Old 04-17-2002, 02:15 PM   #1
ZoomS4
New Member
Account #: 30976
Default Is there a difference in a 2001 and a 2001.5 besides the badges
'01 Silver
UUC Shifter 40%
Miltek catback
18"Sportec Mono 10s
ZoomS4 is offline   Reply With Quote
Old 04-17-2002, 02:28 PM   #2
ryans4
Senior Member
Account #: 4359
Default yes...
Different ECU (M vs. H for a manual)
No FHose in the 2001.5
Different Oil Inlet lines for the Turbos in 2001.5
Different Shifter stalk in the 2001.5
and that's just what has become apparent so far, i'm sure the list goes on and on...
ryans4 is offline   Reply With Quote
Old 04-17-2002, 02:31 PM   #3
Taner Halicioglu
Super Moderator
Account #: 623
Default other visual engine differences, as well...
I think that's when the vacuum line T changed to metal, and the hose at the back of the engine that goes thru the firewall is different....
I'm sure there are other things, too
-T
Taner Halicioglu is offline   Reply With Quote
Old 04-17-2002, 02:37 PM   #4
0700
Senior Member
Account #: 6207
Default Hitachi MAF, Cosworth-look intake man, injectors, tranny, glove box, uprights...
larger oil passage in turbo center housing to go with bigger lines.
Different aux. fan
tbb
bpv
pcv valve
intake piping
fuel lines
tires
trans fluid
0700 is offline   Reply With Quote
Old 04-17-2002, 02:42 PM   #5
Amnizu
Junior Member
Account #: 24128
Default At what build date did these things happen?
Mine is 4/01.. has a new badge..is there anything I should watch out for?
Amnizu is offline   Reply With Quote
Old 04-17-2002, 02:48 PM   #6
ryans4
Senior Member
Account #: 4359
Default new badge pretty much means 2001.5...as for when exactly, that's trickier.
Old 04-17-2002, 03:06 PM   #7
Taner Halicioglu
Super Moderator
Account #: 623
Default I think the Hitachi MAF change happened in the middle of the "2001" (before "2001.5" newbadge)
new TBB is on all the 2001's
what changes on the fuel lines?
Old 04-17-2002, 03:07 PM   #8
ryans4
Senior Member
Account #: 4359
Default yes, Hitachi MAF came with the "H" box 2001's...
Old 04-17-2002, 03:15 PM   #9
0700
Senior Member
Account #: 6207
Default some 00 leaked gas in the pass. fender well, remember?
Old 04-17-2002, 03:23 PM   #10
RubenG
Junior Member
Account #: 34379
Default So what does this new badge look like?
01' S4, Loaded BBlack, X-Giac, VM3, V1
89' Jetta GLI - daily beater
81' Scirocco S, 2096cc Oettinger hemi, 6 speed - torque monster/speed demon!
I thought I wanted a career...turns out I just wanted paychecks.
RubenG is offline   Reply With Quote
Tags
2001, 20015, badge, badges, change, s4
