| Register | Pictureposter | Classifieds | FAQ | Members List | Search | Today's Posts | Mark Forums Read | Garage | My Recent Topics | Dealer Listings |
| Notices |
Thread Tools | Search this Thread | Display Modes |
#1 |
Member
Account #: 16111
I did some modifications to my air intake today and VAG tested MAF flow, and saw a peak increase of 15 grams/sec (that is almost 20 hp!). I have done lots of different airflow testing in the past so I typically know what to expect (little gain). I was quite surprised by these results.
For the starting point I am using a standard AWE S-flo intake. With temps approaching 80 deg I peaked at about 265 grams/sec today. This is completely consistent with prior testing I've done in these temps (and also pretty consistent with most reports from chipped cars out there). As ambient temps go down, I typically gain about 3 grams per 10 degrees (and I've seen as high as 280 grams/sec with temps around 40 deg). I did 3 things to the intake: 1) Installed a wider (standard JC60/73) ITG maxogen cone filter than that in the AWE S-flo (which is a G60 spec). I measured and calculated that the larger filter has about 15-20% more surface area. 2) Sawed an inch or so off the end of the S-flo intake pipe, to shorten it such that the filter is situated a bit higher in the airbox. Otherwise the filter was crammed a bit by the sides of the lower airbox, so doing this created a better perimeter of air space around the filter. 3) Cut a small hole in the very bottom of the airbox to let in more air from the fenderwell. Here are the before and after results from VAG: ![]() As you can there was a solid 10 g/sec gain through most of the upper RPMs, finally peaking at about 15 g/sec. This represents a theoretical 15-20 hp gain, which was definitely more than I expected. Until now I had never peaked at 280 g/sec except in 40 degree weather. I can now foresee hitting at least 290-295 in that cold air. So for any non-believers (I used to be one) that nothing can really be done to the stock intake to get any significant gains, take this data for what it's worth.
2000 6-spd
#2 |
New Member
Account #: 38078
#3 |
Elder Member
Account #: 33816
GIAC X, SLs, Borla, H&R+Bilsteins, Piggie SS. AIM - DYOS4 |
#4 |
Elder Member
Account #: 41217
--------------------------------------------------------- "The Lord be with your spirit. Grace be with you." -2 Timothy 4:22 Click for Peer FATS Times. Updated: 03/15/05<a href="http://public.fotki.com/s4madman/scenerylandscape/wallpapers_1600x1200/"> Got Wallpapers? Updated: 10/29/04</a> The AW Database. Updated: 02/15/05
#5 |
Account #: 25882
5.7 Liters of Forced American Muscle - 2 + 8 = 715 6.0 Liters of American AWDrivin Muscle & 599ccs of Japanese Track Samurai (ninja style) http://public.fotki.com/johnjacobjingleheimer/ |
#6 |
Elder Member
Account #: 6383
Since I don't have the correct oil to keep it clean, it has been sitting on my shelf for roughly a year.
would be interested in seeing what you have done.
#7 |
Senior Member
Account #: 21229
Jason Patel '96 BMW M3
#8 |
Member
Account #: 2711
part of the dirty factor comes from the hole cut in the bottom of the box but the ITG filters perfectly, AWE sells the oiling kits also! Now put the damn thing including the modded mass air meter back on it works.
| Tags |
| 32, air, audi, awe, darin, exhaust, flo, gain, horsepower, intake, mods, q7, s4, sflo, stock |
Previous Thread
Next Thread
| Display Modes | |
Linear Mode
