| Register | Pictureposter | Classifieds | FAQ | Members List | Search | Today's Posts | Mark Forums Read | Garage | My Recent Topics | Dealer Listings |
| Notices |
Thread Tools | Search this Thread | Display Modes |
#1 |
Member
Account #: 12010
I haven't been around this forum for over a year. So, when I visited again yesterday, a post about the N75 "race valve" caused me to look into this matter. I haven't time to search the whole past, so some readers might find this just another review. Nonetheless, here's my take for anyone else who might be interested. I'm motivated to do this by people who think they can go the Audi engineers one better by screwing with the unit's calibration screw. The following will explain why this is a dangerous undertaking.
Figure 1 shows how the Waste Gate controls boost, and Figure 2 shows how the ECU controls the Waste Gate by means of the Wastegate Bypass Regulator (N75). ![]() Figure 1 ![]() Figure2 In your imagination, connect the outlet of high pressure from the Impeller (blue) in Figure 1 to the bottom inlet (green) in Figure 2, and the right side outlet (gray) in Figure 2 to the Waste Gate actuator (Pressure Unit) in Figure 1. Here's how this appears to work: A "No-Flow State" exists during idle, when there is no boost and the Waste Gate is held shut by the spring in its actuator (Pressure Unit). When you step on the accelerator, boost builds up, and so does the pressure in the green bottom port of Figure 2. This also pressurizes the gray outlet of N75 leading to the actuator (Pressure Unit) in Figure 1. Once the air pressure in that actuator overcomes the spring pressure, the Waste Gate opens and allows some of the exhaust gases to bypass the turbine wheel. However, this action alone would open the Waste gate at lower boost pressures than are desirable. Here's where N75 comes in. Notice the Restrictor in Figure 2. It allows only a small amount of air to enter from the green port below. As a, result the pressure above the Restrictor (that goes to the Waste Gate actuator) can be regulated by bleeding off controlled amounts of air through the left side purple port of N75. The bleed-off rate is controlled by how far the electric coil pulls up its central plunger, allowing air to escape under the blue cap at its bottom. That pull-up distance is precisely controlled by a pulse width modulated signal from the ECU. To achieve the intended results, N75 is factory calibrated by a screw above the plunger that sets the proper spring pressure of a spring between the plunger and the blue cap. It's easy to see that one might get a little more boost by turning the calibration screw up a bit, thus increasing the bleed-off rate and reducing the pressure to the Waste Gate actuator. But wait, if the ECU finds the boost higher than expects, it will modify its signal to N75 to correct the situation within limits. If those limits are exceeded, surging will set in, particularly under part load. The moral of the story: Don't screw with the screw. Trying to fix any drivability problems this way, only hides some other fault. Sorry about the lecture. :-) Graphics courtesy of Audi of America
VonK "Not dead yet...!" (Monty Python) "A little bit of knowledge is a dangerous thing." (unknown) vonk at bayarea dot net ![]() All statements, quotations and illustrations by VonK are to be construed as his opinions only, and not as advice, consent, recommendation, guidance, instruction, and/or suggestion. |
#2 |
Member
Account #: 439
#3 |
Member
Account #: 30356
![]() Engine Simulator Dahlback Stage 3, other stuff If you live in the NYC Metro area you NEED aftermarket security - if you don't have it WILL be stolen |
#4 |
Member
Account #: 12010
#5 |
Member
Account #: 14388
Mine seems to be causing all sorts of odd boost behaviors right now and will be heading into the dealer service center soon for further investigation.
BTW - Thanks for the explanation. I am just now learning the details of this critter while investigating DTC 17965 and your verbage has helped.
![]() Current: 2007 Silver Gray BMW Z4 3.0si Coupe 2005 Mystic Blue BMW X3 Past: 2005 Silverstone Honda S2000 2004 Silver Audi S4 Avant 2001 Silver Audi S4 sedan 2000 Silver Audi A4 2.8 Sedan |
#6 |
Senior Member
Account #: 46293
#7 |
Senior Member
Account #: 46293
#8 |
Member
Account #: 14388
#9 |
Elder Member
Account #: 6383
Due to surging in factory configuration, so a blatant, don't screw with it, is in accurate.
I agree 100% this is not to be used to increase boost, but this is a nice tuning mechanism to dial out unwanted spikes in your boost delivery. Before spikes of 1.4, now a constant 1.23 on **** gas and a bit less on great gas! I think with the proper checks in place, one can absolutely tune the N75 to function properly if not set by factory properly (in most cases)
| Tags |
| 01, audi, b5, bypass, gate, location, n75, problems, s4, tt, tuning, valve, waste, wastegate, wastegates, x3 |
Previous Thread
Next Thread
| Display Modes | |
Linear Mode
