Old 09-03-2003, 01:03 PM   #1
VonK :: Retired
Member
Account #: 12010
Default Why more passenger side turbos fail first.--->
My passenger side turbo had bearing failure. The blades of the turbine and compressor wheels were undamaged, except for outside rubbing. Why the passenger side?
Fig. 1
Fig.1 illustrates how oil is supplied to the turbo bearings via the inlet port into a small reservoir, and from there to the bearings through a small metering hole (yellow arrows). The metering hole controls the flow rate of oil to the bearings approximately to the rate it bleeds out through the bearings to the return.
From the size of the metering hole it can be seen that the flow rate is low enough to cause the oil in the relatively large cross section of the external supply line to move slowly (Fig 2, yellow arrow).
Fig. 2
Unfortunately, on the passenger side, that supply line carries the slow moving oil past the cherry red glowing exhaust manifold (red arrow) at a distance of about 1/2", further heating it before it reaches the turbo.
On the track, we see oil temperatures in the engine as high as 275°F. Further heat added by radiation from the glowing exhaust to the slow moving oil in the passenger side supply line, may well elevate its temperature to prohibitive levels (Radiation heat transfer is proportional to the fourth power of temperature). Certainly, the oil reaching the passenger side turbo under load will be of lower viscosity than that on the driver side raising the probability of bearing failure on that side first.
This problem can be avoided by wrapping the oil supply line to the passenger side turbo with a couple of layers of exhaust wrap (Fig. 3, courtesy Mat@4induktion), or by placing a small piece of sheet metal as radiation shield between the exhaust and the supply line. All those whose engine is out of the car should do this.
Fig. 3
Here's a solution from NAPA:
Fig. 4
On installed engines, a makeshift solution is to stuff a lengthy wad of wrinkled heavy duty aluminum foil between the exhaust and supply line, and wrapping its end around the coolant return line (white arrow) to keep it in place. This can be done by reaching in with the left hand while standing under the car.
Happy Motoring.
VonK
"Not dead yet...!" (Monty Python)
"A little bit of knowledge is a dangerous thing." (unknown)
vonk at bayarea dot net
All statements, quotations and illustrations by VonK are to be construed as his
opinions only, and not as advice, consent, recommendation, guidance, instruction,
and/or suggestion.
VonK :: Retired is offline   Reply With Quote
Old 09-03-2003, 01:13 PM   #2
mpwolf
Elder Member
Account #: 26345
Default I'll be stopping at the supermarket on the way home. ;-)
| 1989 BMW M3 | TMS J-Stock | Bimmerworld Cage | iigomotiv | OMP |
| Borla | UUC | Cobalt Friction | Kosei | Toyo | BBS | Bridgestone | V1 |
| 2005 Kawasaki Ninja ZX-6R | Pearl Magma Red |
| 8 Throttle Bodies...B!TCH
AIM: mpw8888
MSN Messenger: mpwolf@hotmail.com
Yahoo!: mw007e
mpwolf is offline   Reply With Quote
Old 09-03-2003, 01:16 PM   #3
DocSlow (Mini Pig)
Elder Member
Account #: 51367
Default Nice writeup. Because of that, the X chipped k04 car (hadeet) has all that wrapped.
DocSlow (Mini Pig) is offline   Reply With Quote
Old 09-03-2003, 01:18 PM   #4
MichaelTM
Maestro
Account #: 15050
Default that's because you are special. Do you have to pi$$ on everyone's parade?
MichaelTM is offline   Reply With Quote
Old 09-03-2003, 01:19 PM   #5
DocSlow (Mini Pig)
Elder Member
Account #: 51367
Default Get back to work. The stage 12 3.5L Montero/MTM powered S4 is in the "challenge" now.
Old 09-03-2003, 01:21 PM   #6
FrankS
Senior Member
Account #: 563
Default You betta reconize!!
FrankS is offline   Reply With Quote
Old 09-03-2003, 01:22 PM   #7
Hank Hill
Junior Member
Account #: 54559
Default 15w50 :-)
/me run away
Hank Hill is offline   Reply With Quote
Old 09-03-2003, 01:27 PM   #8
Hank Hill
Junior Member
Account #: 54559
Default how did he piss on this "parade"....... he's sharing his S4 owner experience
and you know. sharing is caring.
Old 09-03-2003, 01:30 PM   #9
VonK :: Retired
Member
Account #: 12010
Default Thanks. Wish I'd wrapped it too.
VonK
and/or suggestion.
Old 09-03-2003, 01:31 PM   #10
DocSlow (Mini Pig)
Elder Member
Account #: 51367
Default When a bigger turbo kit comes you, you have a reason to do it ;-)
Tags
hank, hill, suspension, tuning
