET
2543 FUEL INJECTOR INSERT
2544 THROTTLE VALVE HOUSING
2546 WARM-UP REGULATOR
2547 OVERRUN CUT-OFF VALVE
2549 THERMO TIME SWITCH
2550 AUXILIARY AIR REGULATOR
2555 PRESSURE REGULATOR
2558 IDLE STABILIZER
2560 FUEL DISTRIBUTOR
2561 PRESSURE RELIEF VALVE
2562 AIR FLOW SENSOR ASSEMBLY
2566 VACUUM RESERVOIR
2567 VACUUM BOOSTER
2568 IDLE AIR CONTROL VALVE
2569 IDLE SPEED BOOST RELAY (CANADA)
2574 THROTTLE POSITION SWITCH/SENSOR
2580 INTAKE MANIFOLD
2609 EXHAUST MANIFOLD GASKET
2610 EXHAUST MANIFOLD
2615 HEAT SHIELD
2637 CHANGE-OVER VALVE
2639 EGR VALVE
2640 COMBINATION VALVE
2641 VACUUM HOSE
2642 EGR TEMPERATURE SENSOR
2643 EGR COOLER
2644 SECONDARY AIR CHANGE-OVER VALVE
2654 THERMO VACUUM SWITCH
2655 SECONDARY AIR INJECTION RELAY
2665 SECONDARY AIR INJECTION PUMP MOTOR
2677 AIR PUMP PULLEY
2680 CATALYTIC CONVERTER TEMPERATURE SENSOR RELAY
2712 BATTERY COVER
2713 HEAT INSULATION
2722 GENERATOR
2724 GENERATOR MOUNTING BRACKET
2730 GENERATOR PULLEY
2750 VOLTAGE REGULATOR
2753 SUPPRESSOR
2760 STARTER
2764 SOLENOID
2766 INTERLOCK RELAY FOR STARTER
2782 CRUISE CONTROL UNIT
2783 CRUISE CONTROL LINKAGE
2785 CRUISE CONTROL INDUCTIVE TRANSMITTER
2789 CRUISE CONTROL PEUMATIC CON ELEMENT
2790 CRUISE CONTROL VENTILATION VALVE
2792 CRUISE CONTROL VACUUM PUMP
2804 IGNITION STARTER SWITCH
2807 IGNITION LOCK CYLINDER
2810 STEERING LOCK
2815 IGNITION BUZZER RELAY
2817 IGN COIL POWER OUTPUT STAGE
2820 IGNITION COIL
2822 IGNITION (IDLE SPEED CONTROL) MODULE
2823 IGNITION SYSTEM (HALL/TCI) CONTROL MODULE
2825 IGNITION SYSTEM CONTROL MODULE
2827 TEMPERATURE SENSOR
2829 IGNITION TIMING POINT
2830 DISTRIBUTOR ASSEMBLY
2839 CAMSHAFT POSITION SENSOR
2842 VACUUM UNIT
2847 DISTRIBUTOR BRACKET
2848 DISTRIBUTOR DRIVE
2853 SPARK PLUG WIRE
2859 RELAY BOX
2871 TDC SENSOR
2872 KNOCK SENSOR
2873 IMPULSE SENDER
2883 GLOW PLUG CONNECTOR
2884 GLOW PLUG
2885 GLOW PLUG RELAY
2886 GLOW PLUG CONTROL LIGHT
2887 GLOW PLUG CONTROL UNIT
2888 COOLANT HTR ELEMNT RELAY
3009 OVER CENTER SPRING
3010 SELF ADJUSTING CLUTCH CABLE
3012 CLUTCH CABLE
3019 STARTER INHIBITOR SWITCH
3020 CLUTCH MASTER CYLINDER
3023 PRESSURE LINES
3030 CLUTCH SLAVE CYLINDER
3035 OPERATING SHAFT RETURN SPRING
3037 OPERATING SHAFT
3040 RELEASE SHAFT BUSHING
3043 PUSH ROD SEAL/BUSHING
3045 CLUTCH RELEASE BEARING
3047 GUIDE SLEEVE
3065 CLUTCH HOUSING
3070 ECOMATIC CONTROL UNIT
3073 PRIORITY SWITCH
3078 ENGINE SPEED SENSOR
3080 GEAR DETECTION SWITCH
3081 GEAR MONITOR SWITCH
3247 TORQUE CONVERTER OIL SEAL
3250 TORQUE CONVERTER
3251 TORQUE CONVERTER BUSHING
3407 GEARSHIFT LEVER BEARING
3408 GEARSHIFT BLOCK
3410 GEARSHIFT HOUSING
3412 SHIFT CABLE
3414 SELECTOR CABLE
3416 PUSH ROD / CABLE
3417 GEARSHIFT ROD
3419 SHIFT ROD EXTENSION
3420 CONNECTING ROD
3421 GEARSHIFT BUSHINGS
3422 WEIGHTED SHIFT ROD
3423 SHIFT ROD CLAMP
3424 SHIFT LEVER SPRING
3425 COMPLETE SHIFT ROD COUPLING
3427 SELECTOR LEVER
3429 CONSOLE - HINGE FUNCTION,NOT APPEARANCE
3431 RELAY SHAFT
3432 MOUNTING BRACKET
3434 SHIELD
3436 GEAR CARRIER
3437 TRANSMISSION HOUSING
3438 TRANSMISSION SUPPORT
3440 RUBBER MOUNT
3443 BREATHER VALVE
3444 SELECTOR SHAFT COVER
3445 SHIFT HOUSING
3446 SHIFT HOUSING GASKET
3447 SELECTOR SHAFT BUSHING
3448 SELECTOR SHAFT SEAL
3449 COVER
3450 GEAR CARRIER
3451 GEAR CARRIER GASKET
3453 VIBRATION DAMPER
3457 OIL DRAIN PLUG
3458 FREE WHEEL LOCK CONTROL UNIT
3459 FREE WHEEL LOCK POSITIONER
3460 DIFFERENTIAL LOCK ELEC CTL UNIT
3462 DIFFERENTIAL LOCK SWITCH
3463 DIFFERENTIAL LOCK VACUUM ACTUATOR
3464 DIFFRTL.LOCK SWITCH/DISPLAY RETAINER
3465 VACUUM RESERVOIR
3467 CHECK VALVE
3468 DIFFERENTIAL LOCK VALVE/SWITCH
3469 VACUUM LINES
3472 OIL PUMP
3476 TRANSMISSION COOLING PIPE
3504 1ST-4TH GEAR OUTPUT SHAFT
3514 SHIFT FINGER
3516 SHIFT ROD
3517 REVERSE LEVER
3518 SELECTOR SHAFTS
3521 FIRST / SECOND GEARSHIFT FORK
3523 THIRD / FOURTH GEARSHIFT FORK
3524 FIFTH / REVERSE GEARSHIFT FORK
3527 REVERSE SELECTOR SHAFT
3529 FIFTH GEARSHIFT FORK
3530 SHIFT LOCK PINS
3533 SELECTOR PLATE, GEARS 1-4
3534 SELECTOR PLATE, GEAR 5
3535 SELECTOR PLATE, REVERSE GEAR
3540 MAIN SHAFT
3543 ADJUSTING SHIM
3546 FRONT MAIN SHAFT BEARING
3547 CENTER MAIN SHAFT BEARING
