Old 03-11-2002, 01:59 PM   #1
ryans4
Senior Member
Account #: 4359
Default With all this talk of Downpipes lately, it seems there is a lot of confusion...
After reading this post
It seems that lots of people don't know much about what each downpipe kit offers.
I've been collecting information (pre-purchase research) and this is what I've found so far.
***Any corrections to my information are appreciated.***
I just want to have everyone on the same page.
I've put each option against a list of features that seem to cover a portion of each aftermarket downpipe system.
Those features are:
1. Increased pipe diameter over stock?
2. Removal of Pre-Cats?
3. O2 sensor location fore and after cat?
(this will allow ANY ECU to run with the downpipes)
4. Test-Pipe Option?
5. Flex Joints?
6. Cat Type
7. Cost?
So now how does each option (that I'm aware of) stack up?
Stock System
Diameter = <2.25" (I believe)
Pre-Cats = YES
O2 Sensor location fore and aft of cats = YES
Test Pipes = NO
Flex Joints = YES (metal mesh/bellows-type)
Cat Type = Pre = Metal, Main = Ceramic
Cost = Nothing, you already have them.
APR
Diameter = 2.5" (I believe)
Pre-Cats = NO
O2 Sensor location fore and aft of cats = NO
Test Pipes = YES
Cat Type = ?
Cost = $1600
AWE
Diameter = taper from 3" to 2.5"
Pre-Cats = NO
02 Sensor location fore and aft of cats = YES
Test Pipes = YES
Flex Joints = YES (ball/socket joint)
Cat Type = 400 cell per inch Ceramic Matrix
Cost = $1595
JP Engineering
Pre-Cats = NO
Test Pipes = NO
Cat Type = Carsound (400cpi Ceramic)
Cost = $1350
Milltek
Diameter = 2.3" (60mm)
Pre-Cats = NO
O2 Sensor Location fore and aft of cats = They say YES, but it doesn't look like it from the PICS. But we'll go with YES since they claim it.
Test Pipes = NO
Cat Type = continuous stainless steel cores
Cost = $1865
MTM
Diameter = ?
Pre-Cats = NO
O2 Sensor location fore and aft of cats = ?
Test Pipes = ?
Flex Joints = YES (not sure what type)
Cat Type = ?
Cost = $6900 (part of there Stage 3 package)
RS4
Diameter = ?
Pre-Cats = YES
Test Pipes = NO
Cat Type = ?
Cost = $3000
(cost is from this post
That about sums it up.
Corrections are encouraged (after all, we should all know the right information).
I'm not trying to start a war (or am I?), just trying to get the cold hard numbers.
Can one of you RS4 downpipe junkies post information about the pipes, I know nothing about these.
FWIW...
ryans4 is offline   Reply With Quote
Old 03-11-2002, 02:29 PM   #2
Todd/A.W.E.
Member
Account #: 1150
Default Corrections:
Milltek: no test pipes (those pipes in the pics are to mate to exhaust system. Makes them universal to the RS4, too, I think)
MTM: no pre-cats.
Carsound cats are 400 cell ceramic, too.
Todd Sager
President
A.W.E. Tuning
Order line: 1-888-565-2257
Tech line: 215-658-1670
Todd/A.W.E. is offline   Reply With Quote
Old 03-11-2002, 02:31 PM   #3
Scourge
Junior Member
Account #: 15242
Default Is there anything different on AWE dp's now? They did not have o2 sensors ...
before and after cats and hence needed a chip before...
Scourge is offline   Reply With Quote
Old 03-11-2002, 02:31 PM   #4
ryans4
Senior Member
Account #: 4359
Default thanks...i edited my post.
Old 03-11-2002, 02:32 PM   #5
ryans4
Senior Member
Account #: 4359
Default I never heard that. AWE always had the O2 sensor moved...
But if you run Test Pipes you need an ECU that can understand you now have NO cats.
Old 03-11-2002, 02:34 PM   #6
KAOS, AZ (Papa Smurf)
Member
Account #: 1134
Default nope, disagree
EVERYTHING POSTED HERE BY ME IS OF PERSONAL OPINION
KAOS, AZ (Papa Smurf) is offline   Reply With Quote
Old 03-11-2002, 02:39 PM   #7
LCP
Member
Account #: 125
Default Stock cats are ceramic (main), metal (pre), and I *think* a tad less than 2.25"
"I can't stop apexing"
2000 S4 :: Nogaro Blue :: 6-spd :: AWE RSK04 :: AP Racing 13" 4-pots
STaSIS Tracksports 550f/600r + 19mm rear sway bar :: APR Bipipe
RS4 ICs :: Forge BPVs :: Autospeed DPs :: Borla :: Aquamist 1s
UUC 40% short shifter w/spacer mod :: AWE center vent boost guage
Lightweight flywheel :: 18x8 Ronal LZ's :: 235/40-18 Toyo T1R's
2002 allroad :: Atlas Grey :: Tip :: 245/50-17 Dunlop SP5000's
Looking for tires? See My review of all of the tires I've had on my S4
Need info? See Everything anyone needs to know about their S4
Help our troops protect their heads: Donate to Operation Helmet
Rest In Peace Matthew Ammon a/k/a O.W. Kenobi. May the Force be with you as you keep on apexing.
Read his funniest post here.
LCP is offline   Reply With Quote
Old 03-11-2002, 02:42 PM   #8
Scourge
Junior Member
Account #: 15242
Default Well...
take a look at Todds post
http://forums.audiworld.com/s4/msgs/465188.phtml
AWE dp's DO require a recoded chip...
"The improved flow allowed us to increase upper rpm boost, while requiring us to adjust fueling a bit higher. We believe that a properly tuned downpipe system *requires* the use of a specific downpipe chip if the downpipes are doing their job of improving exhaust scavenging. Our design requires a change to the O2 sensor coding, too, as we opted to place the O2 sensors close to the OEM position to maintain proper tension on the wiring.
Old 03-11-2002, 02:47 PM   #9
ryans4
Senior Member
Account #: 4359
Default Interesting...my thoughts are...
That if the O2 sensors are Pre and Post the cat, then they are still registering the delta, and thus still work.
As for Todd's statement, I'm sure that a proper ECU that takes full advantage of the change in exhaust flow is a bonus to the system.
Perhaps Todd/AWE can comment more on this?
Old 03-11-2002, 02:48 PM   #10
ryans4
Senior Member
Account #: 4359
Default thanks...updated the post.
Tags
audi, c4, carsound, cat, chip, downpipe, downpipes, inch, o2, placement, reviews, s4, sensor, stainless, tt
