| Register | Pictureposter | Classifieds | FAQ | Members List | Search | Today's Posts | Mark Forums Read | Garage | My Recent Topics | Dealer Listings |
| Notices |
Thread Tools | Search this Thread | Display Modes |
#1 |
Account #: 1889
Purpose:
The S4 came equipped with an after-run system from the factory. The system utilizes a coolant pump to run coolant through the system for up to 10 minutes after the car has been shut off. The system also runs the electric radiator fan on low speed during this time. This is a great feature for a turbocharged car; however, Audi installed a pretty high temp thermo-switch to activate the system. The system from the factory was installed with a thermo-switch that activates at 112C (234F). This causes the system to VERY rarely activate. In order to allow best use of this system a lower temperature thermo-switch should be installed to activate the system on a regular basis. The following is a write-up on installing a thermo-switch that activates at 93C (198F), insuring operating of the after-run system almost anytime the car is brought up to operating temperature. Parts Needed: 021 919 369 - Thermo-switch N 903 168 02 - O-ring Parts should cost around $20-$30 from your local dealer A special thanks to Modified A4 for finding the low temp thermo-switch part number. Tools Needed: Phillips screwdriver Needle-nose pliers Flat head screwdriver (optional) Procedure: Step 1: Remove the expansion tank cap to relieve pressure, then re-install cap. Next, remove the coolant expansion tank by removing the 3 phillips screws. Once the screws are out slowly move the tank until you can disconnect the level sensor at the bottom of the tank (not pictured). Move the coolant expansion tank of the side. ![]() Step 2: Now you have access to the thermo-switch. Using a needle-nose pliers reach in and pull the metal retaining tab that holds the connector to the thermo-switch body. Once the retaining clip is out you can pull the connector off. ![]() Step 3: The thermo-switch is held in the coolant pipe with a black metal clip that slides over the sensor. Slide out the metal clip, in the direction of the arrow, to free the thermo-switch. The clip should slide out pretty easy, if you have trouble you can use a flat head screw driver to pry the clip out. ![]() Step 4: To remove the thermo-switch you just pull it straight out. My thermo-switch was a little hard to get out but eventually it just pulled out. When you first pull the thermo-switch out a little bit of coolant will escape (not much should escape if you released the pressure though). I didn't have a new o-ring so I re-used the existing one, seems to be working so far. The factory thermo-switch has a green body, the new thermo-switch has a blue body. Put the o-ring on the new thermo-switch then press it into the coolant pipe. Installation is reverse of removal. Make sure you re-connect your coolant level sensor connector and put your coolant overflow hose on the outside (towards the wheel) of the heat shield. This procedure should only take 5-10 minutes to complete. ![]() Results: Here's some (highly unscientific) testing I did. I took the car for a drive with each thermo-switch. The drives were a day apart, the car was run from a cold condition both times. I took the same route (about 10-15 mins) and really never even got in the boost on either trip. What I did: I measured temps after I got back and shut the car off. I checked temps right as I shut the car off. I then left the car off and came back and checked temps 5, 10, and 15 minutes after I turned the car off. Oil temp was from gauge, all others were from VAG. Car was parked in my small 1-car garage with the garage door left open. Results are as follow. Results with factory thermo-switch; after-run pump did NOT operate. Outside Temp: 70F On shut-down: Oil - 200F (93C) Coolant - 200F (93C) IAT - 99F (37C) 5 mins after shut-down: Oil - ~195F (91C) Coolant - 212F (100C) IAT - 122F (50C) 10 mins after shut-down: Oil - ~180F (82C) Coolant - 207F (97C) IAT - 144F (62C) 15 mins after shut-down: Oil - ~175F (79C) Coolant - 203F (95C) IAT - 153F (67C) Results with LOW TEMP thermo-switch; after run pump DID activate. Outside temp: 77F On shut-down: Oil - 200F (93C) Coolant - 200F (93C) IAT - 108F (42C) 5 mins after shut-down: Oil - ~190F (88C) **Conversion EDIT** Coolant - 207F (97C) IAT - 129F (54C) 10 mins after shut-down: Oil - ~175F (79C) Coolant - 199F (93C) IAT - 136F (58C) 15 mins after shut-down: Oil - ~170F (77C) Coolant - 198F (92C) IAT - 145F (63C) I'll let you guys compare the numbers and take them for what they're worth. Only item that I'll point out is that it was actually warmer out on the drive with the low temp thermo-switch. Keywords: low temp, temperature, thermoswitch, thermo-switch, after-run, afterrun, coolant pump, secondary, electric Disclaimer: This is the procedure I used on my 2000 S4, 6-speed. This procedure should work for other B5 S4's. Attempt at your own risk, the author is not responsible for others that attempt this procedure. Note: Cars equipped with secondary air injection systems (S4 autos) could cause some additional difficulty in accessing the thermo-switch.
