Old 10-11-2001, 02:24 PM   #1
Third ROC
New Member
Account #: 11029
Default Can U Launch? Request for you street racer & drag strip racers...
There seems to be a lot of questions about how to launch the S4 properly. Can any of you guys shoot a video clip of the proper technique. Say, from the back seat, passenger side, over the driver's right shoulder so we can see the tach and footwork (w/ feet illuminated if necessary)? Kinda like those MotoRing videos you see from Japan. Help us inexperienced types achieve those 1.8 - 1.9 60' times that we dream about (Galati style) instead of burning our clutches making fools of ourselves at the dragstrip!
Thanks,
-ROC
Third ROC is offline   Reply With Quote
Old 10-11-2001, 02:33 PM   #2
elCheng
Member
Account #: 10847
Default i tried double clutching in 1st, albeit on the street
works pretty good according to the butt dyno.
you can also try the e-brake method:
hold car at 3000ish rpm in 1st gear, clutch right at the point where it wants to connect, and hold the ebrake to keep car from lurching.
when the light goes green, drop ebrake, drop clutch and go go go
________
Whatever...
elCheng is offline   Reply With Quote
Old 10-11-2001, 02:56 PM   #3
Third ROC
New Member
Account #: 11029
Default How do you double-clutch?
-ROC
Old 10-11-2001, 03:02 PM   #4
paizuri pizzo (maod)
Member
Account #: 25253
Default are you or were you in any way associated with the military?
paizuri pizzo (maod) is offline   Reply With Quote
Old 10-11-2001, 03:11 PM   #5
Pat-SoCal
Elder Member
Account #: 16079
Default Pat's quick FAQ
First lets establish a goal to have everytime you launch the car. In general, you're going to want to leave the line with as much boost as possible. If this is a new concept, don't be alarmed. You'll see why in a minute.
Contrary to popular belief it doesn't take a GREAT driver to launch this car. To tell you the truth, I don't know the exact rpm the motor is at when I give it the clutch. The reason? Simple, it's different every time
Let me tell you, as close as possible, exactly how I launch the car. Before I even get close to the starting line, the motor doesn't see above 1500rpm. I want the clutch to be as cool, and as grabby as possible. When I roll up to the line I do a couple of nuetral revs to increase vacuum (works better to create boost later). On the line, seconds before I launch, I rev the motor between 2.5k and 4k. This is to get my rythm going so that I catch the motor on its uprev (you'll se in a sec.).
Eventually when I engage the clutch, I want to have the turbos pre-spooled so that I'm already making plenty of horsepower. That way when the clutch is engaged, it has the power available to dig itself out of the hole.
I don't slip the clutch, and I don't sidestep the clutch (6k dump). When I do engage the clutch, the motor has been on a free-rev from ~3k to ~5k or more. I usually "aggresively release" the clutch anywhere between 4.5k and 5k. Honestly, working the clutch is the easy part of the whole equation. It's what you do before you drop the clutch that matters.
When the clutch is engaged, the motor hangs around 5k then gets drawn back down to 4k ("hanging revs"), then catches up with the drivetrain, and from then it's all about rowing gears. You can hear this happen in one of my videos:
This is one where "hanging revs" are very audible"
http://streetracing.crosswinds.net/041401/6.asx (please type the web address into your browser. It won't work if I link it. Sorry.
This one is an excellent way to illistrate how I get into a rythm before I launch: http://streetracing.crosswinds.net/051201/17.asx (once again please type into your web browser to make this work)
And this one will illistrate both how the revs "hang" until the driveline catches up, and how I rev the motor to get into my rythm:
http://streetracing.crosswinds.net/071001/5.asx
(sorry, but yet another inconvenience.... typing in the browser)
IMPORTANT: don't just watch the videos, listen to the wagon, and imagine yourself doing it in real life.
Pat-SoCal is offline   Reply With Quote
Old 10-11-2001, 03:12 PM   #6
Pat-SoCal
Elder Member
Account #: 16079
Default don't worry about it. Learn how to heel-toe first.
Old 10-11-2001, 03:27 PM   #7
George @ BostonAudi
Elder Member
Account #: 189
Default Damn. Impressive. What the hell do you have done to that thing?
You got MAD rowin skillz ;-)
Boston Audi Group Website
George @ BostonAudi is offline   Reply With Quote
Old 10-11-2001, 03:32 PM   #8
Pat-SoCal
Elder Member
Account #: 16079
Default *wavers hand* "Stock" (that's from cannonball run... the Arab guy's thug tell the cop that)
APR race program in all of those videos. Stock downpipes, short shifter, KnN, Forge BPV's, and an ADS.
Old 10-11-2001, 03:45 PM   #9
leslie
Elder Member
Account #: 92
Default "the motor doesn't see above 1500rpm" ... Your engine temps are ~200 though, right?
leslie is offline   Reply With Quote
Old 10-11-2001, 03:49 PM   #10
Pat-SoCal
Elder Member
Account #: 16079
Default No, because the car has been sitting for a solid hour or two...
the oil temp is just above the 150 mark, and the water tem reads a tick under where it usually reads under Normal Driving Conditions.
Tags
car, clutch, drag, dragstrip, dump, gear, launch, launching, light, rpm, rs4, s4, sidestep, strip, technique
