Old 06-07-2004, 01:33 PM   #1
Mike@VAST
Banned
Account #: 21977
Default preliminary 2.8 cam info....some slightly interesting stuff
Nick G and I measured that the 2.8 USA cams have about 0.043" more lift than stock and the 2.8 Euro/RS4 cams have about 0.030" more lift than stock...
so, I put the USA cams in my car and checked the airflow out...19-20 psi peak tapering to whatever k03's do on my car...say, maybe slightly less than 1 bar.
i have no idea if the duration is the same. i bet it is, but who knows. the car runs fine, though, there is a hiccup from 3800-4200 rpm now.
anyway, it LOOKS like I have a slight gain from 5600-5700 up to redline where the airflow doesn't taper as bad. Regardless, I'm on POS original k03's and can't believe I went through all of this
If I figure anything else out, I'll post. Docslow mini-person and I are supposed to meet up and go over things since he and I pretty much have the same car but he is on stock cams.
Mike
Mike@VAST is offline   Reply With Quote
Old 06-07-2004, 01:35 PM   #2
PSmalls::DoggieStyle
Elder Member
Account #: 69223
Default no comment.
PSmalls::DoggieStyle is offline   Reply With Quote
Old 06-07-2004, 01:38 PM   #3
Mike@VAST
Banned
Account #: 21977
Default my only comment...probably doesn't do any good on stock turbos :p
what a PITA!!!!!! just for that. lol
Old 06-07-2004, 01:39 PM   #4
Elder Member
Account #: 69223
Default Time for us to put RS4 cams in my car and do a comparison :)
Honestly, from looking at your logs, I don't see any difference whatsoever in the shape of the airflow curve up high.
Old 06-07-2004, 01:40 PM   #5
Funkweasel
Elder Member
Account #: 28517
Default Well at least you got the tb done right? I fricking told you to do the k16s while you
were there. ;ppp
Funkweasel is offline   Reply With Quote
Old 06-07-2004, 01:41 PM   #6
Elder Member
Account #: 69223
Default Maybe if a special *someone* would send us some k16's, we'd put them on his car....
timing belt?
Old 06-07-2004, 01:42 PM   #7
Mike@VAST
Banned
Account #: 21977
Default i think i'll be hoping that my car lasts!
Old 06-07-2004, 01:42 PM   #8
Elder Member
Account #: 69223
Default Please delete this post before Troy and I vomit.
Old 06-07-2004, 01:43 PM   #9
Mike@VAST
Banned
Account #: 21977
Default well, i don't think it went in a negative direction or flatlined as bad. oh well! we can do whatever
but i have to get ready to leave for CO
Old 06-07-2004, 01:44 PM   #10
Elder Member
Account #: 69223
Default I should probably send you my log to compare, eh?
YGM in a few, porky
Tags
28, 98, a4, audi, cam, cams, camshafts, rs4, s4