3548 REAR MAIN SHAFT BEARING
3550 MAIN SHAFT OIL SEAL
3555 REV. GEAR SHAFT
3557 REVERSE GEAR PINION SHAFT
3559 OUTPUT SHAFT
3560 FRONT PINION BEARING
3561 REAR PINION BEARING
3566 2ND/3RD GEAR SYNCHRO.ASSEMBLY/SYNCRO
3567 4TH/5TH GEAR SYNCHRO.ASSEMBLY/SYNCRO
3568 FIFTH / REVERSE GEAR SYNCHRO HUB
3570 1ST/REVRS.GEAR SYNCHRO.ASSEMBLY/SYNCRO
3571 FIRST GEAR SET
3572 SECOND GEAR SET
3573 THIRD GEAR SET
3574 FOURTH GEAR SET
3575 FIFTH GEAR SET
3577 REVERSE GEAR IDLER
3580 NEEDLE BEARINGS
3581 FIRST / SECOND CLUTCH GEAR
3582 THIRD / FOURTH CLUTCH GEAR
3585 FIFTH GEAR LOCKING RING
3591 FIRST GEAR SYNCHRONIZER RING
3592 SECOND GEAR SYNCHRONIZER RING
3593 THIRD GEAR SYNCHRONIZER RING
3594 FOURTH GEAR SYNCHRONIZER RING
3595 FIFTH GEAR SYNCHRONIZER RING
3596 REVERSE GEAR SYNCHRONIZER RING
3705 SELECTOR LEVER
3707 PARK / NEUTRAL SWITCH
3708 SELECTOR MECHANISM BRACKET
3709 DRIVE PROGRAM SELECTOR
3710 SELECTOR LEVER HOUSING
3713 SHIFT LOCK IGNITION CABLE
3715 SELECTOR LEVER CABLE
3717 FRONT SHIFT ROD
3718 TIPTRONIC SWITCH
3724 TRANSMISSION GEAR DISPLAY
3726 TRANSMISSION SPEED SENDER
3730 TRANSMISSION CONTROL MODULE
3731 MULTI - FUNCTION SWITCH
3732 VEHICLE SPEED SENSOR
3737 TRANSMISSION HOUSING
3738 TRANSMISSION SUPPORT
3739 PROTECTIVE PLATE
3740 LEFT RUBBER MOUNT
3741 REAR RUBBER MOUNT
3745 ATF FILLER PIPE
3750 GASKET
3755 ATF PAN
3756 OIL PAN GASKET
3786 SHIFT LEVER LOCK
3787 SHIFT LOCK ELECTRO MAGNET / SOLENOID SWITCH
3788 SHIFT LOCK RELAY
3805 PLANETARY GEARS COMPLETE
3810 MAIN SHAFT
3814 ONE - WAY ROLLER CLUTCH
3815 ONE-WAY CLUTCH
3825 FORWARD PLANETARY GEAR
3826 REVERSE PLANETARY GEAR SET
3827 PLANET PINION CARRIER
3830 SMALL SUN GEAR
3831 LARGE SUN GEAR
3832 B1 BRAKE
3833 B2 BRAKE
3835 FORWARD CLUTCH
3837 K3 CLUTCH
3838 K1 CLUTCH
3839 K2 CLUTCH
3844 DIRECT/REVERSE GEAR CLUTCH
3850 GEARSHIFT COMPONENTS
3853 2ND GEAR BRAKE BAND
3856 ATF PUMP
3859 PUMP SHAFT
3860 ATF COOLER
3861 OIL COOLER HOSE
3862 ATF COOLER HOSE
3864 1ST GEAR BRK PISTON
3865 2ND GEAR BRAKE PISTON
3868 GOVERNOR
3874 PARKING LOCK LEVER
3877 VALVE BODY
3878 VALVE BODY CONDUCTOR STRIP
3901 FINAL DRIVE ASSEMBLY
3902 PROP SHAFT
3905 DIFFERENTIAL CASE
3906 DRIVE SHAFT BEARING - TRANSMISSION SIDE
3908 RING GEAR / PINION
3910 DIFFERENTIAL HOUSING
3912 DIFFERENTIAL SIDE GEARS
3916 DIFFERENTIAL BEARINGS
3918 INTERMEDIATE GEAR BEARINGS
3920 FINAL DRIVE SIDE COVER / GASKET
3921 COVER / GASKET
3922 DRIVE SHFT FLANGE OIL SEAL - NO COVERAGE IF
NORMAL WEAR
3923 OUTPUT SHAFT
3924 BEARING HOUSING
3925 LEFT / RIGHT DRIVE SHAFT FLANGE
3927 DRIVE FLANGE BOLT
3928 ENGINE SIDE OUTPUT SHAFT OIL SEAL-NOT COVERED
FOR NORMAL WEAR
3929 DIFFERENTIAL LOCK OIL SEAL
3930 OUTPUT SHAFT BEARING
3932 INTERMEDIATE SHAFT SEAL
3933 FRONT DIFFERENTIAL LOCK
3935 COMPLETE CENTRAL DIFFERENTIAL LOCK
3936 TORSEN DIFFERENTIAL LOCK
3940 REAR DIFFERENTIAL LOCK
3942 DIFFERENTIAL LOCK SWITCH
3945 ALL WHEEL DRIVE RING GEAR / PINION
3946 ALL WHEEL DRIVE DIFFERENTIAL HOUSING
3950 SPEEDOMETER DRIVE GEAR
3951 ALL WHEEL DRIVE DIFFERNTIAL SUN GEARS
3954 ALL WHEEL DRIVE DIFFERNTIAL BEARINGS
3955 PROP SHAFT FLANGE SEAL- NOT COVERED FOR NORMAL
WEAR
3956 REAR DRIVE SHAFT BEARING
3957 FRONT DIFFERENTIAL BEARING
3958 ALL WHEEL DRIVE FINAL DRIVE COVER
3959 ALL WHEEL DRIVE FLANGED SHAFT SEAL
3960 VISCOUS COUPLING
3962 TRANS OIL PUMP
3963 ALL WHEEL DRIVE LEFT / RIGHT DRIVE SHAFT FLANGE
3971 HALDEX CLUTCH
3982 FRONT PROP SHAFT OIL SEAL
3988 ALL WHEEL DRIVE FINAL DRIVE ASSEMBLY
3989 ALL WHEEL DRIVE FINAL DRIVE HOUSING
3993 ALL WHEEL LOCK CONTROL UNIT
3994 HALDEX COUPLING PRE-CHARGE PUMP
4001 FRONT AXLE
4006 FRONT AXLE PLATFORM
4007 SUBFRAME / CARRIER
4008 LOWER CONTROL ARM SUPPORT
4011 FRONT AXLE SUPPORT MOUNTING
4012 GUIDE LINK MOUNTING
4013 UPPER GUIDE LINK
4014 RADIUS ROD
4015 UPPER CONTROL ARM
4016 LOWER GUIDE LINK
4017 LOWER CONTROL ARM
4019 ECCENTRIC BUSHING
4020 CONTROL ARM BUSHING
4034 UPPER BALL JOINT - FOR FACTORY DEFECT, NOT WEAR
4036 LOWER BALL JOINT - FOR FACTORY DEFECT, NOT WEAR
4041 DRIVE SHAFT
4043 DRIVE SHAFT SHIELD
4044 INNER C.V. JOINT - FOR FACTORY DEFECT, NOT WEAR
4045 OUTER C.V. JOINT - FOR FACTORY DEFECT, NOT WEAR
