Old 03-17-2004, 05:14 PM   #1
EXGTINOWS4
New Member
Account #: 66899
Default Navi+ with a Panasonic CD changer Question
Hi - I just finished installing a Navi + unit. I have 8 CD Panasonic changer. The Navi+ is working fine with the exception of it not showing or playing any CD's. It says NO CD for all the 6 slot it shows.
Any suggestions as to what could be done to rectify this? (the changer wokred fine with the Symphnoy unit that I had)
Thanks
EXGTINOWS4 is offline   Reply With Quote
Old 03-17-2004, 05:18 PM   #2
JasonS4+Festicle
Senior Member
Account #: 36810
Default hmmmmmmmmmm......are you sure you wired the NAV+ correctly?....
I installed NAV+ some time back and there are tons and tons of wires to connect (as I'm sure you know) - I can't imagine why your changer does not work, unless the wiring to the CD changer was somehow messed up.
FWIW, I had a stock 6-disk changer that worked fine with the NAV+ and have since removed it to replace with a Blitzsafe adapter to wire to an iPOD - that works too.
If you can't get it to work, you might want to try swapping in someone's stock 6-disk changer just to see if it is some incompatibility issue with the Panasonic you have.
JasonS4+Festicle is offline   Reply With Quote
Old 03-17-2004, 05:35 PM   #3
Hal_TT::CBP
Senior Member
Account #: 3027
Default Yep, Start with getting an Audi 6-Disc going and then swap to the other would be my advice as well.
Hal.
Whoops...
I wanna ride...
APR Stg3 (and then some) Sold.
Hal_TT::CBP is offline   Reply With Quote
Old 03-17-2004, 05:46 PM   #4
EXGTINOWS4
New Member
Account #: 66899
Default Re: Navi+ with a Panasonic CD changer Question
Would there be any 'recoding' required in the Navi+ for the Panasonic changer? I think it comes coded or the Audi OEM changer.
I will try to get a OEM working (need to figure out where to get one to test from)
Thanks
Old 03-17-2004, 06:35 PM   #5
Hal_TT::CBP
Senior Member
Account #: 3027
Default Did you code it for the changer in the first place?
00207 for nonBose and
00117 for Bose
I'd check that you have a 7 in that last field first. It is either coded to enable the changer interface or disable it. No distinction between different makes/models in the Nav+ or Sym units that I am aware of.
Hal.
Whoops...
I wanna ride...
Old 03-17-2004, 06:39 PM   #6
Imola Ghost
Account #: 17725
Default I had a Panasonic 8 disc hooked up to my Nav+ and it worked fine. Just recheck your wiring &...
check the radio setting thru a VAG, to make sure the CD changer is enabled.
todd1010 AT gmail DOT com
Imola Ghost is online now   Reply With Quote
Old 03-17-2004, 07:00 PM   #7
VR_Life
Member
Account #: 58573
Default I had a Sony XPlod 6 CD/MP3 player but after installing Navi+ I had to rip it out
The point is that while Symphony was pretty flexible, Navi+ seems to only be compatible with exactly the Audi OEM CD Changer.
I fixed my problem by switching to Phatnoise
After spending more than couple of grand on Navi+, what's another $800 ;-)
IM me in the garage via AIM: VRlifeIM
Thanks AW for mucking up my signature and old posts.
Can't say I'm going to miss all the Tip-hater posts you let thru.
Gone to Quattro World dot com
VR_Life is offline   Reply With Quote
Old 03-17-2004, 07:05 PM   #8
EXGTINOWS4
New Member
Account #: 66899
Default Re: I had a Panasonic 8 disc hooked up to my Nav+ and it w
What exact setting in Vag should I check?
Thanks
Old 03-17-2004, 07:05 PM   #9
EXGTINOWS4
New Member
Account #: 66899
Default Re: Did you code it for the changer in the first place?
Thanks- I am a bit new to this - where exactly in the Vag do i need to check for this code?
Thanks
Old 03-17-2004, 07:08 PM   #10
Imola Ghost
Account #: 17725
Default not sure exactly, but its the same code you would use to enable it on the Symphony HU.
I know it worked fine for me. No problems whatsoever. I had the 8-disc Panasonic Cd changer.
