Old 09-29-2003, 08:04 AM   #1
Neon01
Member
Account #: 34518
Default As it's possible that I'm soon moving on to another car, I wanted to give something back to AW :
[Updated 4-27-04]
So I've attempted to draft up an uber-noob guide, hoping to answer most questions new people to the B5 S4 have before they bug the rest of us. Perhaps this could be made into a "tech article" if it's deemed worthy. Tell me what you think. Here it is:
S4 and Audiworld (AW) Newbie guide.
Since it seems that there are quite a few S4 transactions going on as of this writing (must be the recent release of the 04), I reasoned that the community might benefit from a brief guide to the B5 S4. Before posting a dozen times about things that have already been answered ad infinitum, please use the search feature on the forum. All forums have them, and if you're here, you're probably familiar with how they work by now
-General S4 Information-
The 2000 through 2002 model year Audi S4 shares the B5 platform of the 1996-2001 A4, which has a more rounded look than the new B6 style. Production began on the S4 in late 1999 and continued through late in 2001, when they closed the factories to retool for the new S4. The last few made in 2001 were badged as 2002 model year vehicles.
-Specifications (Stock S4)-
Here are a few of the specs you're likely to be looking for (note - times quoted are for an average driver): 0-60mph time - 5.8 sec, 0-1320' time - 14.3 sec, weight - ~3650 lbs, many more specs can be found here: http://www.s-cars.org/s4biturbo/Tech/tech.html
-Common Problems-
The following are a list of S4 problems that I've compiled after reading Audiworld for nearly 2 years. Some of these may be one time fixes that are corrected at the dealership under warranty, but may be something you want to look for in a potential purchase.
#1. Turbo failure: clearly this is a big problem, as the repair will run you >$6000 if you are not under warranty (not a typo!), but it is usually attributable to one of a few weak points in the system.
Throttle body boot (TBB). A small rubber boot that connects the two pipes that deliver air from the intercoolers to the throttle body. It is shaped like a truncated "Y", and frequently tears due to overtight clamps or simply a defective design (poor material). Several fixes are available on the aftermarket: Samco makes a silicon TBB, and it's available for about $60 when I checked last. Some individuals have complained that it does not fit quite properly, and you usually need to buy clamps separately, but it is usually a serviceable part. Another alternative is AMS' Kevlar-wrapped TBB. This is merely a stock TBB with a layer of Kevlar wrapped around it. I cannot recall seeing a failed one listed on the forum, and it looks and fits identically to the stock TBB. This is available for about $90. What most regard as the best replacement for the TBB, however, is a part called the Bipipe. Made by APR, it is a "Y" shaped pipe made of metal that replaces the TBB and the metal intercooler pipes feeding it. It runs about $350 from APR, and is generally regarded as a foolproof fix to the problem. Other options are available, but they will not be addressed here. Here is an AW tech article on TBB replacement: http://www.audiworld.com/tech/eng19.shtml
Bypass valves (BPVs). Instead of using Blowoff valves, like many turbo cars, the S4 uses BPVs. I will not get into a technical description of what they do, because some knowledge of turbochargers is required. Suffice to say there are two BPVs (one for each turbo) that frequently fail because of a poor design by the manufacturer. Note that the BPVs have an exceptionally high probability of failure if the vehicle is modified to increase performance, but even without modifications, they frequently break. Several fixes are available here as well. The most common solution is to replace each one with the BPVs found in the Audi TT 225 (called 710Ns, by part #), which are a more robust design. Each will run you no more than $35, and can be replaced easily by yourself using the tech write-up on AW. These BPVs are known to perform well even with significant performance modification to the vehicle. Other BPV options exist through aftermarket manufacturers such as Bailey, Forge, Stratmosphere, and many more. The difference between these valves and the TT valves is that they are constructed of metal. They are considered very robust, but require internal lubrication from time to time. These typically run anywhere from $200-$350 for the pair. Here is an AW tech article on BPVs: http://www.audiworld.com/tech/eng21.shtml (sorry, cut and paste)
F-Hose. This problem is exclusive to the 2000 and early 2001 model years (late 2001 year models had numerous changes, and are typically referred to as 2001.5). In the S4s where this is an issue, the F-hose is a little hose that, oddly enough, is shaped like an "F", and is made of rubber. It is prone to tearing. Alternatives available are one made by MTM, which is a metal pipe fashioned in the required shape with rubber connections; cost is about $80. Samco makes a silicon F hose that runs closer to $25. Both seem to work just fine. Note that the F-hose doesn't seem to be as common of a problem as the aforementioned parts.
