Old 07-29-2004, 08:12 AM   #21
spartanS4
Junior Member
Account #: 58020
Default Thanks, just talked to mike about it
Gonna go up 5 degrees and see what happens. I just haven't felt any gains when running on 100 octane with x stg 3.
Current: 993tt - No mods at all
Past: b5 S4 with everything (seriously)
SpartanS4 - Founding member of the Straight Line Whores (SLW's)
"Smooth, safe and remember, this sh!t is $$$, so enjoy yourself!"
spartanS4 is offline   Reply With Quote
Old 07-29-2004, 08:13 AM   #22
PSmalls::DoggieStyle
Elder Member
Account #: 69223
Default Enjoy!
PSmalls::DoggieStyle is offline   Reply With Quote
Old 07-29-2004, 08:21 AM   #23
No More B5 S4
Elder Member
Account #: 41217
Default Yes, 115 vs 114 but I've talked to many "experts" and they say Toluene burns cleaner.
"The Lord be with your spirit. Grace be with you."
-2 Timothy 4:22
Click for Peer FATS Times. Updated: 03/15/05<a href="http://public.fotki.com/s4madman/scenerylandscape/wallpapers_1600x1200/">
Got Wallpapers? Updated: 10/29/04</a>
The AW Database. Updated: 02/15/05
No More B5 S4 is offline   Reply With Quote
Old 07-29-2004, 09:46 AM   #24
M3KILR
Account #: 35340
Default No race gas for 120 miles
AWE-EPL-StaSis-Fiber Images-OZ-Labree/666 Fab
M3KILR is offline   Reply With Quote
Old 07-29-2004, 09:48 AM   #25
M3KILR
Account #: 35340
Default Ok gonna go put some 93 in just is case
Old 07-29-2004, 11:37 AM   #26
Audi2ptzero
Elder Member
Account #: 42349
Default When you start adding adv timing
you have to add a little more fuel. Same goes when you start to increase the boost levels.
Audi2ptzero is offline   Reply With Quote
Old 07-29-2004, 12:16 PM   #27
Elder Member
Account #: 69223
Default Unless you are already running rich like me :P
Old 07-29-2004, 01:45 PM   #28
Audi2ptzero
Elder Member
Account #: 42349
Default Then start adding that timing.
Nice thing about my car is I just get out and turn the fuel pressure down at the rail. I am sure glad I went that way because I need to run 40psi on the street and 50-52psi at the track.
Old 07-29-2004, 04:35 PM   #29
evils4
New Member
Account #: 69693
Default you can have a 55gal drum shipped to you..
thats what alot of guys did when I raced motocross.
OHHHH SNAAAAP!!
evils4 is offline   Reply With Quote
Old 07-29-2004, 05:25 PM   #30
Rican_S4
Elder Member
Account #: 78582
Default I have some mixing info for you guys.
Here is some info i've come upon on different forums but *USE AT YOUR OWN RISK*
SUNOCO "Standard"
Color...Purple
Research Octane...115
Motor Octane...107
R+M/2 ...111
Specific Gravity...0.725
Reid Vapor Pressure... 8#
Distallation temp, degrees F
Initial...90
10%...160
50%...220
Final...360
SUNOCO "GT Unleaded"
Color...Natural
Research Octane...105
Motor Octane...95
R+M/2 ...100
Specific Gravity...0.760
Initial...90
10%...150
50%...210
Final...230
SUNOCO "Supreme"
Color...Blue
Research Octane...116
Motor Octane...109
R+M/2 ...112
Specific Gravity...0.715
Initial...90
10%...155
50%...215
Final...260
SUNOCO "Maximal"
Color...Red
Research Octane...118
Motor Octane...115
R+M/2 ...117
Specific Gravity...0.700
Reid Vapor Pressure... 6#
Initial...100
10%...150
50%...220
Final...240
Richard Lassiter's "How to Mix Your Own Brew"
FORMULA 1
Toulene
R+M/2...114
Cost...$2.50/gal
Mixtures with 92 Octane Premium
10%...94.2 Octane
20%...96.4 Octane
30%...98.6 Octane
Notes: Common ingredient in Octane Boosters in a can. 12-16 ounces will only raise octane 2-3 *points*, I.e. from 92 to 92.3. Often costs $3-5 for 12-16 ounces, when it can be purchased for less than $3/gal at chemical supply houses or paint stores.