4046 DRIVE SHAFT DAMPER
4047 INNER DUST SLEEVE - FOR FACTORY DEFECT, NOT WEAR
4048 OUTER DUST SLEEVE - FOR FACTORY DEFECT, NOT WEAR
4049 DUST SLEEVE CLAMP
4050 WHEEL BEARING HOUSING
4053 STEERING KNUCKLE
4057 INNER WHEEL BEARING
4058 OUTER WHEEL BEARING
4060 FRONT WHEEL BEARING SEAL
4064 FRONT WHEEL HUB
4075 COIL SPRING
4077 STABILIZER BAR
4078 STABILIZER BAR CONNECTING LINK
4080 STABILIZER BAR RUBBER BUSHING
4089 SHOCK ABSORBER CAP
4091 DUST BOOT
4093 AXIAL BALL BEARING
4095 CAP
4096 SHOCK ABSORBER UPPER MOUNTING
4098 RUBBER STOP
4099 UPPER SPRING PLATE
4204 REAR AXLE BRACKET
4205 REAR AXLE
4206 AXLE BEAM
4207 SUPPORT
4208 REAR AXLE BONDED MOUNTING
4209 TRACK ROD - FOR FACTORY DEFECT, NOT WEAR
4211 TRAILING ARM
4213 TRANSVERSE SUSPENSION ROD
4214 TRANSVERSE SUSPENSION ROD BEARING
4216 BONDED RUBBER BUSHING
4217 CONTROL ARM BUSHING
4220 BALL JOINT - FOR FACTORY DEFECT, NOT WEAR
4221 DRIVE SHAFT
4224 INNER C.V. JOINT - FOR FACTORY DEFECT, NOT WEAR
4225 OUTER C.V. JOINT - FOR FACTORY DEFECT, NOT WEAR
4228 INNER DUST BOOT - FOR FACTORY DEFECT, NOT WEAR
4229 OUTER DUST BOOT - FOR FACTORY DEFECT, NOT WEAR
4233 STUB AXLE
4234 STUB AXLE
4235 UPPER LINK
4237 LINK MOUNTING
4250 INNER WHEEL BEARING
4252 WHEEL BEARING HOUSING
4258 INNER WHEEL BEARING
4259 OUTER WHEEL BEARING
4261 WHEEL BEARING SPACER
4264 WHEEL BEARING SEAL
4267 WHEEL HUB WITH BEARING
4268 WHEEL HUB
4272 COIL SPRING
4288 UPPER SPRING SEAT
4290 STABILIZER BAR
4291 STABILIZER BAR LINK
4294 SHOCK ABSORBER BRACKET
4295 BEARING RING
4296 SHOCK ABSORBER BOOT
4298 REAR AXLE RUBBER STOP
4310 SELECTOR SWITCH
4313 WIRING HARNESS FOR SELF-LEVELING SYSTEM
4315 COMPRESSOR
4316 CONTROL UNIT
4317 CONTROL UNIT RELAY
4318 FRONT LEVEL SENSOR
4319 SENDER FOR SELF-LEVELING SYSTEM
4321 SELF COUPLING ROD ALL ROAD
4323 VALVE UNIT
4324 AIR PIPE
4325 AIR SPRING
4329 RUBBER BUMP STOP
4334 BODY SENSOR
4366 SPRING DAMPER
4367 DAMPER SETTINGS SWITCH
4368 SUSPENSION SETTING SWITCH
4378 OIL RESERVOIR
4382 PRESSURE ACCUMULATOR
4383 REGULATING VALVE
4385 PRESSURE HOSE
4386 RETURN FLOW HOSE
4432 WHEEL ELECTRONICS
4434 TIRE PRESSURE CONTROL UNIT
4511 FRONT SPEED SENSOR
4515 REAR SPEED SENSOR
4520 ACCELERATION SWITCH
4526 FRONT TOOTHED ROTOR
4527 REAR TOOTH ROTOR
4530 HYDRAULIC UNIT
4531 PRESSURE WARNING SWITCH
4532 PRESSURE REGULATING VALVE
4533 VALVE ASSEMBLY
4535 RETURN FLOW PUMP
4538 BRAKE PEDAL POSITION SENSOR
4539 CONTROL LINES
4540 ABS CONTROL UNIT
4541 ASR SWITCH
4545 ABS CONTROL UNIT
4546 ABS WIRING HARNESS
4548 EDL CUT-OUT RELAY
4549 ABS LIGHT CONTROL UNIT
4550 ABS RELAY
4551 RETURN PUMP RELAY
4552 SOLENOID VALVE RELAY
4553 VOLTAGE PROTECTION RELAY
4555 ANTI-LOCK SWITCH
4557 ACCELERATION SENSOR
4558 ESP RPM SENSOR
4559 ESP ACCELERATION SENSOR
4560 ESP STEERING SENSOR
4562 ESP CONTROL UNIT
4563 ESP SWITCH
4564 ESP PRIMER PUMP
4566 ESP PRESSURE SENSOR
4570 ADR CONTROL UNIT
4608 BRAKE PEDAL BUSHING
4609 BRAKE PEDAL RETURN SPRING
4611 MASTER CYLINDER PUSH ROD
4615 REAR BACKING PLATE
4617 FRONT SPLASH SHIELD
4618 REAR SPLASH SHIELD
4626 REAR HARNESS
4639 WEAR INDICATOR CONTACT
4650 FRONT BRAKE DISC / NOT COVERED FOR WEAR RELATED
ISSUES
4653 REAR BRAKE DISC / NOT COVERED FOR WEAR RELATED
ISSUES
4659 PARKING BRAKE RELEASE
4661 PARKING BRAKE LEVER
4667 PARKING BRAKE LEVER MOUNTING
4672 LOCKING PAWL
4675 COMPENSATOR LINKAGE
4676 COMPENSATOR LINKAGE
4679 PARKING BRAKE CABLE
4680 SELF ADJUSTING WEDGE
4682 RETAINING SPRING PIN
4685 SPREADER LEVER
4688 RETURN SPRING
4690 PARKING BRAKE WARNING LIGHT SWITCH
4694 BRAKE PAD WEAR INDICATOR RELAY
4710 FLUID RESERVOIR
4711 FLUID LEVEL SENSOR
4714 MASTER CYLINDER PLUG
4715 MASTER CYLINDER
4719 LEFT FRONT LINE
4720 RIGHT FRONT LINE
4722 CENTER LINE
4723 LEFT REAR LINE
4724 RIGHT REAR LINE
4726 FRONT HOSE
4728 REAR HOSE
4732 RIGHT REAR CONNECTING LINE
4733 LEFT REAR CONNECTING LINE
4739 FRONT CALIPER - FOR DEFECT, NOT SEIZED FROM RUST
4741 REAR CALIPER - FOR DEFECT, NOT SEIZED FROM RUST
4750 PRESSURE REGULATOR
4752 PRESSURE REGULATOR TORSION SPRING
4760 VACUUM BOOSTER RESTRICTOR
4766 WARNING SWITCH
4766 ACCUMULATOR PRESSURE WARNING SWITCH
4768 PRESSURE ACCUMULATOR