These three trouble spots can create big problems for your turbo if malfunctioning. If you're interested in buying an S4, it's usually good if the seller at least has a knowledge of the potential problems, and even better if they have been remedied. Turbo failure rate does increase when performance modifications are made to the car. Naturally when you demand more activity of your turbo (to give you more power) it's going to see more wear, and probably premature failure.
#2. Driver's seat problem: apparently some seats likes to "rock" back and forth as if there is play in the track. This problem was usually fixed under warranty. I have personally never experienced it with my S4.
#3. Windshield washer fluid pump cracks. I am not aware of a particular cause for this failure, but most have gotten it taken care of under warranty.
#4. Transmission 1st-2nd gear slider problems (6sp only). This AW thread explains the phenomenon: http://forums.audiworld.com/s4/msgs/691866.phtml. Coupled with weak synchros and a user-base that is frequently running significantly higher-than-stock performance powerplants, this problem *can* cause premature transmission failure. Typically if you treat your gearbox nicely, it will not have problems, so don't power shift through the gears and you should be okay. Transmission problems can also be caused by improper installation of a short-throw shift kit. Follow directions closely if installing one. Just pray that your transmission problems crop up while you are under warranty (if at all), because they will be a VERY expensive fix if you aren't. Do not become overly worried about this issue, many S4s have had no transmission issues at all (like mine).
#5. Mass air flow (MAF) sensor trouble. The mass air flow sensor detects the rate at which air is entering your intake system (to go to the engine). They frequently fail due to (you guessed it) poor design, and could cause gas mileage problems, or a rich or lean condition, even a loss of power. This is about a $350 part (and really easy to replace), so it's not crazy expensive if it goes, but just be aware. This problem appears to be generally limited to MY 2000 cars.
#6. Intercooler (IC) tank end caps leaking. This problem is (some say) due to the end caps on the IC tanks being made of plastic versus the metal of the IC. When they leak, you'll get a loss of power due to the pressurized air that's escaping. Not a terribly common problem.
#7. "Warped" front rotors. Due to their very large size (swept area) and inability to trasnmit heat to their surroundings efficiently, uneven brake pad deposits are frequently left on the rotors. This can result in poor braking performance, and can cause a sort of shuddering experience during hard braking. Many people simply buy inexpensive (in some cases cheaper than replacement OEM) aftermarket rotors which perform well with stock calipers. A set of aftermarket front rotors (good ones) can cost you as little as about $200.
#8. Fan internal to the climate control unit makes a buzzing noise. Replacing the fan fixes the problem.
Those are most of the most common problems that I have found in my experience with AW. Potential buyers worry not, however, as I can assure you they are anything but guaranteed. As they owner of a 2000 S4 with nearly 60k miles on it, I have not experienced one of these problems, and I have modified my car.
-Model Year Changes-
About half of the later 2001 model year S4s made many significant changes. These are the 2001.5 S4s referred to on AW. Among the differences were the following: larger oil inlet lines to the turbo to increase lubrication (made turbos more reliable); badges on front and rear were changed, and others. The first 2001 models received the following over 2000s: a longer warranty (4yr/50k instead of 3yr/50k), sport packages got chrome mirrors, got ESP (traction control), got different tires, avant became available, and others. Clearly, the ones you want are the 2001.5 or 2002s, but that's not to say you can't do well with a 2000.
