Old 03-02-2004, 06:07 PM   #1
PhoenixGTS
AudiWorld Expert
Account #: 14311
Default NE1 know of a wheel offset to backspacing calculator? I understand that offset if different for
different width wheels with the same backspacing, but I get confuse trying to calculate the backspacing given the width and offset, and figured somebody has a calculator for this.
2006 SRT-8 Jeep Cherokee - Silver with all options except for rear seat entertainment - stubby antenna - clean Porterfield R4S brake pads - low beam HID
1998 Viper GTS - Silver no stripes - full exhaust - 70mm throttle bodies - roller rockers - Mopar PCM - huge radiator and overdrive water pump - underdrive crank pulley - 3.55 rear end and 0.80/5th and 0.64/6th gears - Aldan shocks -- cheapy e-bay drilled/slotted rotors - Cer-Wool side sill insulation - HID - stereo - clear corners - silver painted wheels and gas cap
Formerly - 2001 Silver/Onyx S4 with every option except for NAV and phone - sold 09/10/04 - great car, I miss it
PhoenixGTS is offline   Reply With Quote
Old 03-03-2004, 07:25 AM   #2
shinronin
Junior Member
Account #: 56366
Default wheel offset calculator
2000 B5 S4 Nogaro Blue 6MT
Engine: Bailey DVs | Samco F-hose | Samco TBB | Samco Upper Intake Hoses
Exterior: Front + Rear euros
Suspension: STaSIS Track Sport 600/750 (sport) | CPP adjustable front upper control arms (Stainless steel ends)
Tires: Michelin Pilot Sport PS2 (225/45-17)
Tranny: AWE DTS | APR snub mount | TG SS | RS4 Clutch | AWE LWFW | STaSIS High Bias Center Diff
<a href="http://www.marsavius.net/qclub" target="_blank">
</a>
shinronin is offline   Reply With Quote
Tags
backspacing, calculator, offset, wheel
