Old 07-27-2002, 11:21 AM   #1
donistook
Junior Member
Account #: 1510
Default S4 Crankshaft/engine block
I am freshening one of our race motors and I thought you guys might like to see a few things. You will note on the crankcase picture that the S4 uses four bolt main bearing caps, as does the RS4. The 2.8 A4 engine only uses two bolt main bearing caps. this gives a stronger, higher reving capabilities to the engine. If you look at the top of the picture, you will see the crankshaft rod journal bearing surface is offset between opposing cylinders, i.e., cylinders 1 and 4 oppose each other, but they use the same rod journal on the crankshaft. If you look, you will see that the rod journal surface is offset, allowing the rods to run at different angles.
The link is to a picture of the lower end of the forged connecting rod showing you how the rod is cracked versus machined where the upper and lower section of the rod comes together. This "Crack" gives a stronger surface to bite onto when the rod ends are mated together and torqued...allowing for less movement.
Don Istook
donistook is offline   Reply With Quote
Old 07-27-2002, 11:34 AM   #2
donistook
Junior Member
Account #: 1510
Default Re: S4 Crankshaft/engine block
I am freshening one of our race motors (we have three of them) and I thought you guys might like to see a few things. You will note on the crankcase picture that the S4 uses four bolt main bearing caps, as does the RS4. The 2.8 A4 engine only uses two bolt main bearing caps. The four bolts give stronger, higher reving capabilities to the engine. If you look at the top of the picture, you will see the crankshaft rod journal bearing surface is offset between opposing cylinders, i.e., cylinders 1 and 4 oppose each other, but they use the same rod journal on the crankshaft. If you look closely, you will see that the rod journal surface is offset, allowing the rods to run at different angles.
Don Istook
Old 07-27-2002, 12:37 PM   #3
System_S4k
Elder Member
Account #: 23081
Default Mmmmm.... Car porn. :)
System_S4k is offline   Reply With Quote
Old 07-27-2002, 12:43 PM   #4
s4what?
Member
Account #: 30356
Default Love it - keep it coming
Engine Simulator
Dahlback Stage 3, other stuff
If you live in the NYC Metro area you NEED aftermarket security - if you don't have it WILL be stolen
s4what? is offline   Reply With Quote
Old 07-28-2002, 12:41 PM   #5
Singletrack
Account #: 25380
Default Cool! I've never seen that before - thanks.
2008(9?) S5 - ordered 3/29/08
2004 Subaru Impreza WRX STi
2000 A6 2.7T - Sold
"On the run from Johnny Law; ain't no trip to Cleveland."
Singletrack is offline   Reply With Quote
Tags
crankshaft, crankshafts, rodjournalbearing, s4