-Performance Modifications-
Here is the typical "stage" structure as followed by most tuners (fwhp=FlyWheel Horsepower):
Stage 1 (adds around 50-60 fwhp) - performance "chip", which is merely a chip that is soldered into the car's ECU to essentially increase boost pressure and retard timing (giving the car SIGNIFICANT performance gains). To have your ECU modified in this way, you send it to a tuner (GIAC, APR, AMS/Abt, and MTM are widely regarded as the best) and they will modify it and send it back. This costs anywhere from $500-800 depending on the company. Different tuner chips give the car different power curves, so it's important to do your research before selecting which one you want. What most recommend is that you just buy a spare ECU from the tuner to have them modify. That way you have a complete unit you can simply swap out in case you need to go back to stock form. Spare ECUs run about $500 new.
Stage 2 (adds 5-15 fwhp) - just add an aftermarket exhaust to your chip (any will do). The true dual exhausts typically give the most performance gains. Cost: $600-2000 depending on manufacturer. Most do this mod simply for the sound. Here is an AW tech article on exhaust systems: http://www.audiworld.com/tech/eng28.shtml
Stage 2.5 (adds ~20-35 hp) - add replacement of stock downpipes (from turbo to cat) with aftermarket ones (with option to replace cat with high flow unit or even straight pipe). Cost: $1000-1700. Note: difficult to install
Stage 3 (brings fwhp up around 420-450) - Add turbocharger replacement, typically with K04 turbos, such as those used in the european RS4 wagon. Usually many other parts are required at this step as well; kits can be bought that contain everything (sans exhaust components) for $6000-14000.
Other common modifications include(and common brands selected): coilover suspension (H&R, Stasis), rear sway bar (Neuspeed), Snub mount (APR, what this does is to limit forward/rear transfer of weight during acceleration or gear shift), Drivetrain stabilizer or DTS (AWE, Tantrumwerks, Autospeed), performs similar function to snub mount), short shift kit (UUC, Tanoga, "Toy Guy"), air intake replacement (S-Flo), Boost Gauge (Omori matches stock lighting), and many more.
-Audiworld Frequently Used Abbreviations/Definitions-
STFA - search the freaking archives (or other colorful word choice)
TBB - throttle body boot
DTS - drivetrain stabilizer
BPV - bypass valve
BOV - Blowoff valves
TPIWWOP - this post is worthless without pics
RTFM - read the freaking manual
VAG - the entity that owns volkswagon, audi, seat, and skoda
VAG-Com - a software package and tool to read your audi's computer and make changes to programming.
MY - model year
DIY - do it yourself
OT - off topic
P-car - Porsche
PITA - pain in the ass
GB - group buy
STFU - shut the f*&% up
X-Post - Cross post
ACCNA - audi car club north America
ECU - electronics control unit (the car's computer)
DTC - codes thrown by the car's ECU when it detects something wrong, help to diagnose problems
Tip - tiptronic transmission (automatic that has a manual shift mode)
DPs - downpipes
I hope this has been helpful for new people to the S4
2003 Sapphire Black BMW 330i PP (daily)
1999 Silver BMW M3 (track)
Sold:
2004 Alpine White M3 12-24-05
2000 Lake Silver S4 8-14-04
Neon01 is offline   Reply With Quote
Old 09-29-2003, 08:16 AM   #2
Pie4Foo
Member
Account #: 57452
Default Wow! Thanks from a n00b!
Car for driving in circles: Lotus Exige
Car for driving to the airport: AWE/GIAC Stage 3 S4
Car for the weekday: Hertz rental
Pie4Foo is offline   Reply With Quote
Old 09-29-2003, 08:16 AM   #3
daphne
Super Moderator
Account #: 23
Default #3 - it's the pump, not the tank
Also, you might want to specify that sometimes people say VAG to mean VAG-COM.
