Old 01-13-2002, 02:01 PM   #1
jyoteen
Member
Account #: 439
Default Okay, the city light saga has ended....
The install was very straight forward. You know, it always SOUNDS harder on paper. I knew it was probably easy, but I'm always intimidated by screwing around with a car that cost $40K. The VW, I've done all kinds of stuff to, and it's the same.
I would like to thank Mark P. for his pictures. In fact, my digicam died 4 pictures in, so I had to steal his to comment and make amendments/addendums to his instructions. These pointers are for doing the city lights ONLY, not the entire euro light install.
The instructions only apply to those who want the city light to act as the parking light, thus DISABLING the corner lamp's always on status when the parking/headlight switch is in position 1 or 2. The corner lamps will act as blinking lights ONLY if you follow these pointers. Good luck, and be PATIENT!
So here it goes:
jyoteen is offline   Reply With Quote
Old 01-13-2002, 02:07 PM   #2
Kent L
Senior Member
Account #: 19404
Default Nice pics! Glad things turned out great.
Kent L is offline   Reply With Quote
Old 01-13-2002, 02:13 PM   #3
jyoteen
Member
Account #: 439
Default Thanks for your help as well.
Old 01-13-2002, 02:19 PM   #4
Kent L
Senior Member
Account #: 19404
Default Welcome. Just wished I had fancy pics to show everyone.
Like you said, pictures are worth a thousand words. Just sometimes you wanna get the mod completed so picture taking time is just a distraction.
Old 01-13-2002, 02:19 PM   #5
TRM
Elder Member
Account #: 20422
Default good pics - what did you use for the harness connections at location 3 ?????
the AWE city lights kit had the yellow wires, but they also had these very tiny special clips which work as intended with the stock harness. they snap in and neever come out and create the contact between the wiring and harness... curious since i don't see them in your pics.
<sub>uh! let me see you shake in your boots. come back to the old school. come back to your roots!</sub>
TRM is offline   Reply With Quote
Old 01-13-2002, 02:22 PM   #6
jyoteen
Member
Account #: 439
Default The AWE wiring harness is really a VW/Audi electrical connector...
I had one laying around (they come as a wire with the two ends with those special connectors). And I got two more "just in case" from a VW dealer at $1.80 each.
Old 01-13-2002, 02:24 PM   #7
jyoteen
Member
Account #: 439
Default BTW, gotta give credit to Mark P. for his excellent writeup and pics (which I borrowed two of)
My digicam died, so I had to resort to stealing ;-)
I think Mark P's install is a bit different because he's using relays to do some fancy on/off switching, which I didn't need or want.
Old 01-13-2002, 02:25 PM   #8
TRM
Elder Member
Account #: 20422
Default ok thanks.
Old 01-13-2002, 02:37 PM   #9
Eugenius
Member
Account #: 26591
Default Do you write manuals for a living? :)
__________________________________________________
photos
2 1 0 4 4
__________
Eugenius is offline   Reply With Quote
Old 01-13-2002, 04:22 PM   #10
audiophilitis
New Member
Account #: 16459
Default Do the city lights remain lit when the headlights are on?
audiophilitis is offline   Reply With Quote
