Old 03-25-2004, 04:27 AM   #11
TRM
Elder Member
Account #: 20422
Default nah! remember my allroad edition S4 with the KW's?
i had like 3" gap at the top setting.
<sub>uh! let me see you shake in your boots. come back to the old school. come back to your roots!</sub>
TRM is offline   Reply With Quote
Old 03-25-2004, 05:06 AM   #12
Zzak
Junior Member
Account #: 57655
Default Updated S4 Coilover Comparison from an old post of mine
Here are some options:
All are HEIGHT adjustable on-car.
All that have Damping adjustments (e.g. Compression & Rebound) are adjustable off-car
Maker: Spring Rate f/r | Damper | Adjustments | Drop f/r
1.) Koni A4(STaSIS): 420/390 | Koni twin-tube | rebound adj. | 0-2"/0-2"
2.) H&R Streets: 450/450(475Avant) | Gas charged | no adj. | 1-2"/1-1.75"
3.) H&R Ultras: 500/625 | Gas charged | no adj. | 1-3"/1-3"
4.) FK: 480/360 | Koni twin-tube | rebound adj. | 1.8-2.7"/1.8-2.7"
5.) Intrax: 445/362 | Gas charged | rebound & compression adj. | 0-3"/0-2.5"
EDIT: According to SPP this kit is not as described on the Intrax site and is in fact a Koni based twin-tube rebound adjustable only kit. An alternative 800/1100 autocross spring rate for this setup is also offered
6.) KW V1: 400/530 ?? | Inox twin-tube digressive | no adj. | 1.6-2.7"/ 1.6-2.7"
(V2 on-car rebound adj) (V3 on-car rebound and compression adj)
7.) Vogtland 670/630 | Twin Tube | Non-adj | 1.2-2.75"/1.2-2.75"
* coilover coil-over HR H&R Streets Ultra Ultras Koni STaSIS Street Sports FK KW V1 V2 V3 Intrax Vogtland spring rate rates height adjustment damping dampening shock shocks *
Zzak is offline   Reply With Quote
Old 03-25-2004, 05:52 AM   #13
RKA
Member
Account #: 2062
Default I never saw the KW's! Only saw it with the Koni shocks.
Those S4's that I have seen with KW's sit lower than the H&R's...even at max height (somewhere around 25.25" max).
2005.5 A4 Avant 2.0T Quattro 6MT
APR 91/93/100 | APR Exhaust | 19" BBS RS-GT's | Carbonio | Hotchkis | Partridge-in-a-pear-tree
Others:
2006 TL on the block
2001 S4 sold
2000 A4 sold
*** September 11th, 2001 - Never Forget ***
RKA is offline   Reply With Quote
Old 03-25-2004, 06:05 AM   #14
2000ImolaS4
Junior Member
Account #: 38261
Default Thanks again... I posted thanks at x-post
2000ImolaS4 is offline   Reply With Quote
Old 03-25-2004, 08:15 AM   #15
TRM
Elder Member
Account #: 20422
Default i'll email you the pic when i get home. it was hilariously high. :-)
Old 03-25-2004, 08:18 AM   #16
RKA
Member
Account #: 2062
Default OT: (but perhaps of interest to Theo)
Whats the head count for the fun run?
Others:
2001 S4 sold
2000 A4 sold
Old 03-25-2004, 08:36 AM   #17
TRM
Elder Member
Account #: 20422
Default a dismal 6....[edit]
Mark Havlinka
Jeff (if his StopTechs get installed)
Mo and his two buddies...
and me of course, as i can lead without a navigator.
of course only 6 means we go like hell! :-)
Tristan and his Bro Evan just confirmed too.