Daphne
2001 S4 Avant, Silver/Onyx/Silver
"If you guys had any real balls you'd race back down this mountain!"
Michele Mouton, Pikes Peak 1985
daphne is offline   Reply With Quote
Old 09-29-2003, 08:19 AM   #4
dscottjr
Member
Account #: 42392
Default you've got a typo #3 - some, most. also, #7- you might want to change "weak rotors" to rotors that
do not dissapate heat well.
you might want to put pics in of all the parts or links to the tech articles.
nice job though. this looks good.
00 S4, Euro spider hose mod!!
04 allroad, needs rs6 intercoolers, k04s and a cargo box...
dscottjr is offline   Reply With Quote
Old 09-29-2003, 08:28 AM   #5
RocketBoy
Junior Member
Account #: 37205
Default Very Nice... small additions/corrections
I could be wrong on this one because I don't use them, but I've never heard of anyone needing to replace the springs in an aftermarket DV. The maintenance required is usually just making sure the piston remains well lubricated.
#5 - I would add that this issue is pretty much limited to MY 2000 vehicles.
APR doesn't make a DTS. AWE, Autospeed, and TantrumWerks do.
RocketBoy is offline   Reply With Quote
Old 09-29-2003, 08:40 AM   #6
Steve Trac, Sec 303
Account #: 23929
Default additionally, chips don't add 60 "fwhp" or 60 "any wheel HP". All those numbers are "crank" numbers.
Plus another common problem is the rattling/buzzing from the Climate Control unit caused by the fan inside. Replacing the unit fixes the issue.
Plus "vag" should be "VAG" as it's an acronym for "Volkswagon Audi Group"
Great job though and thanks a lot for writing it up!!!!
Steve Trac, Sec 303 is offline   Reply With Quote
Old 09-29-2003, 08:47 AM   #7
Mike2kS4
Elder Member
Account #: 38083
Default How about FlyWheel HP? ;)
2002 S4 Avant, 6spd. Bone stock.
<a href="http://www.autospeed.us">
</a>
Caveat: Any advice I express regarding potential tuning and such is purely informational. If your knowledge and abilities are not up to the task, no amount of advice can assist.
Mike2kS4 is offline   Reply With Quote
Old 09-29-2003, 09:07 AM   #8
Bi_Turbo_WI
Junior Member
Account #: 35570
Default Personally I think that AW should simply add a nOOb forum...
You know...A4, S4, A3, A6, A8, TT, allroad, Off Topic, Feedback, nOOb! :-)
AIM Screename: timwernicke
2003 GTI 20th Anniversary #3813 Stock for NOW!!! :-)
2001.5 S4 6-Spd. SOLD!!! :-(
2000 Jetta GLS 1.8T STOCK!!! :-(
Bi_Turbo_WI is offline   Reply With Quote
Old 09-29-2003, 09:18 AM   #9
GreekDeno
Elder Member
Account #: 4935
Default Nice. Good write up for the noob's. Their should def. be a tech article for them.
An unexamined life is not worth living
-Socrates
Fvck PETA
'05 A6 3.2
and
"06 Denali
GreekDeno is offline   Reply With Quote
Old 09-29-2003, 09:31 AM   #10
No More B5 S4
Elder Member
Account #: 41217
Default Any Cliff Notes? :-P
"The Lord be with your spirit. Grace be with you."
-2 Timothy 4:22
Click for Peer FATS Times. Updated: 03/15/05<a href="http://public.fotki.com/s4madman/scenerylandscape/wallpapers_1600x1200/">
Got Wallpapers? Updated: 10/29/04</a>
The AW Database. Updated: 02/15/05
No More B5 S4 is offline   Reply With Quote
Tags
02, 2000, 2001, 20015, audi, b5, common, cost, fluid, issue, issues, problems, replacement, s4, transmission, turbo