4770 POWER BRAKE VACUUM / HYDRAULIC UNIT
4771 POWER BRAKE BRACKET
4772 PUMP TO ACCUMULATOR PRESSURE HOSE
4773 RETURN HOSE
4774 ACCUMULATOR TO BOOSTER PRESSURE LINE
4775 POWER BRAKE CHECK VALVE
4776 VACUUM PUMP
4777 VACUUM HOSE
4779 POWER BRAKE VACUUM/HYDRAULIC UNIT
4810 STEERING WHEEL / NOT FOR APPEARANCE FROM WEAR
4813 SWITCH HOUSING
4814 UPPER STEERING SHAFT
4816 LOWER STEERING SHAFT
4817 STEERING SHAFT COLUMN
4818 HEIGHT ADJUSTABLE STEERING SHAFT COLUMN
4819 LOWER STEERING COLUMN BEARING
4820 UPPER STEERING COLUMN BEARING
4822 LOWER STEERING COLUMN BEARING
4823 STEERING COLUMN ELECTRIC HEIGHT ADJUSTMENT
4824 RETAINING CLAMP
4833 COUPLING DISC
4840 STEERING GEAR
4842 STEERING BOX RELAY
4847 STEERING HYDRAULIC PUMP
4853 BELLOWS
4855 BOOT
4869 SERVOTRONIC CONTROL UNIT
4876 LIMITING VALVE
4879 TIE RODS - DEFECT ONLY, NOT WEAR AND TEAR
4884 POWER STEERING PUMP REPAIR KIT
4888 STEERING DAMPER
4889 CONTROL LINE
4890 POWER STEERING GEAR
4891 POWER STEERING GASKET SET
4892 POWER STEERING FLUID COOLER
4893 SUCTION HOSE
4894 PRESSURE HOSE
4895 RETURN HOSE
4896 POWER STEERING FLUID LEVEL SENSOR
4897 POWER STEERING FLUID RESERVOIR
4898 POWER STEERING PUMP
4899 POWER STEERING PUMP PULLEY
5038 LOCK CARRIER
5169 SEAT TRACKS
5514 HOOD LOCK CABLE
5517 LOWER HOOD LOCK MECHANISM
5518 UPPER HOOD LOCK MECHANISM
5530 HOOD STRUT
5531 GAS FILLED HOOD SUPPORT
5534 LIFTGATE SWITCH ELEMENT
5538 FUEL FILLER FLAP ACTUATOR
5539 SIDE PANEL LID LOCK
5540 SIDE PANEL LID
5544 FUEL FILLER POSITIONING MOTOR
5545 FUEL FILLER FLAP SWITCH
5552 CENTRAL LOCKING MICROSWITCH
5555 LOWER LIFTGATE LOCK MECHANISM
5556 UPPER LIFTGATE LOCK MECHANISM
5557 REAR LOCK MECHANISM
5558 LIFTGATE LOCK CYLINER
5564 REAR SPRING/STRUT SUPPORT
5569 REAR LID LOCK CABLE
5570 LIFTGATE SEAL
5571 GUIDE WEDGE
5573 LOCK OPERATING ROD
5582 REAR LID LATCH SWITCH
5584 REAR LID LATCH MOTOR
5593 REAR STRUT
5708 KEY-BATTERY NOT COVERED
5709 LOCK CYLINDER
5711 EXTERIOR DOOR HANDLE
5713 INFRARED RECEIVER
5714 HEATED DOOR LOCK CONTROL UNIT
5715 HEATED DOOR LOCK MICRO SWITCH
5716 DOOR LOCK HEATING ELEMENT
5717 DOOR LOCK
5718 RIGHT DOOR LOCK
5721 DOOR LOCK KNOB / ROD
5725 STRIKER PIN PLATE / LOCKING WEDGE
5730 DOOR COMPONENT CARRIER
5733 DOOR HINGE
5745 RELEASE LEVER
5753 DOOR HINGE
5759 DOOR CHECK ROD
5763 INNER DOOR SEAL
5771 ACTUATOR ROD
5773 CENTRAL LOCKING CONTROL UNIT
5775 POWER DOOR LOCK ACTUATOR
5776 PWR DR LOCK LINES, RSVR/CH/VLV
5778 CENTRAL LOCKING SAFETY SWITCH
5780 CENTRAL LOCKING PUMP / CONTROL UNIT
5781 CENTRAL LOCKING ELECTRIC MOTOR
5782 CENTRAL LOCKING CONTROL UNIT
5784 CENTRAL LOCKING MICRO SWITCH
5785 RADIO REMOTE CONTROL SENDER
5786 RADIO REMOTE CONTROL UNIT
5789 COMFORT SYSTEM CENTRAL CONTROL UNIT
5811 EXTERIOR DOOR HANDLE
5817 DOOR LOCK
5818 RIGHT REAR DOOR LOCK
5819 CABLE
5821 DOOR LOCK KNOB / ROD
5825 STRIKER PLATE
5826 STRIKER PIN / LOCKING WEDGE
5830 DOOR COMPONENT CARRIER
5834 ACTUATOR
5835 CENTRAL LOCKING HOSES
5837 PULL ROD
5843 CONNECTING ROD/CABLE
5845 RELEASE LEVER
5853 DOOR HINGE
5859 DOOR CHECK ROD
5862 UPPER SLIDING DOOR SEAL
5863 INNER DOOR SEAL
5865 SLIDING DOOR
5867 LOCK CYLINDER
5868 SLIDING DOOR EXTERIOR HANDLE
5869 SLIDING DOOR STOP
5870 CENTRAL LOCK
5871 STRIKER PIN
5872 RETAINER HOOK
5874 REMOTE CONTROL LOCK
5875 LOCK LATCH
5876 PULL ROD
5877 SLIDING DOOR INTERIOR HANDLE
5880 SLIDING DOOR ACTUATOR
5881 SLIDING DOOR LATCH
5882 CHECK ROD
5883 SLIDING DOOR HINGE
5884 ROLLER ASSEMBLY
5885 CONTACT SWITCH
5887 LOWER GUIDE ROLLER
5888 UPPER GUIDE ROLLER
6010 SUNROOF WINDER
6011 MICROSWITCH
6012 SUNROOF SWITCH
6013 SUNROOF RELAY
6014 SUNROOF MOTOR / GEARBOX
6018 CONTROL CABLE
6019 UPPER LOCK MECHANISM
6022 WINDER GEAR
6023 DRIVE COVER
6024 CABLE GUIDE WITH COVER
6028 GUIDE FRAME
6030 LEFT/RIGHT CABLE GUIDE
6033 WIND DEFLECTOR
6034 FRONT CABLE GUIDE
6036 DEFLECTOR LINKAGE
6039 TILTING GLASS ROOF PANEL
6040 SLIDING ROOF PANEL
6041 GUIDE BLOCK
6042 SEAL
6045 SEAL
6048 WATER DRAIN HOSE
6050 UPPER FRAME
6051 LOWER FRAME
6052 WATER DEFLECTOR PLATE
6054 RELEASE LOOPS
6063 AUTOMATIC PRE-SELECTION
6064 POTENTIOMETER
6119 UPPER LOCK MECHANISM
6123 REAR SEAL
6130 TOP FRAME
