Old 03-29-2003, 09:36 PM   #1
Zoltan (icecreaman)
Junior Member
Account #: 31487
Default DIY: Make Your own intake!! Z-Flo/Darintake
Okay, here goes a nice write-up for all you cheapies out there (like me!!). I made and installed this in VegasS4's Tip car(with chip, exhaust) Total COST:no more than $60 TOTAL (depending on what you have already)
Materials)i used:
Cone Filter
3"x8" 30 angle pipe
RED HOT BLUE GLUE
Mesh
Fiberglass(only use if you know how)
spraypaint(black-the fastest color)
First off remove your airbox, and cut the hole in the bottom to give you the INFAMOUS Darintake hole!!
I happen to have some mesh lying around(always!)
Shape it and Fiberglass it to the box
since you done see the hole no need to sand the fiberglass or make it look real neat, jus tmake sure nothing is sticking out too far to interfere with installation.. Put a quick bit of spray paint on there, and BAM your set!!
Here is the bottom box installed with hole and mesh!
Okay go to a Muffler shop (ask S4MadMan for location if you are unsure) Get a 3" pipe 8"long and have them bend it to 30degrees!!!When you get home you may have take a mallet and round out the ends to make round them...the bender may make them a little out of round, this is real easy to do don't worry!(should cost NOMORE than $20)
Pick your self up a nice cone filter. Get one that can suck air from the top(because of the hole you made) It needs to have a 3" opening. This is one from pepboys ($30 retail, those going IGT this is gonna cost ya an extra $30 or so)
Remove filter and take pipe and insert it into the hole in the top of your airbox and check the angle, so you know how to put it in. You need to buy some sealant. Go to Home Depot and get RED HOT BLUE GLUE(its in the pvc section)...This stuff is nasty but the damndest sealant ive ever seen... This stuff gives you 30 seconds so make sure you got your angle down.(also note that the pipe should stick through the hole about an 1/8th of an inch so it meets directly with the screen of the maf!!!) Also when you line your angle up put the filter on and make sure it fits in your box how you want... Now smear that sealent on the end of the tube adn shove it up there (most likely you will have gaps, no worries) Hold it there for 30 seconds then set aside and let dry for 10 minutes. Use silicone to fill the gaps you have from top and bottom(by all means go as crazy with silicone as you like on the inside of the box)
Here is a Vag log of G/S before and after the intake and hole.(tip car) These logs were taken in 68degree weather. stop-120mph, no launch!
Boost logs, for some reason teh spikes are gone with it, shifts smoother...maybe someone else would know the reason. But noticable difference none the less
Any one tell me what you think?!?
And would someone repost this for morning crew Sun and Mon I will be busy!
Thanks
Aim:ZoltanS4
Zoltan (icecreaman) is offline   Reply With Quote
Old 03-29-2003, 09:44 PM   #2
Zoltan (icecreaman)
Junior Member
Account #: 31487
Default also i would like to recognize: Darin and FunkWeasel for ideas on this
not to mention AWE for design...I bought my S-Flo 2 years ago
Aim:ZoltanS4
Old 03-29-2003, 09:45 PM   #3
chuangs4
Member
Account #: 44931
Default Awesome!I just installed s-flo but....
did not cut the hole on the buttom of airbox...According to your write-up,I have to make the Darintake hole like yours!
1995 RS2 avant
2001 S4 wide body conversion
2004 Sportec RS600
chuangs4 is offline   Reply With Quote
Old 03-29-2003, 09:49 PM   #4
Zoltan (icecreaman)
Junior Member
Account #: 31487
Default ;P Yes i would like this to reference the hole as many are posting inquiries about
where the hole goes what it looks like and pics...where they they are! Btw alot of people do a 3" hole or so with wood saw, this is done with dremel
Aim:ZoltanS4
Old 03-29-2003, 10:03 PM   #5
chuangs4
Member
Account #: 44931
Default Yes...a very good reference for all!!
1995 RS2 avant
2004 Sportec RS600
Old 03-29-2003, 10:33 PM   #6
drgolfnut
Member
Account #: 24874
Default does the filter make a huge difference?
and where to get the ITG filter?
HERS: Level10, ASP3 custom tuned for X-1 intake, ER ICs, Bilstein PSS9s, Brembo GT 355, Stasis rear, piggie pipes and modified Miltek, Work Emotions, Matrix OCK, all assembled and cared for by WMS.
HIS: casablanca widebody avant, ASP GT28RS, tuning for 91 octane in process, also babied by WMS.
drgolfnut is offline   Reply With Quote
Old 03-29-2003, 10:49 PM   #7
AUJ
Senior Member
Account #: 46293
Default Maybe the decreased pressure drop influences less boost spikes.
AUJ is offline   Reply With Quote
Old 03-29-2003, 11:00 PM   #8
Zoltan (icecreaman)
Junior Member
Account #: 31487
Default as far as which filter...i have not done tests with various filters
an ITG filter can be purchased from
http://www.parts123.com/PartFrame.as...ITLE=Coast_Fab
also you are gonna have to verify, because i think ITG has an aluminum female position at the end... if this is the case, make your pipe around 6inches or so and go to Home Depot and go to the plumbing section and get a 3"-3" adapter (they are short, good quality and cost maybe $2-3)
Aim:ZoltanS4
Old 03-29-2003, 11:01 PM   #9
Zoltan (icecreaman)
Junior Member
Account #: 31487
Default kind of what im thinking, cause it made the car smoother
all around... this actually worked REALLY well
Aim:ZoltanS4
Old 03-29-2003, 11:22 PM   #10
Audi2ptzero
Elder Member
Account #: 42349
Default Just letting in colder air thru the bottom of the box
will increase the g/s. The reason your your spikes dropped off is because colder air causes a slight pressure drop after the turbos and your reading those levels at the boost sensor.
Audi2ptzero is offline   Reply With Quote
Tags
a4, a6, airbox, audi, b6, black, boys, build, darintake, diy, filter, forum, intake, pep, tube