Current Audi Count --- 5 ![]() Previous Audi Count --- 7 In spite of dealers; I still love Audi :-) |
#2 |
Member
Account #: 42392
#3 |
Audiworld Sponsor
Account #: 6924
Gonna see if I can find/order the parts today!
-Dave Pramanik |
#4 |
Elder Member
Account #: 16079
#5 |
Account #: 52044
-Imolavirus K16/K04 turbos- -PEB/VAST Stage III fueling- -600F/700R STaSIS Track Sports- -MadMan/SPP Stage III HID- -VAST Performance Modified Kevlar RS4 Clutch- "The Audi S4 is a car revered by the cognoscenti and underestimated by the majority..." www.NogaroBlue.com The Truth My Photos Nurburging FAQ |
#6 |
Account #: 19401
#7 |
Elder Member
Account #: 26345
![]() ![]() | 1989 BMW M3 | TMS J-Stock | Bimmerworld Cage | iigomotiv | OMP | | Borla | UUC | Cobalt Friction | Kosei | Toyo | BBS | Bridgestone | V1 | | 2005 Kawasaki Ninja ZX-6R | Pearl Magma Red | | 8 Throttle Bodies...B!TCH AIM: mpw8888 MSN Messenger: mpwolf@hotmail.com Yahoo!: mw007e |
#8 |
Member
Account #: 2062
everytime you shut the car down. I was talking with one of the AZ guys this weekend, and he mentioned that it's a common question on the Jetta forums (people hear the whirring noise after they shut the car down, but can't figure out what it is). Kinda odd that they would install this system into a NA motor...and have it run everytime the car is shut down.
2005.5 A4 Avant 2.0T Quattro 6MT APR 91/93/100 | APR Exhaust | 19" BBS RS-GT's | Carbonio | Hotchkis | Partridge-in-a-pear-tree Others: 2006 TL on the block 2001 S4 sold 2000 A4 sold *** September 11th, 2001 - Never Forget *** |
#9 |
Account #: 14154
Electrically I mean...does the car only send a signal to the pump when the ignition is switched off?
Nice write-up.
2008 A6 3.2Q S-Line Daytona Gray / Black S-Line interior Premium, Tech, Nav retrofit |
#10 |
Member
Account #: 20251
2002 S4 Laser/Silver 6-speed Cold, Premium, Bose, Changer <Brian May guitar riff>..."I'm in love with my car, got a feel for my automobile"...I OWN an S4, I DROVE many a service loaner from Enterprise! $19k+ worth of warranty repairs. Tally ended on 8-23-05! She's now free of the man; DIY all the way! Now spending AoA retroactive cash back bonus for crappy dealer service! Thanks for the check, AoA! Please help to fight window-licking! (I hear they have a cure over on Audizine...)
| Tags |
| 2000, afterrun, audi, cobalt, green, jetta, low, lower, motor, pump, run, s4, send, switch, temp, thermo, thermoswitch, vw, work |
Previous Thread
Next Thread
| Display Modes | |
Linear Mode