6132 GAS SPRING
6137 TOP HEADER
6139 HEADER SEAL
6143 TENSIONING CABLE
6144 LOCK / CABLE
6145 SEAL
6147 REAR WINDOW LATCH
6181 POWER ROOF SWITCH
6182 RELAY
6183 UPPER HYDRAULIC CYLINDER
6184 POWER ROOF HYDRAULIC PUMP
6186 POWER ROOF HYDRAULIC CYLINDER
6187 POWER ROOF CYLINDER HYDRAULIC LINE
6189 COVER HYDRAULIC CYLINDER
6196 RELEASE CONTROL UNIT
6416 WINSHIELD WEATHERSTRIP
6438 DOOR COMFORT SYSTEM CONTROL UNIT
6445 FRONT DOOR WINDOW GUIDE
6450 WINDOW CONTROL UNIT
6452 ELECTRIC WINDOW REGULATOR ASSEMBLY
6453 MANUAL FRONT WINDOW REGULATOR ASSEMBLY
6454 ELECTRIC WINDOW REGULATOR MOTOR
6455 ELECTRIC WINDOW REGULATOR
6456 WINDOW REGULATOR RELAY
6458 WINDOW REGULATOR SWITCH
6459 REAR WNDOW LOCK OUT SWITCH
6465 REAR DOOR WINDOW GUIDE
6468 OUTER REAR DOOR WINDOW SLOT WEATHERSTRIP
6471 ELECTRIC WINDOW REGULATOR ASSEMBLY
6473 MANUAL REAR WINDOW REGULATOR
6486 REAR WINDOW GLASS ANTENNA
6490 REAR WINDOW WEATHERSTRIP / URETHANE SEAL
6492 REAR WINDOW DEFOGGER SWITCH
6616 FRONT WHEELHOUSE LINER
6655 ELECTRIC SIDE VIEW MIRROR MOUNTING HOUSING
6657 ELECTRIC SIDE MIRROR SWITCH
6658 REAR SPOILER-FUNCTION NOT APPEARANCE
6660 MIRROR CONTROL UNIT
6676 REAR WHEEL HOUSING LINER
6679 SIDE VIEW MIRROR ASSEMBLY - FUNCTION NOT
APPEARANCE
6680 REMOTE CONTROL MIRROR ADJUSTER
6810 GLOVE COMPARTMENT LOCK
6811 GLOVE COMPARTMENT / CENTER CONSOLE LOCK CYLINDER
6817 CONSOLE - FOR FUCTION, NOT APPEARANCE OR OUTSIDE
INFLUENCE
6823 LEFT / CENTER SUN VISOR - FOR FUNCTION NOT
APPEARANCE
6824 RIGHT SUN VISOR - FOR FUNCTION NOT APPEARANCE
6827 REAR VIEW MIRROR
6830 CUP HOLDER - NOT FOR OUTSIDE INFLUENCE
6853 SUN BLIND SWITCH
6882 TIMING RELAY
6896 SUN SHADE
6897 SUN SHADE MOTOR
6898 SUN SHADE CONTROL UNIT
6908 AUTO 2-POINT SHOULDER BELT
6911 FRONT 3 - POINT AUTOMATIC SAFETY BELT
6912 REAR 3 - POINT AUTOMATIC SAFETY BELT
6913 3 - POINT SAFETY BELT WITH TENSIONER
6914 REAR 3 - POINT SAFETY BELT WITH TENSIONER
6920 REAR LAP BELT
6921 INERTIA LAP BELT
6924 SAFETY BELT LOCK / CONTACT
6926 SAFETY BELT GUIDE
6934 TIMED SEAT BELT SENDER
6936 SAFETY BELT HEIGHT ADJUSTER
6950 AIR BAG ENERGY RESERVE
6951 AIR BAG SENSOR
6953 AIR BAG TRIGGERING / CONTROL UNIT
6955 AIR BAG SPIRAL SPRING ASSEMBLY
6956 SEAT OCCUPIED SENSOR
6957 AIR BAG SWITCH
6958 DRIVER AIR BAG UNIT
6959 PASSENGER AIR BAG UNIT
6961 LEFT REAR SIDE AIR BAG UNIT
6962 RIGHT REAR SIDE AIR BAG UNIT
6963 LEFT FRONT SIDE AIR BAG UNIT
6964 RIGHT FRONT SIDE AIR BAG UNIT
6965 LATERAL ACCELERATION SENSOR
6966 HEAD AIR BAG
6969 LATERAL ACCELERATION SENSOR
6972 ROLL BAR
6981 BUZZER / LOGIC RELAY
6982 SAFETY BELT INDICATOR LIGHT
6991 ALARM SYSTEM HORN
7209 FRONT MANUAL SEAT FRAME
7210 FRONT ELECTRIC SEAT FRAME
7211 SEAT RAIL GUIDE
7212 SEAT TRACK COVER
7213 FRONT SEAT ADJUSTER
7214 GAS STRUT
7215 FRONT SEAT FRAME / HEIGHT ADJUSTER
7219 FRONT SEAT BACKREST FRAME
7220 ADJUSTABLE ARMREST - FOR FUNCTION NOT APPEARANCE
7228 HEIGHT ADJUSTER
7229 HEIGHT ADJ. SWITCH
7230 LIFT MOTOR
7231 BACKREST ADJUSTER
7233 LUMBAR ADJUSTMENT
7240 CENTER SEAT BACKREST FRAME
7243 CENTER SEAT FRAME
7246 FRONT SEAT BACKREST LOCK
7250 REAR SPLIT BACKREST FRAME
7251 REAR SPLIT SEAT FRAME
7253 FOLDING CENTER BACKREST SPRING CORE
7255 REAR SEAT FRAME
7256 REAR SEAT BACKREST
7260 REAR SEAT ADJUSTMENT SWITCH
7262 REAR BACKREST REAR PANEL
7263 REAR SEAT BACKREST LATCH / LOCK
7264 REAR BACKREST FRAME
7265 REAR BACKREST STOP
7268 REAR SEAT LOCK
7270 SEAT MOUNTING
7271 GUIDE
7272 REAR ELECTRIC SEAT FRAME
7273 ELECTRIC FORE / AFT ADJUSTMENT MOTOR
7274 HEIGHT ADJUSTMENT MOTOR
7275 SEAT ADJUSTMENT MOTOR END SWITCH
7276 SEAT ADJUSTMENT OFF SWITCH
7277 FORE / AFT ADJUSTMENT SWITCH
7278 HEIGHT ADJUSTMENT SWITCH
7280 HEADREST
7283 HEADREST MOTOR
7286 SEAT ADJUSTMENT SWITCH
7287 ELECTRIC SEAT ADJUSTMENT MOTOR
7288 ELECTRIC FRONT HEIGHT ADJUST. MOTOR
7289 ELECTRIC BACKREST ADJUSTMENT MOTOR
7291 ELECTRIC SEAT RELAY
7292 ELECTRIC REAR HEIGHT ADJUSTMENT MOTOR
7293 SEAT ADJUSTMENT MEMORY CONTROL UNIT
7294 MEMORY SWITCH
7295 REGULATING SWITCH
7296 THIGH SUPPORT REGULATOR
7426 HEATED SEAT SWITCH
7427 SEAT HARNESS CONTROL UNIT
7428 FRONT SEAT HEATING ELEMENT HARNESS
