| Register | Pictureposter | Classifieds | FAQ | Members List | Search | Today's Posts | Mark Forums Read | Garage | My Recent Topics | Dealer Listings |
| Notices |
Thread Tools | Search this Thread | Display Modes |
#1 |
Member
Account #: 10011
People have claimed that lowering the weight of the wheel/tire by say 10 lbs per wheel will have an 8-fold effect at each wheel, effectively lightening the vehicle by 320 lbs. I smelled a rat here and decided to perform a little physical analysis.
The answer? A 10 lb reduction of wheel/tire weight will result in a total overall apparent effect of reducing vehicle weight by about 65 lbs and at absolute maximum, 80 lbs. The analysis follows: Question: What is the effective additional mass of wheels/tires due to their rotation? For the vehicle in motion, the kinetic energy is given by: Ekinetic = ½ * (Mtotal*V2 + 4*Iwheel*w2) Where Mtotal = Total vehicle mass including wheels Iwheel = moment of inertia of a single wheel/tire combination V = Velocity of vehicle w = rotational velocity of the wheel (in radians/sec) Now, V = Rtread * w where Rtread = effective radius of the tire's tread Combining, we find: Ekinetic = ½ * (Mtotal + 4*Iwheel / Rtread2) * V2 So the effective additional mass added to the vehicle due to the wheels rotation = 4*Iwheel / Rtread2 Now, Iwheel = Mwheel * Reffective2 Where Mwheel = mass of the wheel/tire combination Reffective = radius of gyration (which is always less than Rtread ) What is this radius of gyration (otherwise known as the radius of inertia)? It is the radius at which an infinitely thin hoop of material of identical mass would have the same moment of intertia as the body in question. It is a mathematical abstraction, but can be calculated for any object. For example, a disk of uniform density would have an Reffective = 0.707 x Rdisk Now, finally, the effective additional mass added to the vehicle due to the wheels rotation is: Mdue to rotation = 4 * Mwheel * (Reffective / Rtread)2 On a per wheel basis, the EFFECTIVE TOTAL wheel mass is given by: Mwheel, effective = Mwheel * (1 + (Reffective / Rtread)2 ) Reffective / Rtread is always less than 1 and probably somwhere around 80% by my guess. This ratio is a function of wheel and tire weight disribution. So in this case, Mwheel, effective = Mwheel * 1.64 The absolute maximum (impossible) case would be Mwheel, effective = Mwheel * 2 Example: New wheels and tires are fitted, lowering the weight of each wheel / tire combo by 10 lbs. Assuming the radius of inertia of the wheel and tire combination are 80% of the outer radius of the tire, the apparent effect is to lower the weight of the car by 65.6 lbs (16.4 lbs per wheel). One further note: I used an energy analysis because it was more convenient for me. The exact same conclusion results if the analysis is performed using Newton's Second Law (F=M*a). This is not a steady-state analysis: it applies to all linear acceleration and deceleration conditions as long as traction is maintained. edited 11/16/02 |
#2 |
Elder Member
Account #: 26345
![]() ![]() | 1989 BMW M3 | TMS J-Stock | Bimmerworld Cage | iigomotiv | OMP | | Borla | UUC | Cobalt Friction | Kosei | Toyo | BBS | Bridgestone | V1 | | 2005 Kawasaki Ninja ZX-6R | Pearl Magma Red | | 8 Throttle Bodies...B!TCH AIM: mpw8888 MSN Messenger: mpwolf@hotmail.com Yahoo!: mw007e |
#3 |
Member
Account #: 10011
#4 |
Elder Member
Account #: 13456
don't make me check your work over mister! and you know i'm going to now....over the weekend.
#5 |
Elder Member
Account #: 189
Keep in mind, wheels don't have an even weight distribution from the hub to their outer surface... most of the weight is on the very outer part of the wheel.
I didn't go through your math completely, but I think there's something else off with it -- vehicle weight shouldn't be a factor at all. The reason why reducing unsprung and rotational mass helps the car isn't because it makes the car lighter, but because that weight (both unsprung, and more importantly, the higher mass at a distance from the hub) impacts significantly the drive train loss. (Some percentage of your total engine output has to be used to both pass energy across your suspension to the body of the car, and to accelerate the mass of the wheels) |
#6 |
Member
Account #: 125
"I can't stop apexing" ![]() 2000 S4 :: Nogaro Blue :: 6-spd :: AWE RSK04 :: AP Racing 13" 4-pots STaSIS Tracksports 550f/600r + 19mm rear sway bar :: APR Bipipe RS4 ICs :: Forge BPVs :: Autospeed DPs :: Borla :: Aquamist 1s UUC 40% short shifter w/spacer mod :: AWE center vent boost guage Lightweight flywheel :: 18x8 Ronal LZ's :: 235/40-18 Toyo T1R's 2002 allroad :: Atlas Grey :: Tip :: 245/50-17 Dunlop SP5000's Looking for tires? See My review of all of the tires I've had on my S4 Need info? See Everything anyone needs to know about their S4 Help our troops protect their heads: Donate to Operation Helmet ![]() Rest In Peace Matthew Ammon a/k/a O.W. Kenobi. May the Force be with you as you keep on apexing. Read his funniest post here. |
#7 |
Elder Member
Account #: 13456
out at the edges of the tire...in other words max possible contribution from wheel weight....but i agree it loooks suspect...i'll take a look at it this weeekend...
#8 |
Elder Member
Account #: 189
Sorry, I wasn't clear. I meant to say thats why I think he got 6x not 4x.
| Tags |
| 189, acceleration, bmw, tire, weight, wheel, wheels |
Previous Thread
Next Thread
| Display Modes | |
Linear Mode