FORMULA 2
Xylene
R+M/2...117
Cost...$2.75/gal
10%...94.5 Octane
20%...97.0 Octane
30%...99.5 Octane
Notes: Similar to Toulene. 12-16 ounces will only raise octane 2-3 *points*, I.e. from 92 to 92.3. Usually mixed with Toulene and advertised as *race formula*.
FORMULA 3
Methyl-tertiary-butyl-ether (MTBE)
R+M/2...118
Cost...$3.50/gal
10%...94.6 Octane
20%...97.2 Octane
30%...99.8 Octane
Notes: Oxygenate. Very common in octane booster products. Has lower BTU content than toulene or xylene, but oxygenate effect makes the gasoline burn better and produce more energy.
FORMULA 4
Methanol or Ethanol
R+M/2...101
Cost...$0.60 - $1.75/gal
10%...94.3 Octane (Methanol)
10%...94.7 Octane (Ethanol)
20%...Not Recommended
Notes: Methanol is wood alcohol. Ethanol is grain alcohol and found in Gasohol in 10% ratios. Both alcohols are mildly corrosive and will eat gas tank linings, rubber and aluminum if used in excessive ratios. Main ingredient in "Gas Dryers", combines with water.
FORMULA 5
Isopropyl Alcohol and Tertiary Butyl Alcohol
R+M/2...101
Cost...$0.60-$1.50/gal
10%...94.5 Octane
30%...Not Recommended
Notes: Similar to Methanol/Ethanol. Isopropyl Alcohol is simply rubbing alcohol.
When oil companies blend their gas, they have to mix the cheap stuf, usually 'straight run' components, with the good (high octane/expensive) stuff. It is a fine balancing act, they run as much of the cheap stuff as they can to meet the octane spec.
Xylene (and its buddy Toluene) are magnificent gasolines. Toluene is about 114 octane, and xylenes can be anywhere from 115 to 121, depending on the makeup of the different isomers.
Both are very high energy fuels.
(Don't confuse octane with energy potential, we mix in a lot of Butane/Propane into the gasoline because it is cheap and has a nice 94 octane, but it is an awful fuel, not dense, no oomph, results in a poor 'drivability' index, another spec we have to meet.)
You can read in various Formula 1 articles of a time when teams ran 80% toluene mixes, until that was banned.
Xylenes have lots of uses outside gasoline, as you know we can sell it for lots o'cash as paint thinner/solvent, and toluene is also worth plenty - we make it into Styrene plastic and ship it to Japan and the USA. We don't like to have to put it into the gasoline. But gas pays the bills, so if a blend comes up short on octane, in goes just enough 'X&T' to get them out of the jam.
I can assure you that one or two gallons of xylene (or toluene) to nine of good quality pump gas will do wonderful things for your power, from an octane and from an overall power point of view. Trust me, you will not get anything like it from an oil company - most 'race gas' still has Lead additives to boost the octane, not X&T.
It is also relatively simple to work out your final octane in your tank - just add the octane of the pump gas and the octane of the X/T. So 8 gals of 94 octane and 1 of 114 octane = 866, divide by 9 = 96.2 ( if there is no Lead involved, it screws up the result)
It is best to keep it less than 40% of the total, because you are also diluting the other additives, the detergents/anti-static/stability package.
And never believe the crap on the "Octane Booster" bottle - 'adds 2 to 4 octane points' - they mean points as in "point one of an octane" 12 ounces to ten gallons may make 0.1 difference (very expensively!)
**this link may have some repeated info**
http://www.elektro.com/~audi/audi/toluene.html
Rican_S4 is offline   Reply With Quote