7429 FRONT SEAT BACKREST HEATING ELEMENT HARNESS
7430 REAR SEAT HEATING ELEMENT HARNESS
7431 REAR SEAT BACKREST HEATING ELEMENT HARNESS
8004 CONTROL UNIT
8005 TEMP SENSOR INT.
8006 TEMP SENSOR EXT.
8011 REGULATOR MOTOR
8012 VENT TEMP SENDER
8013 HEATER CONTROL CABLE
8015 HEATER CONTROL VALVE
8023 HEATER CORE
8030 HEAT EXCHANGER FEED HOSE
8032 HEAT EXCHANGER RETURN HOSE
8033 T-PIECE
8036 PUMP AND VALVE UNIT
8038 HEATING ELEMENT RELAY
8039 HEATER ELEMENT
8040 REAR HEATER CORE
8055 FRONT FOOTWELL OUTLET
8057 REAR FOOTWELL OUTLET
8281 AMBIENT TEMPERATURE SENSOR
8510 FRESH AIR CONTROLS
8511 FRESH AIR CONTROL CABLES
8515 FRESH AIR HOUSING
8517 AIR CIRCULATION SWITCH
8520 AIR INTAKE GRILLE
8521 WATER DRAIN HOSE
8522 WATER DEFLECTOR
8523 FRESH AIR BLOWER MOTOR SWITCH
8525 FRESH AIR BLOWER MOTOR SERIES RESISTOR
8530 FRESH AIR BLOWER MOTOR
8536 FRESH AIR HOSE
8553 CENTER AIR OUTLET
8555 LEFT / RIGHT AIR OUTLET
8561 FRESH AIR OUTLET
8565 VENTILATION SLOT
8566 ADDITIONAL FRESH AIR BLOWER
8567 ADDITIONAL AIR DUCTING
8570 SOLENOID
8573 VACUUM UNIT
8578 MOTOR
8702 A/C CONTROL UNIT
8704 CONTROL UNIT
8705 CHECK VALVE
8706 VACUUM HOSES
8707 VACUUM CONTROL UNIT
8708 MICRO SWITCH
8709 PRESSURE SWITCH
8710 BLOWER MOTOR SWITCH
8711 CLIMATE CONTROL UNIT
8712 THERMOSTAT SWITCH
8714 PHOTO SENSOR
8715 WIRING HARNESS
8716 AC CONTROL WIRING HARNESS
8718 INTERIOR TEMPERATURE SENSOR
8719 RELAY
8720 POSITIONING MOTOR
8722 AIR QUALITY SENSOR
8724 TENSIONER
8727 COMPRESSOR CLUTCH
8728 COMPRESSOR CLUTCH RELAY
8734 COMPRESSOR
8735 COMPRESSOR SPEED SENSOR
8740 COMPRESSOR MOUNTING BRACKET
8741 COMPRESSOR REFRIGERANT LINE
8743 DISCHARGE HOSE
8744 CONDENSOR / EVAPORATOR HOSE
8745 SUCTION HOSE
8746 RECEIVER DRIER HOSE
8747 RECEIVER DRIER / EVAPORATOR HOSE
8748 CONTROL/REGULATOR UNIT
8749 MAGNETIC VALVE
8750 CONDENSOR
8754 OIL SEAL
8755 RECEIVER DRIER / ACCUMULATOR
8757 HIGH PRESSURE SWITCH
8758 INTERIOR TEMPERATURE SENSOR
8759 EXTERIOR AMBIENT SENSOR / INDICATOR
8760 EVAPORATOR
8762 EVAPORATOR HOUSING
8763 AMBIENT TEMPERATURE SWITCH
8764 LOW PRESSURE SWITCH
8765 WATER DEFLECTOR
8767 AIR INLET/COVER
8768 EVAPORATOR BLOWER MOTOR
8769 EVAP.BLOWER MOTOR SERIES RESISTOR
8770 EXPANSION VALVE
8771 DEFROSTER BUTTON
8772 REGULATING CONTROL UNIT
8774 AIR DUCT
8775 AIR OUTLET
8776 FOOT TEMPERATURE SENDER
8777 EVAPORATOR RESTRICTOR
8778 BLOWER REGULATOR
8779 EVAPORATOR AIR TEMPERATURE SENSOR
8780 OUTSIDE REGULATOR SENSOR
8782 INTERIOR BLOWER SENSOR
8785 VACUUM DISTRIBUTOR
8786 VACUUM RESERVOIR
8787 VACUUM PUMP
8791 DRAIN HOSE
9005 SPEEDOMETER (KILOMETERS)
9006 SPEEDOMETER (MILES)
9009 SPEEDOMETER SENSOR
9010 SPEEDOMETER DRIVE
9013 TRIP ODOMETER
9016 OIL PRESSURE INDICATOR
9018 OIL TEMPERATURE GAUGE
9021 FLASHER/TURN SIGNAL RELAY
9022 DIGITAL CLOCK
9023 FUEL GAUGE
9024 UPSHIFT INDICATOR LIGHT
9025 INSTRUMENT CLUSTER
9027 MALFUNCTION INDICATOR LAMP BULB
9028 PRINTED CIRCUIT
9029 VOLTAGE STABILIZER
9030 ANALOG CLOCK
9031 VOLTMETER
9032 TACHOMETER
9033 BOOST PRESSURE GAUGE
9034 CHECK PACKAGE WARNING LIGHT
9035 HAND BRAKE INDICATOR LIGHT
9040 COOLANT TEMPERATURE GAUGE
9041 AMBIENT TEMPERATURE SENSOR
9043 AMBIENT TEMPERATURE GAUGE
9045 MALFUNCTION INDICATOR LAMP
9050 SINGLE / ALARM SYSTEM HORN
9052 DUAL HORNS
9053 DUAL HORN RELAY
9059 HORN RELAY
9062 CIGAR LIGHTER
9070 POWER DOOR LOCK ELECTRIC MOTOR
9082 REPLACE CONTACT SWITCH
9093 ALARM SYSTEM CONTROL UNIT
9095 ALARM RELAY
9096 REAR SWITCH FOR ALARM
9110 OPERATING UNIT
9111 NAVIGATION CONTROL UNIT
9112 NAVIGATION UNIT
9113 GPS ANTENNA
9114 MAGNETIC FIELD PROBE
9115 MEASURING RESISTOR
9116 CD PLAYER
9118 GPS CD
9126 HEADPHONE CONNECTOR
9128 ANTENNA CABLE
9131 DSP AMPLIFER
9132 RADIO NAVIGATION UNIT
9134 ST.CASSETTE RADIO
9135 PREMIUM STEREO CASSETTE RADIO
9136 SUB-WOOFER
9138 MANUAL ANTENNA
9139 OE POWER ANTENNA
9140 FRONT STEREO SPEAKER
9142 REAR STEREO SPEAKER
9144 SPEAKER AMPLIFIER
9145 TRANSMISSION / RECEIVE UNIT
9147 CELLULAR ANTENNA
9159 CD CHANGER CONTROL UNIT
9160 COMPACT DISC CHANGER
9162 STERRING ELECTRONICS CONTROL UNIT
9163 RADAR SENSOR
9164 SPEAKER SWITCH OVER RELAY
9165 MULT-FUNCTION INDICATOR
9166 SPEED SENSOR
9167 VACUUM SENSOR
