Old 12-10-2002, 11:01 AM   #1
SmokinS4™
Member
Account #: 18942
Default The Spring Report: S4 spring comparisions - Rates and Heights
Audiworld now sucks - join Quattroworld.com
how's that for a short signature
Stg4 S4.
SmokinS4™ is offline   Reply With Quote
Old 12-10-2002, 11:04 AM   #2
mpwolf
Elder Member
Account #: 26345
Default Kind of a neat optical illusion on the bottom axis there.
| 1989 BMW M3 | TMS J-Stock | Bimmerworld Cage | iigomotiv | OMP |
| Borla | UUC | Cobalt Friction | Kosei | Toyo | BBS | Bridgestone | V1 |
| 2005 Kawasaki Ninja ZX-6R | Pearl Magma Red |
| 8 Throttle Bodies...B!TCH
AIM: mpw8888
MSN Messenger: mpwolf@hotmail.com
Yahoo!: mw007e
mpwolf is offline   Reply With Quote
Old 12-10-2002, 11:07 AM   #3
SmokinS4™
Member
Account #: 18942
Default BTW, I HAVE the RS4 springs on my car now.....it's nice
in the rear - 3/4 inch drop....but the front looks like an ALLROAD - set on HIGH.
I shoulda gone with STaSiS....I'll have to ride out the winter....at least I don't have clearance problems =)
Stg4 S4.
Old 12-10-2002, 11:09 AM   #4
Prodigy
Senior Member
Account #: 20474
Default very useful data - did you get the rs4 exhaust yet ?
Prodigy is offline   Reply With Quote
Old 12-10-2002, 11:09 AM   #5
DAP@EPL
Audiworld Sponsor
Account #: 6924
Default The drop is dependent on the perch settings of the shocks used.
Unless all springs were tried with the same shocks, the drop measurements aren't that meaningful.
Also some of the springs listed are progressive, aren't they? In that case, the rates aren't constant over the entire compression range.
-Dave Pramanik
DAP@EPL is offline   Reply With Quote
Old 12-10-2002, 11:12 AM   #6
Ray Khan
Account #: 4477
Send a message via AIM to Ray Khan
Default BTW...most advertised rates are bogus
according to Shine...they tend to be way lower than advertised. But nice info nonetheless. Very nice tool for people to consult.
Matt...I would reccomend a coilover. The better setups I've ridden in have been coilover setups. Hard to be a well matched spring/shock combo. I'm probably going with the Motopersona custom rate H&R coilovers in the spring. 500F/625R. FOr an S4...these rates might not be what you want. Not sure where you want comfort vs performance now that the little on is here.
Ray Khan
00 1.8T QM
APR stage 3+
APR Exhaust
APR Intake
DUH FMIC
Southbend OFE Stage 4 clutch
SPEC 12 lb flywheel
Greddy Profec B electronic boost controller
Porshe Boxster calipers
BIRA stage I brackets
Hawk HPS brake pads
A8 rotors, SS lines
V&S Short Shifter
Vogtland Coilovers
Neuspeed 19mm rear sway
18x8 Flik Lex
235/40/18 Falken GRB 451
17x7.5 B5 S4 Avus
205/50/17 Dunlop Wintersport 3D
Sony XM 7554 amp with 5.25" and 6.5" Infinity kappas
MTX 801D amp with 2x10" kenwood sub enclosure
Xenons
Fog light relay mod
VDO boost gauge in custom vent pod
Clear corner mod
S4 wheel well liner
RS-4 grill
AIM and MSN messenger:rakha77
Ray Khan is offline   Reply With Quote
Old 12-10-2002, 11:13 AM   #7
SmokinS4™
Member
Account #: 18942
Default The Euro S4 and RS4 springs were measured on the same scale.
The heights were also measureed by me.
The OEM springs were pretty linear.
As for the rest of the data - it was compiled based on what I have found searching the forums.
Stg4 S4.
Old 12-10-2002, 11:15 AM   #8
SmokinS4™
Member
Account #: 18942
Default The RS4 perch is the same as the 2001-2 S4....the 2000 is a different p/n
The only difference was new RS4 bump stops - I couldn't tell you the difference - but they were cheap anyway.
it all fit, just didn't work out as I hoped.
Stg4 S4.
Old 12-10-2002, 11:19 AM   #9
SmokinS4™
Member
Account #: 18942
Default Yes, this is a good reference tool
but a better educational tool for me.
As for my next step - probably a custom SRS coilover, unless I can find a good deal on those old hyperco springs or MTM/Eibach.
Stg4 S4.
Old 12-10-2002, 11:22 AM   #10
George @ BostonAudi
Elder Member
Account #: 189
Default Where did you see that the euro S4 springs are any different than the US?
Every other source I've ever talked to has said they are the same...
Boston Audi Group Website
George @ BostonAudi is offline   Reply With Quote