9168 AMBIENT TEMPERATURE SENSOR
9170 TELEMATIC CONTROL UNIT
9171 INDICATOR UNIT
9172 REAR LIGHT MONITOR RELAY
9173 HEADLIGHT MONITOR RELAY
9174 PARKING AID CONTROL UNIT
9175 PARKING AID SENSOR
9180 BOARD COMPUTER
9182 COMPUTER SWITCH
9183 PARKING AID SWITCH
9184 WINDSHIELD ANTENNA AMPLIFIER
9186 ANTENNA SELECTION CONTROL UNIT
9202 WIPER ASSEMBLY
9205 WINDSHIELD WIPER / WASHER SWITCH
9210 WINDSHIELD WIPER INTERVAL RELAY
9212 RAIN SENSOR
9215 WINDSHIELD WIPER MOTOR
9216 WIPER CONTROL UNIT
9219 WINDSHIELD WIPER LINKAGE
9220 WINDSHIELD WIPER SHAFT/BEARING
9222 WINDSHIELD WIPER ASSEMBLY BRACKET
9225 WINDSHIELD WIPER ARM
9234 REAR WINDOW WIPER MOTOR
9237 REAR WINDOW WIPER LINKAGE
9239 REAR WINDOW WIPER SHAFT
9241 REAR WINDOW WIPER ARM
9254 FRONT / REAR WASHER HOSES
9255 CHECK VALVE
9256 WINDSHIELD WASHER PUMP
9258 FLUID LEVEL SENSOR
9260 WINDSHIELD WASHER CONTAINER
9263 HEATED WINDSHIELD WASHER SPRAY JETS
9266 WASHER SPRAY JETS
9271 HEADLIGHT WASHER RESERVOIR
9272 HEADLIGHT WATER JETS
9273 HEADLIGHT WASHER CHECK VALVE
9274 HEADLIGHT WASHER CYLINDER
9275 HEADLIGHT WASHER RELAY
9277 HEADLIGHT WASHER HOSE
9278 HEADLIGHT WASHER PUMP
9281 HEADLIGHT WIPER MOTOR
9289 REAR WINDOW WASHER PUMP
9290 REAR WINDOW WASHER RELAY
9291 REAR WINDOW WASHER CONTAINER
9294 REAR WASHER JET
9405 HEADLIGHT SWITCH
9406 LIGHT/RADIO BUZZER
9413 HEADLIGHT TRIM COVER
9415 HEADLIGHT ASSEMBLY
9418 AERODYNAMIC HEADLIGHT LENS-NO OUTSIDE INFLUENCE
9426 HEADLIGHT SIDE LIGHT HOLDER
9431 TAIL LIGHT ASSEMBLY- NO OUTSIDE INFLUENCE
9436 BRAKE LIGHT SWITCH
9442 TURN SIGNAL SWITCH
9446 TURN SIGNAL / EMERGENCY FLASHER RELAY
9447 EMERGENCY FLASHER SWITCH
9450 STEERING COLUMN COMBINATION SWITCH
9452 SIDE REFLECTOR / LIGHT
9453 SIDE TURN SIGNAL
9454 FRONT TURN SIGNAL / PARKING LIGHT
9457 GAS DISCHARGE CONTROL UNIT
9458 GAS DISCHARGE STARTER
9460 REFLECTOR COVERS
9461 FOG LIGHT SWITCH
9462 FOG LIGHT RELAY
9464 FOG LIGHT
9465 REAR FOG LIGHT SWITCH
9470 CENTER BRAKE LIGHT
9471 HALOGEN HIGH BEAM LENS - NO OUTSIDE INFLUENCE
9472 BACK UP LIGHT SWITCH
9474 BACK-UP LIGHT
9478 FRONT HEADLIGHT RANGE CONTROL SENDER
9479 REAR HEADLIGHT RANGE CONTROL SENDER
9481 REAR FOG LIGHT RELAY
9498 HEADLIGHT RANGE CONTROL UNIT
9604 TRUNK / LUGGAGE COMPARTMENT LIGHT SWITCH
9605 FRONT DOOR SWITCH
9619 DOME/INTERIOR LIGHT TIME RELAY
9620 DOME / INTERIOR LIGHT
9626 INSTRUMENT PANEL ILLUMINATION AMPLIFIER
9628 INSTRUMENT PANEL ILLUMINATION RHEOSTAT
9635 HEATED FRONT SEAT RELAY
9640 TRUNK / LUGGAGE COMPARTMENT LIGHT
9642 ENGINE COMPARTMENT LIGHT
9644 GLOVE COMPARTMENT LIGHT
9646 MAP / READING LIGHT
9654 FRESH AIR / HEATER REGULATOR LIGHT
9663 TILL SENSOR CONTROL UNIT
9665 ALARM SIREN
9667 KESSY ANTENNA
9668 IMMOBILIZER CONTROL UNIT
9672 IMMOBILIZER READING UNIT
9674 IMMOBILIZER RELAY
9675 IMMOBILIZER HARNESS
9677 STOP-START SWITCH
9678 GARAGE DOOR OPENER
9679 GARAGE DOOR OPENER CONTROL UNIT
9681 HT CABLE/CONNECTOR
9682 CONTACT SWITCH
9683 MOVEMENT SENSOR SWITCH
9684 MOTION SENSOR CONTROL UNIT
9685 MOTION SENSOR
9687 ALARM SYSTEM CONTROL UNIT
9689 ALARM SYSTEM LED
9691 ALARM SYSTEM HORN
9692 FRONT ALARM SYSTEM SWITCH
9693 ALARM SYSTEM CONTROL UNIT
9694 DOOR ALARM SYSTEM SWITCH
9696 ALARM SYSTEM REAR LID / LIFTGATE SWITCH
9709 CENTRAL WIRING HARNESS
9710 POWER SUPPLY CONTROL UNIT
9711 INSTRUMENT WIRING LOOM
9712 HEADLIGHT/AC WIRING HARNESS
9713 ENGINE COMPARTMENT WIRING HARNESS
9714 FRONT LIGHTING WIRING HARNESS
9715 LEFT FRONT HARNESS
9716 RIGHT FRONT HARNESS
9725 REAR HARNESS
9727 REAR LID / LIFTGATE WIRING HARNESS
9732 DOOR WIRING HARNESS
9733 CENTRAL LOCKING SYSTEM HARNESS
9735 ALTERNATOR HARNESS
9739 CRUISE CONTROL HARNESS
9740 STEERING COLUMN WIRING HARNESS
9743 ELECTRIC MIRROR WIRING
9745 BATTER / STARTER WIRING
9746 INHIBITOR RELAY
9747 RELAY WIRING HARNESS
9748 OXYGEN SENSOR WIRING
9750 ELECTRIC INJECTION HARNESS/CONTROL UNIT WIRING
9752 ENGINE HARNESS
9754 TRANSISTOR IGNITION WIRING
9755 CONVERTIBLE TOP WIRING HARNESS
9756 FRONT BACKREST HEATING ELEMENT HARNESS
9757 ADJUSTABLE SEAT WIRING HARNESS
9758 SPEAKER WIRING HARNESS
9759 BUMPER WIRING HARNESS
9761 HEATER BOOSTER WIRING
9763 WINDSHIELD WIPER MOTOR HARNESS
9766 AIR BAG WIRING HARNESS
9768 TELEPHONE WIRING HARNESS
9769 DOME / INTERIOR LIGHT WIRING
9770 LICENSE PLATE LIGHT WIRING
9772 FIBER OPTICS CONDUCTOR
9773 REAR WINDOW WIPER WIRING
9774 INSTRUMENT PANEL HARNESS
9775 SAFETY BELT CONTACT SWITCH
9776 SAFETY BELT WARNING HARNESS
9777 SAFETY BELT WARNING INDICATOR PLUG
9779 SUNROOF MOTOR WIRING
9780 ELECTRIC WINDOW WIRING
9781 SHIFT LOCK / TRANSMISSION WIRING HARNESS
9784 ADDITIONAL FUSE PANEL
9785 BATTERY GROUND STRAP
9786 TRANSMISSION GROUND STRAP
9787 ENGINE GROUND STRAP
9790 RELAY CARRIER
9791 LOAD REDUCTION RELAY
9793 CENTRAL ELECTRICS COVER
9794 CENTRAL ELECTRICS
9795 FUSE PANEL
9796 CENTRAL ELECTRICS HOUSING
9798 GROUND CONNECTOR
AUDD USED CAR DEDUCTIBLE- AUDI PRODUCTS ONLY
2000 Audi S4 STG 3
FATS = 3.66 w/ 91 oct
AIM: EdyJun
11 September 2001
In their honor. In their memory.
<font color="red">----------------------------------------------------------
<u><big>
<a href="http://homepage.mac.com/edyjun1/S4/index.htm">EdyJun's S4 Directory (FAQ, DIY, Info, Tips and Help)
</a>
</big> </u>----------------------------------------------------------
</font>
EdyJun is offline   Reply With Quote
Old 02-07-2005, 03:16 PM   #2
ATH
Elder Member
Account #: 57761
Default Whoa, those lying motherf'ers - they told me headlight washers weren't covered!
And charged me $350 to fix mine! Thanks for the list, should be very useful to everyone with that warranty...
ATH is offline   Reply With Quote
Old 02-07-2005, 03:16 PM   #3
nobodeuno
Account #: 25538
Default I thought it was exclusionary warranty...
At least thats how its explained in my booklet...where did you get this list from?
-Justin-
01.5 S4, Santorin, 6 speed
::APR V5::
::Eibach Pro Street S Coilovers::
::AWE Twin2::
::ASP TSB w/ Vast Snub::
::Adjustible ToyGuy SS::
::AMS TBB w/ 710N's::
::20gb Phatbox::
::HCB-700 BT Kit::
::Painted RS4 Grill::
nobodeuno is offline   Reply With Quote
Old 02-07-2005, 03:17 PM   #4
andrew20195
Junior Member
Account #: 84711
Default Thanks for the info.
2001 Laser Red/Onyx Leather S4
AWE DTS
R.I.P.
2005 Evo
Nothing yet.
andrew20195 is offline   Reply With Quote
Old 02-07-2005, 03:23 PM   #5
ATH
Elder Member
Account #: 57761
Default Nope, it's not - they have a list of what is covered (wouldn't give me the list though)
Old 02-07-2005, 04:15 PM   #6
EricPA
Member
Account #: 4115
Default Great info. Can you tell me where you sourced it?
One of my EGT sensors is bad so I want to make sure it's covered.
2001.5 Pearl White S4 - Stage 3 ~~~ 2005 Sprint Blue S4 Cab
EricPA is offline   Reply With Quote
Old 02-07-2005, 04:23 PM   #7
EdyJun
Member
Account #: 48484
Default There is a dealer close to my work, i had them email it to me. [m]
call me if u need more info 818.231.1353
2000 Audi S4 STG 3
AIM: EdyJun
11 September 2001
<u><big>
</a>
</font>
Old 02-07-2005, 04:25 PM   #8
EdyJun
Member
Account #: 48484
Default Ya the dealer can be a BiAtch sometimes. Maybe u should pay them a visit.
2000 Audi S4 STG 3
AIM: EdyJun
11 September 2001
<u><big>
</a>
</font>
Old 02-07-2005, 09:03 PM   #9
NorCal S4Skier
New Member
Account #: 87708
Default Great document but wish it had reference to model/year
I'm buying a CPO 2001.5 this week and the list makes me feel better, but wish it had some sort of reference to car model, year, etc... since the CPO brochure says coverage varies by model.
If you have any other info to "certify" the document for future use at a dealer, please post.
Thanks.
NorCal S4Skier is offline   Reply With Quote
Old 02-07-2005, 09:16 PM   #10
TheDetailGuy(666PSI)
Junior Member
Account #: 46836
Default ...and if I have somthing on here that I paid for which should have been covered what do I say to th
em? Kinda seems like all I have here is a list of part #'s..cool info though Im about to go through my reciepts and see if everything was kosher
Jason
Black/Onyx '00 Audi S4; 6spd
-STOLEN AS OF 8/14/05-
TheDetailGuy(666PSI) is offline   Reply With Quote
Tags
6912, actuator, audi, b2, bearing, control, coolant, crankshaft, electro, fan, headlight, magnet, potentiometer, range, repair, run, shift, syncro, vacuum
